application timer issue
I'm using NRF51822 with soft device version 6.0.
I'm trying to create an event which should be triggered every 24 Hours. In the current implementation in our code base, I see that we are already initializing application timer module and then creating two timer instances and starting them.
APP_TIMER_INIT(APP_TIMER_PRESCALER, 4, 4, false);
app_timer_create(&timer_id1, APP_TIMER_MODE_REPEATED, timeout_handler1);
app_timer_create(&timer_id2, APP_TIMER_MODE_REPEATED, timeout_handler2);
app_timer_start(timer_id1, TIMER1_TICK, NULL);  // 1 sec
app_timer_start(timer_id2, TIMER2_TICK, NULL);  // 50 msec
Where,
#define TIMER1_TICK APP_TIMER_TICKS(60000, 0)
Similarly, I tried creating a third timer instance(the maximum limit is already set to '4' above) in the same fashion and associated a separate (say, timeout_handler3) timeout handler for 24Hrs, i.e.
#define TIMER3_TICK APP_TIMER_TICKS(24 * 60 * 60 * 1000, 0); // 24 hours
But then the Bluetooth module on the nRF51822 SOC didn't seem to work at all(Seems as if the softdevice failed). Any pointers to debug and/or fix this?
Thank you.
