Outputting a PWM signal and it's inverse thru gpio pins
I have two questions:
How do I access the gpio pins of nrf52840 dk? what example program from nrf5 sdk can I use as example?
Is there a simpler example program to output a pwm signal of example like 400kHz and it's inverse in the pins?I'm looking at the PWM driver example of nrf5 sdk and it's a really big leap for someone like me who's use to programming via Arduino IDE
    The description of the application above sounds very similar to the functionality demonstrated in our PWM Library example from the SDK. I highly recommend checking out this example, to see how you may go about setting up two inverted PWM's using the PWM library provided in the SDK.
    Unfortunately, the pwm library instances are limited to 200 kHz. If you need 400 kHz, you will need to make use of the PWM peripheral. You could see how this can be used in the PWM driver example - however, this example might seem a little intense for someone who's most used to Arduino development. The example contains multiple demons, which in turn makes it seem daunting to familiarize with.
    To make things easier, you could instead have a look at the project I have included below, which is made for the nRF52840 DK. This project is the same as the one referenced by my colleague Torbjørn in this ticket. It showcases a much simpler approach to setting up the PWM peripheral, with a much less complex output. Once you get the hang of this example and how it works, you can begin looking at modifying it for your application needs.
    Mind you that this example uses the legacy nrf_drv driver, but in never SDK's this is using the nrfx driver behind the scenes through forwarding macros.
    2627.pwm_driver_simple.zip
    You should have a look at the nrfx_pwm API Reference when you start modifying the example.
    No worries at all - we've all been new to this at some point! :)
    Please do not hesitate to ask, if you should encounter any issues or questions.
    Karl
  • You could see how this can be used in the PWM driver example
    Oh so I should use the pwm driver example rather than the pwm library when going to output 400kHz?
    By any chance you can provide me some resource I could read on or guidance so I could learn to handle these demons? I'm really new in this embedded programming stuff
    Are you referring to the zip file you attached?
    Yes, this part might seem a little bit confusing, but the PWM library actually does not use the PWM peripheral - it uses the GPIOTE + TIMER peripherals to create a low-power PWM. This is better to use if the application only requires a simple, low-frequency, low-power PWM instance.
    In your case, you will rather need to use the PWM peripheral - which gives you much more options to configure the waveform generation. The PWM peripheral comes with a driver already made for it to make things easier- the PWM driver - which you should use, since you need a 400 kHz waveform.
    Before looking at the PWM driver demos I would recommend that you read through the PWM peripheral documentation to understand what is being done 'behind the scenes' of the PWM driver.
    Then, you could move on to the simple PWM example from the .zip file, to see if you can recognize how the things from the Peripheral documentation is being applied, in order to generate the PWM waveforms.
    The functionality of the different demos are described in the PWM driver example documentation. When you begin to look into these demos I highly recommend looking at only 1 at the time, and understanding how they perform the task as described in the documentation.
    Is there anything else in particular you would like know more about when it comes to embedded programming?
    The source code behind complex embedded example might seem daunting at first glance, when you come directly from Arduino development, but please know that it get better fast.
    In my opinion, one of the best examples to start looking at when you come directly from Arduino is probably the TIMER peripheral example. The reason why I would recommend this one in particular is because it demonstrates core functionality ( config and init of a peripheral, event handler, and LEDs ) and coding practices ( Wait-for-interrupt, error checks ), while also being contained within 108 lines of main.c code.
    When you understand every line of the TIMER peripheral example, you will be well prepared to familiarize with most of the other peripheral examples.
    Yes. Sorry, I should have been more explicit. The .zip file I attached contains the simple pwm example.
    You will need to use the PCA10056 version for your nRF52840 DK.
    Karl
  • How do I access the gpio pins of nrf52840 dk?
     I meant was how do I access for example pin P0.06 on the board? I tried looking at the pwm_library example and all I can recognized being programmed are BSP_LED_0 and BSP_LED_1?
  • In your case, you will rather need to use the PWM peripheral - which gives you much more options to configure the waveform generation.
    Sure, I'll study pwm_driver example for outputting 400kHz
    Yes, I think I'm somehow in a way grasping how pwm is generated here but like a really vague understanding to begin with
    I think from my part I understand the C programming part. What comes confusing for me are the terminologies behind the explanation. It's honestly my first time dealing with terms such as prescalers, registers, and countertops and while I think I can grasp it, I would somehow slip as I read further along the document. This is something I am not good at right now and I was wondering if you could provide guidance on what possible resource I can look up to better understand these terminologies or what topic/subject are they tackled in.
    Yup, I think it's a really simple program to start studying to get familiar with. I'm a bit confuse where I can read up on "_WFI()" and "NRF_SUCCESS"? It's my first time seeing them in C
