wake up from system off
Hello
I have found 2 strange behavoir when I want to wake up nrf from system off state:
1/ when I use pin 15, this does not work at all, but with pin 6 it does. Why?
2/ if i use gpiote to program the gpio pin for wake up this doesn't work. I have to program the pin with nrf_gpio_xxx interface. Why this does not work with GPIOTE ?
Thanks for your answer
Mikael
    Are you using the DK or a custom board? And how did you configure it to wake-up before you went to sleep? Could share your code?
    regards
    Jared
  • Hi Jared,
    I use a custom board. we use as well soft device.
    I read on other post that "The only peripherals that are partially kept active in SYSTEM OFF are GPIO, LPCOMP and NFC"
    So I deduced that GPIOTE is completely off.
    Let me know if misunderstand something.
    before I went to sleep I did
    err_code = nrfx_gpiote_init();
      nrfx_gpiote_in_config_t in_config = NRFX_GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
      in_config.pull = NRF_GPIO_PIN_PULLDOWN;
      // configure wakeup pin
      err_code = nrfx_gpiote_in_init( GPIO_WAKEUP_PIN, &in_config, wakeup_event_handler);
      nrfx_gpiote_in_event_enable( GPIO_WAKEUP_PIN, true);
      // switch OFF both RAM banks when in System OFF mode
      NRF_POWER->RAMON |= (POWER_RAMON_OFFRAM0_RAM0Off << POWER_RAMON_OFFRAM0_Pos) |
                          (POWER_RAMON_OFFRAM1_RAM1Off << POWER_RAMON_OFFRAM1_Pos);
    but does not work
    Now I use
      nrf_gpio_cfg_input( GPIO_WAKEUP_PIN, NRF_GPIO_PIN_PULLDOWN );
      nrf_gpio_cfg_sense_input( GPIO_WAKEUP_PIN, NRF_GPIO_PIN_PULLDOWN, NRF_GPIO_PIN_SENSE_HIGH );
      NRF_GPIOTE->INTENSET = GPIOTE_INTENSET_PORT_Msk;
      NVIC_EnableIRQ(GPIOTE_IRQn);
    and its fine.
    but something strange even. If the gpio goes from 0 to 1 and stay to 1 this does not work. the signal shall do 0-1-0 to work.
    Regards
    Mikael
  •  Hi,
    You're assumption is correct.
    You don't need to configure the pin as input before you call the nrf_gpio_cfg_input as it will do everything itself.
    Here is a quick sample that shows you how to configure it on the DK:
    #include <stdbool.h>
    #include <stdint.h>
    #include "nrf_delay.h"
    #include "boards.h"
    #define PIN_GPIO_WAKEUP 3
     * @brief Function for application main entry.
        /* Configure board. */
        for (int i = 0; i < LEDS_NUMBER; i++)
            bsp_board_led_invert(i);
            nrf_delay_ms(500);
        nrf_gpio_cfg_sense_input(PIN_GPIO_WAKEUP, NRF_GPIO_PIN_PULLDOWN, NRF_GPIO_PIN_SENSE_HIGH);
        bsp_board_leds_off();
        NRF_POWER->SYSTEMOFF = 0x1;
        (void) NRF_POWER->SYSTEMOFF;
        while (true);
  • Ok thank you for the answer.
    have you got an idea of question 1?
    thanks
    Are you using a custom board or a Development kit? If you're using the development kit and pin 15 then you have to observe that pin 15 is connected to Button 3. The pin is therefore connected to a button switch, that connects the pin to gnd when you press the button. You therefore have to do it like this:
    #include <stdint.h>
    #include "boards.h"
            nrf_delay_ms(500);
        //Note the difference in the PULLUP and the Sense requirment being changed to NRF_GPIO_PIN_SENSE_LOW
        nrf_gpio_cfg_sense_input(BUTTON_3, NRF_GPIO_PIN_PULLUP,NRF_GPIO_PIN_SENSE_LOW);
        while (true);
