nRF5340PDK Throughput example, very low throughput.
Hi!
I was trying the throughput example using two nRF5340PDK boards and I observed the throughput is very low, i.e. 1kpbs. I tried programming the cpuappns, but it didn't work correctly, it displayed other stuff on the terminal emulator:
And when I tried programming on the cpuapp, the throughput was 1kbps:
I tried modifying the .conf files, by adding the lines:
CONFIG_BT_CTLR_TX_BUFFER_SIZE=251
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
CONFIG_BT_RX_BUF_LEN=255
But the throughput stayed the same.
 Why would the Bluetooth be so slow? What should I do to maximize the throughput?
Thank you,
Florin Mazilu.
  • Hi Florin
    Which NCS version are you using?
    I tried this myself in v1.4.99-dev1, and making the same changes suggested earlier in this case I get around 1360kbps transfer speed, which is more or less as good as it gets.
    Best regards
    Torbjørn
  • Hi Torbjørn
    I was using v1.4.0, then I removed it and installed v1.4.99-dev1, and after making the changes the throughput stayed the same, very small.
    What board are you using? I'm using nRF5340PDK rev. 0.8.0; could this be a hardware problem?
    Florin.
  • Hi Florin
    I am using v0.11.0 boards, yes, and building for the nRF5340DK and not the PDK.
    It is possible this could be an issue, but I will have to investigate further.
    In the mean time are you able to share the build/zephyr/.config file after you build the project in v1.4.99-dev1?
    Best regards
    Torbjørn
  • Hi
    Sure, I will attach it. Unfortunately, I couldn't share it as .config, so I had to rename it, but this is the build/zephyr/.config file
    # Modules
    # Nordic nRF Connect
    CONFIG_MAIN_STACK_SIZE=1024
    CONFIG_PRIVILEGED_STACK_SIZE=1024
    # CONFIG_NCS_SAMPLES_DEFAULTS is not set
    CONFIG_LOG_DEFAULT_LEVEL=3
    # Bootloader
    # CONFIG_BUILD_S1_VARIANT is not set
    # CONFIG_SECURE_BOOT is not set
    CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
    # CONFIG_B0_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
    # CONFIG_SECURE_BOOT_CRYPTO is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    CONFIG_SB_VALIDATE_FW_SIGNATURE=y
    # end of Secure Boot firmware validation
    # end of Bootloader
    # Bluetooth Low Energy
    CONFIG_BT_MAX_CONN=2
    CONFIG_BT_HCI_TX_STACK_SIZE=1024
    CONFIG_BT_RX_STACK_SIZE=1024
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024
    # BLE Libraries
    # CONFIG_BT_GATT_POOL is not set
    CONFIG_BT_GATT_DM=y
    CONFIG_BT_GATT_DM_MAX_ATTRS=35
    # CONFIG_BT_GATT_DM_DATA_PRINT is not set
    # CONFIG_BT_GATT_DM_LOG_LEVEL_OFF is not set
    # CONFIG_BT_GATT_DM_LOG_LEVEL_ERR is not set
    # CONFIG_BT_GATT_DM_LOG_LEVEL_WRN is not set
    CONFIG_BT_GATT_DM_LOG_LEVEL_INF=y
    # CONFIG_BT_GATT_DM_LOG_LEVEL_DBG is not set
    CONFIG_BT_GATT_DM_LOG_LEVEL=3
    CONFIG_BT_SCAN=y
    CONFIG_BT_SCAN_NAME_MAX_LEN=32
    CONFIG_BT_SCAN_SHORT_NAME_MAX_LEN=32
    CONFIG_BT_SCAN_FILTER_ENABLE=y
    CONFIG_BT_SCAN_MANUFACTURER_DATA_MAX_LEN=32
    CONFIG_BT_SCAN_UUID_CNT=1
    CONFIG_BT_SCAN_NAME_CNT=0
    CONFIG_BT_SCAN_SHORT_NAME_CNT=0
    CONFIG_BT_SCAN_ADDRESS_CNT=0
    CONFIG_BT_SCAN_APPEARANCE_CNT=0
    CONFIG_BT_SCAN_MANUFACTURER_DATA_CNT=0
    # CONFIG_BT_SCAN_CONN_ATTEMPTS_FILTER is not set
    # CONFIG_BT_SCAN_BLOCKLIST is not set
    # CONFIG_BT_SCAN_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SCAN_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SCAN_LOG_LEVEL_WRN is not set
    CONFIG_BT_SCAN_LOG_LEVEL_INF=y
    # CONFIG_BT_SCAN_LOG_LEVEL_DBG is not set
    CONFIG_BT_SCAN_LOG_LEVEL=3
    # CONFIG_BT_CONN_CTX is not set
    # Bluetooth Services
    CONFIG_BT_NRF_SERVICES=y
    # CONFIG_BT_BAS_CLIENT is not set
    # CONFIG_BT_BMS is not set
    # CONFIG_BT_DFU_SMP is not set
    # CONFIG_BT_HIDS is not set
    # CONFIG_BT_HOGP is not set
    # CONFIG_BT_LBS is not set
    # CONFIG_BT_NUS is not set
    # CONFIG_BT_NUS_CLIENT is not set
    CONFIG_BT_THROUGHPUT=y
    # CONFIG_BT_THROUGHPUT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_THROUGHPUT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_THROUGHPUT_LOG_LEVEL_WRN is not set
    CONFIG_BT_THROUGHPUT_LOG_LEVEL_INF=y
    # CONFIG_BT_THROUGHPUT_LOG_LEVEL_DBG is not set
    CONFIG_BT_THROUGHPUT_LOG_LEVEL=3
    # CONFIG_BT_LATENCY is not set
    # CONFIG_BT_LATENCY_CLIENT is not set
    # CONFIG_BT_GADGETS is not set
    # end of Bluetooth Services
    # end of Bluetooth Low Energy
    # DFU
    # CONFIG_DFU_TARGET is not set
    # end of DFU
    # CONFIG_ESB is not set
    # Peripheral CPU DFU (PCD)
    # CONFIG_PCD is not set
    # end of Peripheral CPU DFU (PCD)
    # Networking
    # Application protocols
    # CONFIG_NRF_CLOUD is not set
    # CONFIG_DOWNLOAD_CLIENT is not set
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_AZURE_IOT_HUB is not set
    # CONFIG_CLOUD_API is not set
    # Self-Registration (Zi ZHu Ce)
    # end of Self-Registration (Zi ZHu Ce)
    # CONFIG_ICAL_PARSER is not set
    # CONFIG_FTP_CLIENT is not set
    # end of Application protocols
    # end of Networking
    # NFC
    # CONFIG_NFC_NDEF is not set
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_NDEF_FILE is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    # CONFIG_NFC_PLATFORM is not set
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # CONFIG_NFC_TNEP_CH is not set
    # end of NFC
    # CONFIG_PROFILER is not set
    # SPM
    # CONFIG_SPM is not set
    # CONFIG_IS_SPM is not set
    # end of SPM
    # CONFIG_FW_INFO is not set
    # CONFIG_PPI_TRACE is not set
    # CONFIG_CPU_LOAD is not set
    # CONFIG_SHELL_BT_NUS is not set
    # Nordic MPSL
    CONFIG_MPSL_THREAD_COOP_PRIO=8
    CONFIG_MPSL_SIGNAL_STACK_SIZE=1024
    CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_MPSL_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_LOG_LEVEL_WRN is not set
    CONFIG_MPSL_LOG_LEVEL_INF=y
    # CONFIG_MPSL_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_LOG_LEVEL=3
    # end of Nordic MPSL
    # Partition Manager
    # Zephyr subsystem configurations
    # end of Zephyr subsystem configurations
    # Zephyr samples configurations
    # CONFIG_HCI_RPMSG_BUILD_STRATEGY_SKIP_BUILD is not set
    CONFIG_HCI_RPMSG_BUILD_STRATEGY_FROM_SOURCE=y
    CONFIG_RPMSG_NRF53_SRAM_SIZE=0x10000
    # end of Zephyr samples configurations
    # NCS subsystem configurations
    # end of NCS subsystem configurations
    # CONFIG_PM_SINGLE_IMAGE is not set
    # CONFIG_PM_EXTERNAL_FLASH is not set
    CONFIG_PM_SRAM_BASE=0x20000000
    CONFIG_PM_SRAM_SIZE=0x80000
    # end of Partition Manager
    # nRF RPC (Remote Procedure Call) library
    # end of nRF RPC (Remote Procedure Call) library
    # CONFIG_ZIGBEE is not set
    # Libraries
    # CONFIG_AGPS is not set
    # CONFIG_AGPS_LOG_LEVEL_OFF is not set
    # CONFIG_AGPS_LOG_LEVEL_ERR is not set
    # CONFIG_AGPS_LOG_LEVEL_WRN is not set
    CONFIG_AGPS_LOG_LEVEL_INF=y
    # CONFIG_AGPS_LOG_LEVEL_DBG is not set
    CONFIG_AGPS_LOG_LEVEL=3
    # Binary libraries
    # end of Binary libraries
    # BSD Library for nrf91
    # end of BSD Library for nrf91
    # CONFIG_ADP536X is not set
    # AT Command driver
    # end of AT Command driver
    # CONFIG_LTE_LINK_CONTROL is not set
    # CONFIG_FPROTECT is not set
    CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x8000
    CONFIG_FPROTECT_BLOCK_SIZE=0x8000
    # AT Host Library for nrf91
    # CONFIG_AT_HOST_LIBRARY is not set
    # end of AT Host Library for nrf91
    # CONFIG_DK_LIBRARY is not set
    # CONFIG_AT_CMD_PARSER is not set
    # CONFIG_MODEM_INFO is not set
    CONFIG_RESET_ON_FATAL_ERROR=y
    # CONFIG_FATAL_ERROR_LOG_LEVEL_OFF is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_ERR is not set
    # CONFIG_FATAL_ERROR_LOG_LEVEL_WRN is not set
    CONFIG_FATAL_ERROR_LOG_LEVEL_INF=y
    # CONFIG_FATAL_ERROR_LOG_LEVEL_DBG is not set
    CONFIG_FATAL_ERROR_LOG_LEVEL=3
    # CONFIG_SMS is not set
    # CONFIG_SUPL_CLIENT_LIB is not set
    # CONFIG_DATE_TIME is not set
    # CONFIG_RAM_POWER_DOWN_LIBRARY is not set
    # end of Libraries
    # Device Drivers
    CONFIG_HW_CC3XX=y
    CONFIG_HW_CC3XX_NAME="HW_CC3XX_0"
    # CONFIG_ETH_RTT is not set
    # CONFIG_SENSOR is not set
    # GPS Drivers
    # CONFIG_GPS_SIM is not set
    # end of GPS Drivers
    # CONFIG_NRF_SW_LPUART is not set
    # end of Device Drivers
    # External libraries
    # end of External libraries
    # CONFIG_UNITY is not set
    # end of Nordic nRF Connect
    # MCUboot
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
    # end of MCUboot
    # Nordic nrfxlib
    # CONFIG_NFC_T2T_NRFXLIB is not set
    # CONFIG_NFC_T4T_NRFXLIB is not set
    # Crypto libraries for nRF5x SOCs.
    CONFIG_NRFXLIB_CRYPTO=y
    # CONFIG_NRF_OBERON is not set
    # CONFIG_NRF_CC310_BL is not set
    CONFIG_NRF_CC3XX_PLATFORM=y
    # CONFIG_HW_CC3XX_INTERRUPT is not set
    # end of Crypto libraries for nRF5x SOCs.
    # Nordic Security
    # CONFIG_NORDIC_SECURITY_BACKEND is not set
    # end of Nordic Security
    # CONFIG_BT_LL_SOFTDEVICE_VS_INCLUDE is not set
    # CONFIG_BT_LL_SOFTDEVICE_DEFAULT is not set
    # CONFIG_NRF_RPC is not set
    # end of Nordic nrfxlib
    # Optional modules. Make sure they're installed, via the project manifest.
    # CONFIG_CANOPENNODE is not set
    # CONFIG_CIVETWEB is not set
    CONFIG_HAS_CMSIS_CORE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    CONFIG_LIBMETAL=y
    CONFIG_LIBMETAL_SRC_PATH="libmetal"
    # CONFIG_HAS_SEMTECH_LORAMAC is not set
    # CONFIG_HAS_SEMTECH_SOFT_SE is not set
    # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
    # CONFIG_MBEDTLS is not set
    # CONFIG_HAS_MEC_HAL is not set
    CONFIG_HAS_NORDIC_DRIVERS=y
    # Nordic drivers
    # CONFIG_NRF_802154_SER_HOST is not set
    # end of Nordic drivers
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    CONFIG_NRFX_CLOCK=y
    CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
    CONFIG_NRFX_DPPI=y
    # CONFIG_NRFX_EGU is not set
    # CONFIG_NRFX_EGU0 is not set
    # CONFIG_NRFX_EGU1 is not set
    # CONFIG_NRFX_EGU2 is not set
    # CONFIG_NRFX_EGU3 is not set
    # CONFIG_NRFX_EGU4 is not set
    # CONFIG_NRFX_EGU5 is not set
    # CONFIG_NRFX_GPIOTE is not set
    # CONFIG_NRFX_I2S is not set
    CONFIG_NRFX_IPC=y
    # CONFIG_NRFX_NFCT is not set
    # CONFIG_NRFX_NVMC is not set
    # CONFIG_NRFX_PDM is not set
    # CONFIG_NRFX_POWER is not set
    # CONFIG_NRFX_PWM is not set
    # CONFIG_NRFX_PWM0 is not set
    # CONFIG_NRFX_PWM1 is not set
    # CONFIG_NRFX_PWM2 is not set
    # CONFIG_NRFX_PWM3 is not set
    # CONFIG_NRFX_QSPI is not set
    # CONFIG_NRFX_RTC is not set
    # CONFIG_NRFX_RTC0 is not set
    # CONFIG_NRFX_RTC1 is not set
    # CONFIG_NRFX_SAADC is not set
    # CONFIG_NRFX_SPIM is not set
    # CONFIG_NRFX_SPIM0 is not set
    # CONFIG_NRFX_SPIM1 is not set
    # CONFIG_NRFX_SPIM2 is not set
    # CONFIG_NRFX_SPIM3 is not set
    # CONFIG_NRFX_SPIM4 is not set
    # CONFIG_NRFX_SPIS is not set
    # CONFIG_NRFX_SPIS0 is not set
    # CONFIG_NRFX_SPIS1 is not set
    # CONFIG_NRFX_SPIS2 is not set
    # CONFIG_NRFX_SPIS3 is not set
    # CONFIG_NRFX_SYSTICK is not set
    # CONFIG_NRFX_TIMER is not set
    # CONFIG_NRFX_TIMER0 is not set
    # CONFIG_NRFX_TIMER1 is not set
    # CONFIG_NRFX_TIMER2 is not set
    # CONFIG_NRFX_TWIM is not set
    # CONFIG_NRFX_TWIM0 is not set
    # CONFIG_NRFX_TWIM1 is not set
    # CONFIG_NRFX_TWIM2 is not set
    # CONFIG_NRFX_TWIM3 is not set
    # CONFIG_NRFX_TWIS is not set
    # CONFIG_NRFX_TWIS0 is not set
    # CONFIG_NRFX_TWIS1 is not set
    # CONFIG_NRFX_TWIS2 is not set
    # CONFIG_NRFX_TWIS3 is not set
    # CONFIG_NRFX_UARTE is not set
    # CONFIG_NRFX_UARTE0 is not set
    # CONFIG_NRFX_UARTE1 is not set
    # CONFIG_NRFX_UARTE2 is not set
    # CONFIG_NRFX_UARTE3 is not set
    # CONFIG_NRFX_USBD is not set
    # CONFIG_NRFX_USBREG is not set
    # CONFIG_NRFX_WDT is not set
    # CONFIG_NRFX_WDT0 is not set
    # CONFIG_NRFX_WDT1 is not set
    # CONFIG_NRFX_PRS is not set
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    # CONFIG_NRFX_PRS_BOX_2 is not set
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # end of nrfx drivers
    CONFIG_OPENAMP=y
    CONFIG_OPENAMP_SRC_PATH="open-amp"
    CONFIG_OPENAMP_MASTER=y
    CONFIG_OPENAMP_SLAVE=y
    # CONFIG_MIPI_SYST_LIB is not set
    CONFIG_NUM_PREEMPT_PRIORITIES=15
    CONFIG_ROM_START_OFFSET=0
    # CONFIG_TINYCBOR is not set
    CONFIG_TINYCRYPT=y
    # CONFIG_TINYCRYPT_CTR_PRNG is not set
    CONFIG_TINYCRYPT_SHA256=y
    CONFIG_TINYCRYPT_SHA256_HMAC=y
    CONFIG_TINYCRYPT_SHA256_HMAC_PRNG=y
    # CONFIG_TINYCRYPT_ECC_DH is not set
    # CONFIG_TINYCRYPT_ECC_DSA is not set
    CONFIG_TINYCRYPT_AES=y
    # CONFIG_TINYCRYPT_AES_CBC is not set
    # CONFIG_TINYCRYPT_AES_CTR is not set
    # CONFIG_TINYCRYPT_AES_CCM is not set
    CONFIG_TINYCRYPT_AES_CMAC=y
    # end of Modules
    # CONFIG_SPI is not set
    # CONFIG_I2C is not set
    # CONFIG_KSCAN is not set
    # CONFIG_WIFI is not set
    CONFIG_NET_CONFIG_IEEE802154_DEV_NAME=""
    # CONFIG_MODEM is not set
    CONFIG_GPIO_NRF_P1=y
    CONFIG_BT_HCI_ACL_FLOW_CONTROL=y
    CONFIG_BT_HCI_VS_EXT=y
    CONFIG_BOARD_DEPRECATED_RELEASE="v2.6.0"
    CONFIG_BOARD="nrf5340pdk_nrf5340_cpuapp"
    CONFIG_FLASH_LOAD_SIZE=0
    CONFIG_SRAM_SIZE=448
    CONFIG_FLASH_LOAD_OFFSET=0
    CONFIG_SOC="nRF5340_CPUAPP_QKAA"
    CONFIG_SOC_SERIES="nrf53"
    CONFIG_NUM_IRQS=69
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
    CONFIG_HEAP_MEM_POOL_SIZE=2048
    # CONFIG_WATCHDOG is not set
    # CONFIG_UART_NS16550 is not set
    CONFIG_GPIO=y
    CONFIG_SYS_POWER_MANAGEMENT=y
    # CONFIG_SYS_POWER_DEEP_SLEEP_STATES is not set
    CONFIG_HAS_SYS_POWER_STATE_DEEP_SLEEP_1=y
    # CONFIG_DEVICE_POWER_MANAGEMENT is not set
    CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    # CONFIG_CORTEX_M_SYSTICK is not set
    CONFIG_NRF5340_CPUAPP_ERRATUM19=y
    CONFIG_CLOCK_CONTROL=y
    CONFIG_NRF_RTC_TIMER=y
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
    CONFIG_BUILD_OUTPUT_HEX=y
    # CONFIG_FPU is not set
    CONFIG_FLASH_SIZE=1024
    CONFIG_FLASH_BASE_ADDRESS=0x0
    # CONFIG_GPIO_MCUX is not set
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    # CONFIG_UART_PL011 is not set
    # CONFIG_IPM_STM32_IPCC is not set
    CONFIG_BOARD_NRF5340PDK_NRF5340_CPUAPP=y
    # CONFIG_BOARD_NRF5340PDK_NRF5340_CPUAPPNS is not set
    # CONFIG_BOARD_NRF5340DK_NRF5340_CPUAPP is not set
    # CONFIG_BOARD_NRF5340DK_NRF5340_CPUAPPNS is not set
    # Board Options
    CONFIG_BOARD_ENABLE_DCDC_APP=y
    CONFIG_BOARD_ENABLE_DCDC_NET=y
    CONFIG_BOARD_ENABLE_DCDC_HV=y
    CONFIG_BT_HAS_HCI_VS=y
    CONFIG_BOARD_ENABLE_CPUNET=y
    CONFIG_DOMAIN_CPUNET_BOARD="nrf5340pdk_nrf5340_cpunet"
    # CONFIG_BT_CTLR is not set
    CONFIG_BT_ECC=y
    # end of Board Options
    # CONFIG_SOC_SERIES_BEETLE is not set
    # CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set
    # CONFIG_SOC_SERIES_MPS2 is not set
    # CONFIG_SOC_SERIES_MUSCA is not set
    # CONFIG_SOC_SERIES_MUSCA_B1 is not set
    # CONFIG_SOC_SERIES_SAMD20 is not set
    # CONFIG_SOC_SERIES_SAMD21 is not set
    # CONFIG_SOC_SERIES_SAMD51 is not set
    # CONFIG_SOC_SERIES_SAME51 is not set
    # CONFIG_SOC_SERIES_SAME53 is not set
    # CONFIG_SOC_SERIES_SAME54 is not set
    # CONFIG_SOC_SERIES_SAMR21 is not set
    # CONFIG_SOC_SERIES_SAM3X is not set
    # CONFIG_SOC_SERIES_SAM4E is not set
    # CONFIG_SOC_SERIES_SAM4L is not set
    # CONFIG_SOC_SERIES_SAM4S is not set
    # CONFIG_SOC_SERIES_SAME70 is not set
    # CONFIG_SOC_SERIES_SAMV71 is not set
    # CONFIG_SOC_SERIES_VALKYRIE is not set
    # CONFIG_SOC_SERIES_VIPER is not set
    # CONFIG_SOC_SERIES_PSOC62 is not set
    # CONFIG_SOC_SERIES_PSOC63 is not set
    # CONFIG_SOC_SERIES_XMC_4XXX is not set
    # CONFIG_SOC_SERIES_MEC1501X is not set
    # CONFIG_SOC_SERIES_MEC1701X is not set
    # CONFIG_SOC_SERIES_NRF51X is not set
    # CONFIG_SOC_SERIES_NRF52X is not set
    CONFIG_SOC_SERIES_NRF53X=y
    # CONFIG_SOC_SERIES_NRF91X is not set
    # CONFIG_SOC_SERIES_M48X is not set
    # CONFIG_SOC_SERIES_NPCX7 is not set
    # CONFIG_SOC_SERIES_IMX_6X_M4 is not set
    # CONFIG_SOC_SERIES_IMX7_M4 is not set
    # CONFIG_SOC_SERIES_IMX8MM_M4 is not set
    # CONFIG_SOC_SERIES_IMX_RT6XX is not set
    # CONFIG_SOC_SERIES_IMX_RT is not set
    # CONFIG_SOC_SERIES_KINETIS_K2X is not set
    # CONFIG_SOC_SERIES_KINETIS_K6X is not set
    # CONFIG_SOC_SERIES_KINETIS_K8X is not set
    # CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
    # CONFIG_SOC_SERIES_KINETIS_KL2X is not set
    # CONFIG_SOC_SERIES_KINETIS_KV5X is not set
    # CONFIG_SOC_SERIES_KINETIS_KWX is not set
    # CONFIG_SOC_SERIES_LPC11U6X is not set
    # CONFIG_SOC_SERIES_LPC54XXX is not set
    # CONFIG_SOC_SERIES_LPC55XXX is not set
    # CONFIG_SOC_QEMU_CORTEX_A53 is not set
    # CONFIG_SOC_EOS_S3 is not set
    # CONFIG_SOC_SERIES_EFM32GG11B is not set
    # CONFIG_SOC_SERIES_EFM32HG is not set
    # CONFIG_SOC_SERIES_EFM32JG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG12B is not set
    # CONFIG_SOC_SERIES_EFM32WG is not set
    # CONFIG_SOC_SERIES_EFR32BG13P is not set
    # CONFIG_SOC_SERIES_EFR32FG1P is not set
    # CONFIG_SOC_SERIES_EFR32MG12P is not set
    # CONFIG_SOC_SERIES_EFR32MG21 is not set
    # CONFIG_SOC_SERIES_STM32F0X is not set
    # CONFIG_SOC_SERIES_STM32F1X is not set
    # CONFIG_SOC_SERIES_STM32F2X is not set
    # CONFIG_SOC_SERIES_STM32F3X is not set
    # CONFIG_SOC_SERIES_STM32F4X is not set
    # CONFIG_SOC_SERIES_STM32F7X is not set
    # CONFIG_SOC_SERIES_STM32G0X is not set
    # CONFIG_SOC_SERIES_STM32G4X is not set
    # CONFIG_SOC_SERIES_STM32H7X is not set
    # CONFIG_SOC_SERIES_STM32L0X is not set
    # CONFIG_SOC_SERIES_STM32L1X is not set
    # CONFIG_SOC_SERIES_STM32L4X is not set
    # CONFIG_SOC_SERIES_STM32L5X is not set
    # CONFIG_SOC_SERIES_STM32MP1X is not set
    # CONFIG_SOC_SERIES_STM32WBX is not set
    # CONFIG_SOC_TI_LM3S6965 is not set
    # CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
    # CONFIG_SOC_SERIES_CC32XX is not set
    # CONFIG_SOC_SERIES_MSP432P4XX is not set
    # CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
    # Hardware Configuration
    CONFIG_CPU_HAS_ARM_MPU=y
    CONFIG_CPU_HAS_NRF_IDAU=y
    CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000
    CONFIG_SOC_FAMILY="nordic_nrf"
    CONFIG_SOC_FAMILY_NRF=y
    CONFIG_HAS_HW_NRF_CC312=y
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_DPPIC=y
    CONFIG_HAS_HW_NRF_EGU0=y
    CONFIG_HAS_HW_NRF_EGU1=y
    CONFIG_HAS_HW_NRF_EGU2=y
    CONFIG_HAS_HW_NRF_EGU3=y
    CONFIG_HAS_HW_NRF_EGU4=y
    CONFIG_HAS_HW_NRF_EGU5=y
    CONFIG_HAS_HW_NRF_GPIO0=y
    CONFIG_HAS_HW_NRF_GPIO1=y
    CONFIG_HAS_HW_NRF_GPIOTE=y
    CONFIG_HAS_HW_NRF_I2S=y
    CONFIG_HAS_HW_NRF_IPC=y
    CONFIG_HAS_HW_NRF_NFCT=y
    CONFIG_HAS_HW_NRF_NVMC_PE=y
    CONFIG_HAS_HW_NRF_PDM=y
    CONFIG_HAS_HW_NRF_POWER=y
    CONFIG_HAS_HW_NRF_PWM0=y
    CONFIG_HAS_HW_NRF_PWM1=y
    CONFIG_HAS_HW_NRF_PWM2=y
    CONFIG_HAS_HW_NRF_PWM3=y
    CONFIG_HAS_HW_NRF_QSPI=y
    CONFIG_HAS_HW_NRF_RTC0=y
    CONFIG_HAS_HW_NRF_RTC1=y
    CONFIG_HAS_HW_NRF_SAADC=y
    CONFIG_HAS_HW_NRF_SPIM0=y
    CONFIG_HAS_HW_NRF_SPIM1=y
    CONFIG_HAS_HW_NRF_SPIM2=y
    CONFIG_HAS_HW_NRF_SPIM3=y
    CONFIG_HAS_HW_NRF_SPIM4=y
    CONFIG_HAS_HW_NRF_SPIS0=y
    CONFIG_HAS_HW_NRF_SPIS1=y
    CONFIG_HAS_HW_NRF_SPIS2=y
    CONFIG_HAS_HW_NRF_SPIS3=y
    CONFIG_HAS_HW_NRF_SPU=y
    CONFIG_HAS_HW_NRF_TIMER0=y
    CONFIG_HAS_HW_NRF_TIMER1=y
    CONFIG_HAS_HW_NRF_TIMER2=y
    CONFIG_HAS_HW_NRF_TWIM0=y
    CONFIG_HAS_HW_NRF_TWIM1=y
    CONFIG_HAS_HW_NRF_TWIM2=y
    CONFIG_HAS_HW_NRF_TWIM3=y
    CONFIG_HAS_HW_NRF_TWIS0=y
    CONFIG_HAS_HW_NRF_TWIS1=y
    CONFIG_HAS_HW_NRF_TWIS2=y
    CONFIG_HAS_HW_NRF_TWIS3=y
    CONFIG_HAS_HW_NRF_UARTE0=y
    CONFIG_HAS_HW_NRF_UARTE1=y
    CONFIG_HAS_HW_NRF_UARTE2=y
    CONFIG_HAS_HW_NRF_UARTE3=y
    CONFIG_HAS_HW_NRF_USBD=y
    CONFIG_HAS_HW_NRF_USBREG=y
    CONFIG_HAS_HW_NRF_WDT0=y
    CONFIG_HAS_HW_NRF_WDT1=y
    # CONFIG_NFCT_PINS_AS_GPIOS is not set
    CONFIG_SOC_NRF5340_CPUAPP=y
    CONFIG_SOC_NRF5340_CPUAPP_QKAA=y
    # CONFIG_SOC_NRF5340_CPUNET_QKAA is not set
    CONFIG_SOC_DCDC_NRF53X_APP=y
    CONFIG_SOC_DCDC_NRF53X_NET=y
    CONFIG_SOC_DCDC_NRF53X_HV=y
    CONFIG_SOC_ENABLE_LFXO=y
    CONFIG_NRF_ENABLE_CACHE=y
    # CONFIG_SOC_LOG_LEVEL_OFF is not set
    # CONFIG_SOC_LOG_LEVEL_ERR is not set
    # CONFIG_SOC_LOG_LEVEL_WRN is not set
    CONFIG_SOC_LOG_LEVEL_INF=y
    # CONFIG_SOC_LOG_LEVEL_DBG is not set
    CONFIG_SOC_LOG_LEVEL=3
    # end of Hardware Configuration
    CONFIG_SOC_COMPATIBLE_NRF=y
    # ARM Options
    CONFIG_ARCH="arm"
    CONFIG_CPU_CORTEX=y
    CONFIG_CPU_CORTEX_M=y
    CONFIG_ISA_THUMB2=y
    CONFIG_ASSEMBLER_ISA_THUMB2=y
    CONFIG_COMPILER_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    CONFIG_PLATFORM_SPECIFIC_INIT=y
    CONFIG_FAULT_DUMP=2
    CONFIG_BUILTIN_STACK_GUARD=y
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_CPU_CORTEX_M33=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_DWT=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_CPU_CORTEX_M_HAS_CMSE=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_SE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    CONFIG_ARMV8_M_DSP=y
    # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
    CONFIG_GEN_ISR_TABLES=y
    # CONFIG_ZERO_LATENCY_IRQS is not set
    # CONFIG_SW_VECTOR_RELAY is not set
    # CONFIG_CORTEX_M_DWT is not set
    # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
    CONFIG_ARM_MPU=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    # CONFIG_MPU_STACK_GUARD is not set
    # CONFIG_MPU_ALLOW_FLASH_WRITE is not set
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    CONFIG_ARM_TRUSTZONE_M=y
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    CONFIG_IDLE_STACK_SIZE=320
    CONFIG_ISR_STACK_SIZE=2048
    CONFIG_TEST_EXTRA_STACKSIZE=0
    # end of ARM Options
    CONFIG_ARM=y
    CONFIG_ARCH_IS_SET=y
    # General Architecture Options
    # CONFIG_ARCH_LOG_LEVEL_OFF is not set
    # CONFIG_ARCH_LOG_LEVEL_ERR is not set
    # CONFIG_ARCH_LOG_LEVEL_WRN is not set
    CONFIG_ARCH_LOG_LEVEL_INF=y
    # CONFIG_ARCH_LOG_LEVEL_DBG is not set
    CONFIG_ARCH_LOG_LEVEL=3
    # CONFIG_MPU_LOG_LEVEL_OFF is not set
    # CONFIG_MPU_LOG_LEVEL_ERR is not set
    # CONFIG_MPU_LOG_LEVEL_WRN is not set
    CONFIG_MPU_LOG_LEVEL_INF=y
    # CONFIG_MPU_LOG_LEVEL_DBG is not set
    CONFIG_MPU_LOG_LEVEL=3
    CONFIG_SRAM_BASE_ADDRESS=0x20000000
    # CONFIG_TRUSTED_EXECUTION_SECURE is not set
    # CONFIG_TRUSTED_EXECUTION_NONSECURE is not set
    CONFIG_HW_STACK_PROTECTION=y
    # CONFIG_USERSPACE is not set
    CONFIG_KOBJECT_TEXT_AREA=256
    CONFIG_GEN_PRIV_STACKS=y
    # CONFIG_STACK_GROWS_UP is not set
    # Interrupt Configuration
    # CONFIG_DYNAMIC_INTERRUPTS is not set
    CONFIG_GEN_SW_ISR_TABLE=y
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=0
    CONFIG_GEN_IRQ_START_VECTOR=0
    # CONFIG_EXTRA_EXCEPTION_INFO is not set
    # end of Interrupt Configuration
    # CONFIG_INIT_ARCH_HW_AT_BOOT is not set
    # end of General Architecture Options
    CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_SUPPORTS_COREDUMP=y
    CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
    CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_CPU_HAS_TEE=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_MEMORY_PROTECTION=y
    CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
    CONFIG_MPU_GAP_FILLING=y
    # Floating Point Options
    # end of Floating Point Options
    # General Kernel Options
    # CONFIG_KERNEL_LOG_LEVEL_OFF is not set
    # CONFIG_KERNEL_LOG_LEVEL_ERR is not set
    # CONFIG_KERNEL_LOG_LEVEL_WRN is not set
    CONFIG_KERNEL_LOG_LEVEL_INF=y
    # CONFIG_KERNEL_LOG_LEVEL_DBG is not set
    CONFIG_KERNEL_LOG_LEVEL=3
    CONFIG_MULTITHREADING=y
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_MAIN_THREAD_PRIORITY=0
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=0
    CONFIG_NUM_METAIRQ_PRIORITIES=0
    # CONFIG_SCHED_DEADLINE is not set
    # CONFIG_SCHED_CPU_MASK is not set
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    CONFIG_ERRNO=y
    CONFIG_SCHED_DUMB=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_DUMB=y
    # Kernel Debugging and Metrics
    # CONFIG_INIT_STACKS is not set
    CONFIG_BOOT_BANNER=y
    CONFIG_BOOT_DELAY=0
    # CONFIG_THREAD_MONITOR is not set
    # CONFIG_THREAD_NAME is not set
    # CONFIG_THREAD_RUNTIME_STATS is not set
    # end of Kernel Debugging and Metrics
    # Work Queue Options
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    # end of Work Queue Options
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    CONFIG_TIMESLICING=y
    CONFIG_TIMESLICE_SIZE=0
    CONFIG_TIMESLICE_PRIORITY=0
    CONFIG_POLL=y
    # end of Timer API Options
    # Other Kernel Object Options
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    CONFIG_NUM_PIPE_ASYNC_MSGS=10
    CONFIG_KERNEL_MEM_POOL=y
    CONFIG_MEM_POOL_HEAP_BACKEND=y
    CONFIG_HEAP_MEM_POOL_MIN_SIZE=64
    # end of Other Kernel Object Options
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_SYS_CLOCK_EXISTS=y
    # CONFIG_LEGACY_TIMEOUT_API is not set
    CONFIG_TIMEOUT_64BIT=y
    CONFIG_XIP=y
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Security Options
    # end of Security Options
    # SMP Options
    CONFIG_MP_NUM_CPUS=1
    # CONFIG_KERNEL_COHERENCE is not set
    # end of SMP Options
    CONFIG_TICKLESS_IDLE=y
    CONFIG_TICKLESS_IDLE_THRESH=3
    CONFIG_TICKLESS_KERNEL=y
    # end of General Kernel Options
    CONFIG_HAS_DTS=y
    CONFIG_HAS_DTS_GPIO=y
    # Device Drivers
    # Bluetooth Drivers
    # Bluetooth HCI Driver Options
    # CONFIG_BT_H4 is not set
    # CONFIG_BT_H5 is not set
    CONFIG_BT_RPMSG=y
    # CONFIG_BT_STM32_IPM is not set
    # CONFIG_BT_NO_DRIVER is not set
    CONFIG_BT_RPMSG_NRF53=y
    CONFIG_BT_RPMSG_NRF53_RX_STACK_SIZE=1024
    CONFIG_BT_RPMSG_NRF53_RX_PRIO=8
    CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE=y
    # end of Bluetooth Drivers
    # CONFIG_IEEE802154 is not set
    # CONFIG_LORA is not set
    CONFIG_UART_CONSOLE_ON_DEV_NAME="UART_0"
    CONFIG_CONSOLE=y
    CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
    CONFIG_CONSOLE_HAS_DRIVER=y
    CONFIG_CONSOLE_HANDLER=y
    CONFIG_UART_CONSOLE=y
    CONFIG_UART_CONSOLE_INIT_PRIORITY=60
    CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS=y
    # CONFIG_UART_CONSOLE_MCUMGR is not set
    # CONFIG_USB_UART_CONSOLE is not set
    # CONFIG_RAM_CONSOLE is not set
    # CONFIG_IPM_CONSOLE_SENDER is not set
    # CONFIG_IPM_CONSOLE_RECEIVER is not set
    # CONFIG_IPM_CONSOLE is not set
    # CONFIG_UART_PIPE is not set
    # CONFIG_UART_MCUMGR is not set
    # CONFIG_SEMIHOST_CONSOLE is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL_INF=y
    # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL=3
    # CONFIG_GSM_MUX is not set
    CONFIG_UART_MUX_RX_STACK_SIZE=512
    CONFIG_UART_MUX_RX_PRIORITY=7
    # CONFIG_UART_MUX_LOG_LEVEL_OFF is not set
    # CONFIG_UART_MUX_LOG_LEVEL_ERR is not set
    # CONFIG_UART_MUX_LOG_LEVEL_WRN is not set
    CONFIG_UART_MUX_LOG_LEVEL_INF=y
    # CONFIG_UART_MUX_LOG_LEVEL_DBG is not set
    CONFIG_UART_MUX_LOG_LEVEL=3
    CONFIG_HAS_SEGGER_RTT=y
    # CONFIG_USE_SEGGER_RTT is not set
    # CONFIG_EC_HOST_CMD_PERIPH is not set
    # CONFIG_NET_LOOPBACK is not set
    CONFIG_SERIAL=y
    # Capabilities
    CONFIG_SERIAL_HAS_DRIVER=y
    CONFIG_SERIAL_SUPPORT_ASYNC=y
    CONFIG_SERIAL_SUPPORT_INTERRUPT=y
    # CONFIG_UART_ASYNC_API is not set
    # CONFIG_UART_LINE_CTRL is not set
    # CONFIG_UART_DRV_CMD is not set
    # Serial Drivers
    CONFIG_UART_NRFX=y
    CONFIG_UART_0_NRF_UARTE=y
    CONFIG_UART_0_ENHANCED_POLL_OUT=y
    CONFIG_UART_0_INTERRUPT_DRIVEN=y
    # CONFIG_UART_0_NRF_PARITY_BIT is not set
    CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
    CONFIG_NRF_UARTE_PERIPHERAL=y
    # CONFIG_UART_ALTERA_JTAG is not set
    # CONFIG_UART_XLNX_UARTLITE is not set
    # Interrupt Controllers
    # CONFIG_SWERV_PIC is not set
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    # end of Interrupt Controllers
    # Timer Drivers
    # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    CONFIG_SYSTEM_CLOCK_DISABLE=y
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    # end of Timer Drivers
    # CONFIG_ENTROPY_GENERATOR is not set
    # CONFIG_PCIE is not set
    # CONFIG_PCIE_ENDPOINT is not set
    # CONFIG_GPIO_LOG_LEVEL_OFF is not set
    # CONFIG_GPIO_LOG_LEVEL_ERR is not set
    # CONFIG_GPIO_LOG_LEVEL_WRN is not set
    CONFIG_GPIO_LOG_LEVEL_INF=y
    # CONFIG_GPIO_LOG_LEVEL_DBG is not set
    CONFIG_GPIO_LOG_LEVEL=3
    # CONFIG_GPIO_DW is not set
    CONFIG_GPIO_NRFX=y
    CONFIG_GPIO_NRF_INIT_PRIORITY=40
    CONFIG_GPIO_NRF_P0=y
    # CONFIG_GPIO_INTEL_APL is not set
    # CONFIG_GPIO_XLNX_AXI is not set
    # CONFIG_SHARED_IRQ is not set
    # CONFIG_I2S is not set
    # CONFIG_PWM is not set
    # CONFIG_PINMUX is not set
    # CONFIG_ADC is not set
    # CONFIG_DAC is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF=y
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
    CONFIG_CLOCK_CONTROL_NRF=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM=y
    CONFIG_CLOCK_CONTROL_NRF_ACCURACY=20
    # CONFIG_PTP_CLOCK is not set
    CONFIG_IPM=y
    # CONFIG_IPM_MHU is not set
    CONFIG_IPM_NRFX=y
    # CONFIG_IPM_NRF_SINGLE_INSTANCE is not set
    # IPM Message Channel [0] configuration
    CONFIG_IPM_MSG_CH_0_ENABLE=y
    # CONFIG_IPM_MSG_CH_0_RX is not set
    CONFIG_IPM_MSG_CH_0_TX=y
    # end of IPM Message Channel [0] configuration
    # IPM Message Channel [1] configuration
    CONFIG_IPM_MSG_CH_1_ENABLE=y
    CONFIG_IPM_MSG_CH_1_RX=y
    # CONFIG_IPM_MSG_CH_1_TX is not set
    # end of IPM Message Channel [1] configuration
    # IPM Message Channel [2] configuration
    # CONFIG_IPM_MSG_CH_2_ENABLE is not set
    # end of IPM Message Channel [2] configuration
    # IPM Message Channel [3] configuration
    # CONFIG_IPM_MSG_CH_3_ENABLE is not set
    # end of IPM Message Channel [3] configuration
    # IPM Message Channel [4] configuration
    # CONFIG_IPM_MSG_CH_4_ENABLE is not set
    # end of IPM Message Channel [4] configuration
    # IPM Message Channel [5] configuration
    # CONFIG_IPM_MSG_CH_5_ENABLE is not set
    # end of IPM Message Channel [5] configuration
    # IPM Message Channel [6] configuration
    # CONFIG_IPM_MSG_CH_6_ENABLE is not set
    # end of IPM Message Channel [6] configuration
    # IPM Message Channel [7] configuration
    # CONFIG_IPM_MSG_CH_7_ENABLE is not set
    # end of IPM Message Channel [7] configuration
    # IPM Message Channel [8] configuration
    # CONFIG_IPM_MSG_CH_8_ENABLE is not set
    # end of IPM Message Channel [8] configuration
    # IPM Message Channel [9] configuration
    # CONFIG_IPM_MSG_CH_9_ENABLE is not set
    # end of IPM Message Channel [9] configuration
    # IPM Message Channel [10] configuration
    # CONFIG_IPM_MSG_CH_10_ENABLE is not set
    # end of IPM Message Channel [10] configuration
    # IPM Message Channel [11] configuration
    # CONFIG_IPM_MSG_CH_11_ENABLE is not set
    # end of IPM Message Channel [11] configuration
    # IPM Message Channel [12] configuration
    # CONFIG_IPM_MSG_CH_12_ENABLE is not set
    # end of IPM Message Channel [12] configuration
    # IPM Message Channel [13] configuration
    # CONFIG_IPM_MSG_CH_13_ENABLE is not set
    # end of IPM Message Channel [13] configuration
    # IPM Message Channel [14] configuration
    # CONFIG_IPM_MSG_CH_14_ENABLE is not set
    # end of IPM Message Channel [14] configuration
    # IPM Message Channel [15] configuration
    # CONFIG_IPM_MSG_CH_15_ENABLE is not set
    # end of IPM Message Channel [15] configuration
    # CONFIG_IPM_INTEL_ADSP is not set
    # CONFIG_IPM_LOG_LEVEL_OFF is not set
    # CONFIG_IPM_LOG_LEVEL_ERR is not set
    # CONFIG_IPM_LOG_LEVEL_WRN is not set
    CONFIG_IPM_LOG_LEVEL_INF=y
    # CONFIG_IPM_LOG_LEVEL_DBG is not set
    CONFIG_IPM_LOG_LEVEL=3
    # CONFIG_FLASH is not set
    # CONFIG_COUNTER is not set
    # CONFIG_DMA is not set
    # CONFIG_USB is not set
    # CONFIG_CRYPTO is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_LED_STRIP is not set
    # CONFIG_LED is not set
    # CONFIG_CAN is not set
    # CONFIG_AUDIO is not set
    # CONFIG_NEURAL_NET_ACCEL is not set
    # CONFIG_HWINFO is not set
    # CONFIG_ESPI is not set
    # CONFIG_PS2 is not set
    # CONFIG_VIDEO is not set
    # CONFIG_EEPROM is not set
    # CONFIG_PECI is not set
    # CONFIG_PECI_INTERRUPT_DRIVEN is not set
    # CONFIG_REGULATOR is not set
    # C Library
    CONFIG_MINIMAL_LIBC=y
    # CONFIG_NEWLIB_LIBC is not set
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_HAS_NEWLIB_LIBC_NANO=y
    CONFIG_MINIMAL_LIBC_MALLOC=y
    CONFIG_MINIMAL_LIBC_MALLOC_ARENA_SIZE=0
    CONFIG_MINIMAL_LIBC_CALLOC=y
    CONFIG_MINIMAL_LIBC_REALLOCARRAY=y
    # CONFIG_MINIMAL_LIBC_LL_PRINTF is not set
    CONFIG_STDOUT_CONSOLE=y
    # end of C Library
    # Additional libraries
    # CONFIG_FNMATCH is not set
    # CONFIG_LVGL is not set
    # OS Support Library
    # CONFIG_JSON_LIBRARY is not set
    # CONFIG_RING_BUFFER is not set
    # CONFIG_BASE64 is not set
    # CONFIG_SYS_HEAP_VALIDATE is not set
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    # CONFIG_PRINTK64 is not set
    # CONFIG_PRINTK_SYNC is not set
    CONFIG_CBPRINTF_COMPLETE=y
    # CONFIG_CBPRINTF_NANO is not set
    CONFIG_CBPRINTF_FULL_INTEGRAL=y
    # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
    # CONFIG_CBPRINTF_FP_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_ALWAYS_A is not set
    CONFIG_CBPRINTF_N_SPECIFIER=y
    # CONFIG_CBPRINTF_LIBC_SUBSTS is not set
    # end of OS Support Library
    CONFIG_POSIX_MAX_FDS=4
    # CONFIG_POSIX_API is not set
    # CONFIG_PTHREAD_IPC is not set
    # CONFIG_POSIX_CLOCK is not set
    CONFIG_MAX_TIMER_COUNT=5
    # CONFIG_POSIX_MQUEUE is not set
    # CONFIG_EVENTFD is not set
    # CONFIG_OPENAMP_RSC_TABLE is not set
    # end of Additional libraries
    # Sub Systems and OS Services
    CONFIG_BT=y
    # CONFIG_BT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_LOG_LEVEL_WRN is not set
    CONFIG_BT_LOG_LEVEL_INF=y
    # CONFIG_BT_LOG_LEVEL_DBG is not set
    CONFIG_BT_LOG_LEVEL=3
    CONFIG_BT_HCI=y
    # CONFIG_BT_CUSTOM is not set
    # CONFIG_BT_HCI_RAW is not set
    # CONFIG_BT_HCI_RAW_H4 is not set
    # CONFIG_BT_HCI_RAW_CMD_EXT is not set
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_CENTRAL=y
    CONFIG_BT_BROADCASTER=y
    # CONFIG_BT_EXT_ADV is not set
    CONFIG_BT_OBSERVER=y
    # GATT Services
    # CONFIG_BT_DIS is not set
    # CONFIG_BT_BAS is not set
    # CONFIG_BT_HRS is not set
    # CONFIG_BT_OTS is not set
    # end of GATT Services
    CONFIG_BT_CONN=y
    # CONFIG_BT_REMOTE_VERSION is not set
    CONFIG_BT_PHY_UPDATE=y
    CONFIG_BT_DATA_LEN_UPDATE=y
    CONFIG_BT_HCI_VS=y
    # CONFIG_BT_HCI_VS_EXT_DETECT is not set
    # CONFIG_BT_HCI_MESH_EXT is not set
    # CONFIG_BT_WAIT_NOP is not set
    CONFIG_BT_RPA=y
    CONFIG_BT_ASSERT=y
    CONFIG_BT_ASSERT_VERBOSE=y
    # CONFIG_BT_ASSERT_PANIC is not set
    CONFIG_BT_DEBUG=y
    # CONFIG_BT_DEBUG_NONE is not set
    CONFIG_BT_DEBUG_LOG=y
    # CONFIG_BT_DEBUG_MONITOR is not set
    # CONFIG_BT_DEBUG_HCI_DRIVER is not set
    # CONFIG_BT_DEBUG_RPA is not set
    # Host Stack Configuration
    CONFIG_BT_HCI_HOST=y
    CONFIG_BT_HCI_CMD_COUNT=2
    CONFIG_BT_RX_BUF_COUNT=10
    CONFIG_BT_DISCARDABLE_BUF_COUNT=3
    CONFIG_BT_DISCARDABLE_BUF_SIZE=45
    # CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
    CONFIG_BT_HCI_ECC_STACK_SIZE=1100
    CONFIG_BT_HCI_TX_PRIO=7
    CONFIG_BT_HCI_RESERVE=1
    CONFIG_BT_RX_PRIO=8
    CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
    # CONFIG_BT_AUDIO is not set
    CONFIG_BT_HOST_CRYPTO=y
    # CONFIG_BT_WHITELIST is not set
    CONFIG_BT_ACL_RX_COUNT=6
    CONFIG_BT_CONN_TX_MAX=10
    # CONFIG_BT_USER_PHY_UPDATE is not set
    CONFIG_BT_AUTO_PHY_UPDATE=y
    # CONFIG_BT_USER_DATA_LEN_UPDATE is not set
    CONFIG_BT_AUTO_DATA_LEN_UPDATE=y
    # CONFIG_BT_REMOTE_INFO is not set
    CONFIG_BT_SMP=y
    # CONFIG_BT_PRIVACY is not set
    # CONFIG_BT_SIGNING is not set
    # CONFIG_BT_SMP_APP_PAIRING_ACCEPT is not set
    # CONFIG_BT_SMP_SC_PAIR_ONLY is not set
    # CONFIG_BT_SMP_SC_ONLY is not set
    # CONFIG_BT_SMP_OOB_LEGACY_PAIR_ONLY is not set
    # CONFIG_BT_SMP_DISABLE_LEGACY_JW_PASSKEY is not set
    # CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE is not set
    # CONFIG_BT_FIXED_PASSKEY is not set
    CONFIG_BT_BONDABLE=y
    # CONFIG_BT_BONDING_REQUIRED is not set
    # CONFIG_BT_STORE_DEBUG_KEYS is not set
    CONFIG_BT_SMP_ENFORCE_MITM=y
    # CONFIG_BT_KEYS_OVERWRITE_OLDEST is not set
    # L2CAP Options
    CONFIG_BT_L2CAP_RX_MTU=247
    CONFIG_BT_L2CAP_TX_BUF_COUNT=10
    CONFIG_BT_L2CAP_TX_FRAG_COUNT=2
    CONFIG_BT_L2CAP_TX_MTU=247
    CONFIG_BT_L2CAP_DYNAMIC_CHANNEL=y
    # CONFIG_BT_L2CAP_ECRED is not set
    # CONFIG_BT_DEBUG_L2CAP is not set
    # end of L2CAP Options
    # ATT and GATT Options
    CONFIG_BT_ATT_ENFORCE_FLOW=y
    CONFIG_BT_ATT_PREPARE_COUNT=2
    CONFIG_BT_ATT_TX_MAX=10
    CONFIG_BT_GATT_SERVICE_CHANGED=y
    # CONFIG_BT_GATT_DYNAMIC_DB is not set
    CONFIG_BT_GATT_CACHING=y
    # CONFIG_BT_GATT_NOTIFY_MULTIPLE is not set
    # CONFIG_BT_GATT_ENFORCE_CHANGE_UNAWARE is not set
    CONFIG_BT_GATT_CLIENT=y
    CONFIG_BT_GATT_READ_MULTIPLE=y
    # CONFIG_BT_GATT_AUTO_DISCOVER_CCC is not set
    CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y
    CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=y
    CONFIG_BT_PERIPHERAL_PREF_MIN_INT=24
    CONFIG_BT_PERIPHERAL_PREF_MAX_INT=40
    CONFIG_BT_PERIPHERAL_PREF_SLAVE_LATENCY=0
    CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=42
    # CONFIG_BT_DEBUG_ATT is not set
    # CONFIG_BT_DEBUG_GATT is not set
    # end of ATT and GATT Options
    CONFIG_BT_MAX_PAIRED=1
    CONFIG_BT_CREATE_CONN_TIMEOUT=3
    CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=5000
    CONFIG_BT_BACKGROUND_SCAN_INTERVAL=2048
    CONFIG_BT_BACKGROUND_SCAN_WINDOW=18
    # CONFIG_BT_SCAN_WITH_IDENTITY is not set
    # CONFIG_BT_DEVICE_NAME_DYNAMIC is not set
    CONFIG_BT_DEVICE_NAME="Nordic_Throughput"
    CONFIG_BT_DEVICE_APPEARANCE=0
    CONFIG_BT_ID_MAX=1
    # CONFIG_BT_TINYCRYPT_ECC is not set
    # CONFIG_BT_HOST_CCM is not set
    # CONFIG_BT_DEBUG_HCI_CORE is not set
    # CONFIG_BT_DEBUG_CONN is not set
    # CONFIG_BT_DEBUG_KEYS is not set
    # CONFIG_BT_DEBUG_SMP is not set
    # CONFIG_BT_DEBUG_SERVICE is not set
    # CONFIG_BT_TESTING is not set
    # CONFIG_BT_BREDR is not set
    # CONFIG_BT_HCI_VS_EVT_USER is not set
    # BLE Controller support
    # CONFIG_BT_CTLR_DEBUG_PINS_CPUAPP is not set
    # CONFIG_BT_SHELL is not set
    CONFIG_BT_COMPANY_ID=0x05F1
    # CONFIG_BT_MESH is not set
    # Controller Area Network (CAN) bus subsystem
    # CONFIG_ISOTP is not set
    # end of Controller Area Network (CAN) bus subsystem
    CONFIG_CONSOLE_SUBSYS=y
    CONFIG_CONSOLE_GETCHAR=y
    # CONFIG_CONSOLE_GETLINE is not set
    CONFIG_CONSOLE_GETCHAR_BUFSIZE=16
    CONFIG_CONSOLE_PUTCHAR_BUFSIZE=16
    # CONFIG_CPLUSPLUS is not set
    # System Monitoring Options
    # CONFIG_BOOT_TIME_MEASUREMENT is not set
    # CONFIG_THREAD_ANALYZER is not set
    # end of System Monitoring Options
    # Debugging Options
    # CONFIG_DEBUG is not set
    # CONFIG_STACK_USAGE is not set
    # CONFIG_STACK_SENTINEL is not set
    CONFIG_PRINTK=y
    CONFIG_EARLY_CONSOLE=y
    # CONFIG_ASSERT is not set
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    # CONFIG_ASSERT_NO_COND_INFO is not set
    # CONFIG_ASSERT_NO_MSG_INFO is not set
    # CONFIG_OBJECT_TRACING is not set
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    # CONFIG_DEBUG_INFO is not set
    # CONFIG_OPENOCD_SUPPORT is not set
    # CONFIG_DEBUG_COREDUMP is not set
    # end of Debugging Options
    # CONFIG_DISK_ACCESS is not set
    # CONFIG_EMUL is not set
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # File Systems
    # CONFIG_FILE_SYSTEM is not set
    # CONFIG_NVS is not set
    # end of File Systems
    # CONFIG_JWT is not set
    CONFIG_LOG=y
    # CONFIG_LOG_MINIMAL is not set
    # CONFIG_LOG_RUNTIME_FILTERING is not set
    CONFIG_LOG_OVERRIDE_LEVEL=0
    CONFIG_LOG_MAX_LEVEL=4
    # CONFIG_LOG_MIPI_SYST_ENABLE is not set
    # Prepend non-hexdump log message with function name
    # CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
    CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
    # end of Prepend non-hexdump log message with function name
    # CONFIG_LOG_PRINTK is not set
    # CONFIG_LOG_IMMEDIATE is not set
    # CONFIG_LOG_ENABLE_FANCY_OUTPUT_FORMATTING is not set
    CONFIG_LOG_MODE_OVERFLOW=y
    # CONFIG_LOG_MODE_NO_OVERFLOW is not set
    # CONFIG_LOG_BLOCK_IN_THREAD is not set
    CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10
    CONFIG_LOG_PROCESS_THREAD=y
    CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000
    CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=768
    CONFIG_LOG_BUFFER_SIZE=1024
    CONFIG_LOG_DETECT_MISSED_STRDUP=y
    CONFIG_LOG_STRDUP_MAX_STRING=32
    CONFIG_LOG_STRDUP_BUF_COUNT=4
    # CONFIG_LOG_STRDUP_POOL_PROFILING is not set
    CONFIG_LOG_DOMAIN_ID=0
    # CONFIG_LOG_FRONTEND is not set
    CONFIG_LOG_BACKEND_UART=y
    CONFIG_LOG_BACKEND_SHOW_COLOR=y
    CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
    # Device Management
    # Host command handler subsystem
    # CONFIG_EC_HOST_CMD is not set
    # end of Host command handler subsystem
    # CONFIG_MCUMGR is not set
    # CONFIG_HAWKBIT is not set
    # CONFIG_HAWKBIT_LOG_LEVEL_OFF is not set
    # CONFIG_HAWKBIT_LOG_LEVEL_ERR is not set
    # CONFIG_HAWKBIT_LOG_LEVEL_WRN is not set
    CONFIG_HAWKBIT_LOG_LEVEL_INF=y
    # CONFIG_HAWKBIT_LOG_LEVEL_DBG is not set
    CONFIG_HAWKBIT_LOG_LEVEL=3
    # CONFIG_UPDATEHUB is not set
    # CONFIG_UPDATEHUB_LOG_LEVEL_OFF is not set
    # CONFIG_UPDATEHUB_LOG_LEVEL_ERR is not set
    # CONFIG_UPDATEHUB_LOG_LEVEL_WRN is not set
    CONFIG_UPDATEHUB_LOG_LEVEL_INF=y
    # CONFIG_UPDATEHUB_LOG_LEVEL_DBG is not set
    CONFIG_UPDATEHUB_LOG_LEVEL=3
    # CONFIG_OSDP is not set
    # end of Device Management
    # Networking
    CONFIG_NET_BUF=y
    CONFIG_NET_BUF_USER_DATA_SIZE=4
    # CONFIG_NET_BUF_LOG is not set
    # CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
    # CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
    CONFIG_NET_BUF_LOG_LEVEL_INF=y
    # CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
    CONFIG_NET_BUF_LOG_LEVEL=3
    # CONFIG_NET_BUF_POOL_USAGE is not set
    # CONFIG_NETWORKING is not set
    # end of Networking
    # Power Management
    # CONFIG_SYS_PM_STATE_LOCK is not set
    # CONFIG_SYS_PM_DIRECT_FORCE_MODE is not set
    # CONFIG_SYS_PM_DEBUG is not set
    CONFIG_SYS_PM_POLICY_RESIDENCY=y
    # CONFIG_SYS_PM_POLICY_DUMMY is not set
    # CONFIG_SYS_PM_POLICY_APP is not set
    CONFIG_SYS_PM_POLICY_RESIDENCY_DEFAULT=y
    CONFIG_SYS_PM_MIN_RESIDENCY_DEEP_SLEEP_1=60000
    # CONFIG_SYS_PM_LOG_LEVEL_OFF is not set
    # CONFIG_SYS_PM_LOG_LEVEL_ERR is not set
    # CONFIG_SYS_PM_LOG_LEVEL_WRN is not set
    CONFIG_SYS_PM_LOG_LEVEL_INF=y
    # CONFIG_SYS_PM_LOG_LEVEL_DBG is not set
    CONFIG_SYS_PM_LOG_LEVEL=3
    # end of Power Management
    # CONFIG_SHELL is not set
    # CONFIG_STATS is not set
    # CONFIG_IMG_MANAGER is not set
    # Random Number Generators
    # CONFIG_TEST_RANDOM_GENERATOR is not set
    # end of Random Number Generators
    # Storage
    # CONFIG_STREAM_FLASH is not set
    # end of Storage
    # CONFIG_SETTINGS is not set
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_TEST is not set
    # CONFIG_TEST_USERSPACE is not set
    CONFIG_TEST_ARM_CORTEX_M=y
    # end of Testing
    # CONFIG_TIMING_FUNCTIONS is not set
    # CONFIG_TRACING is not set
    # end of Sub Systems and OS Services
    CONFIG_TOOLCHAIN_GNUARMEMB=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    # CONFIG_CODE_DATA_RELOCATION is not set
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    # CONFIG_USE_DT_CODE_PARTITION is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    CONFIG_KERNEL_ENTRY="__start"
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    # end of Linker Options
    # Compiler Options
    # CONFIG_CODING_GUIDELINE_CHECK is not set
    # CONFIG_NATIVE_APPLICATION is not set
    CONFIG_SIZE_OPTIMIZATIONS=y
    # CONFIG_SPEED_OPTIMIZATIONS is not set
    # CONFIG_DEBUG_OPTIMIZATIONS is not set
    # CONFIG_NO_OPTIMIZATIONS is not set
    CONFIG_COMPILER_OPT=""
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    # CONFIG_NO_RUNTIME_CHECKS is not set
    CONFIG_RUNTIME_ERROR_CHECKS=y
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    CONFIG_OUTPUT_DISASSEMBLY=y
    # CONFIG_OUTPUT_DISASSEMBLE_ALL is not set
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
    # CONFIG_BUILD_NO_GAP_FILL is not set
    CONFIG_BUILD_OUTPUT_BIN=y
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19 is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    # CONFIG_DEPRECATED_ZEPHYR_INT_TYPES is not set
    # end of Build Options
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    # CONFIG_BOOTLOADER_MCUBOOT is not set
    CONFIG_REBOOT=y
    # CONFIG_MISRA_SANE is not set
    # end of Boot Options
    # Compatibility
    CONFIG_COMPAT_INCLUDES=y
    # end of Compatibility
    Thank you,
    Florin.
  • Hi Florin
    Doesn't seem to be any major differences there, except for the change in board.
    Are you able to capture a sniffer trace when connecting the two boards and running the test?
    (no point capturing the whole test transaction, just the first couple of seconds)
    That should show more clearly why the transmission is so slow.
    If you don't have a dedicated, professional BLE sniffer we provide a free option that can be run on a standard Nordic devkit: https://www.nordicsemi.com/Software-and-tools/Development-Tools/nRF-Sniffer-for-Bluetooth-LE
    Also, I would recommend getting some new nRF5340 DK's if possible, so that you can continue development on up to date parts.
    Best regards
    Torbjørn
