e-paper display with spi. (hardware pins - digital write -baud-rate)
Sorry if it will be long. thanks for the help.
Using nrf9160 dk. The first thing I want to ask is about is the pins. I want to make sure I am using the correct pin. I think most of the pins can be used for digital I/O so that leave the sck,MISO.MOSI.
#define sck_pin   13     //p.13
#define sda_pin   12     //p.12   MISO
#define cs_pin    11     //p.11   MOSI
#define dc_pin    21     //       digital pin pwd
#define reset_pin 22     //       digital pin pwd
#define busy_pin  23     //       digital pin pwd
#define pnlon_pin 24     //       digital pin pwd
#define bs_pin    25     //       digital pin pwd
#define css_pin   26     //       digital pin pwd
The second thing is that I am trying to digital write to pin high/low. similar to the Arduino digital write(). So I looked and found  nrf_gpio_pin_write ( uint32_t pin_number, uint32_t value ) OR  should use gpio_pin_write(struct device *port, gpio_pin_t pin, u32_t value)
Also to set-up a pin to output/input  GPIO_INPUT /  GPIO_OUTPUT can be used right.
Last question to begin the serial link I couldn't find anything about that except for spi_cfg.frequency = 115200;  but that doesn't work.
I looked also into the blinky example and devicetree still confused.
