nRF52833 SAADC with Channel Scanning Settling Time
Hello Nordic Team,
i'm trying to configure the nRF52833 DK to scan through two channels at a high rate (10ksps) with the SAADC module.  i have configured the time to operate at 100us and I am seeing what looks like settling time with the internal mux.  for reference i used the following configuration in the ADC:
void saadc_init(void)
    ret_code_t err_code;
    //nrf_saadc_channel_config_t channel_config =
    //    NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
    nrf_drv_saadc_config_t saadc_config;
    nrf_saadc_channel_config_t channel_config;
    saadc_config.low_power_mode = true;
    saadc_config.resolution = NRF_SAADC_RESOLUTION_12BIT;
    saadc_config.oversample = NRF_SAADC_OVERSAMPLE_DISABLED;
    saadc_config.interrupt_priority = APP_IRQ_PRIORITY_LOW_MID;
    err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
    channel_config.acq_time = NRF_SAADC_ACQTIME_3US;
    channel_config.reference = NRF_SAADC_REFERENCE_INTERNAL;
    channel_config.gain = NRF_SAADC_GAIN1_2;
    channel_config.mode = NRF_SAADC_MODE_SINGLE_ENDED;
    channel_config.pin_p = NRF_SAADC_INPUT_AIN1;
    channel_config.pin_n = NRF_SAADC_INPUT_DISABLED;
    channel_config.resistor_p = NRF_SAADC_RESISTOR_DISABLED;                              //Disable pullup resistor on the input pin
    channel_config.resistor_n = NRF_SAADC_RESISTOR_DISABLED;                              //Disable pulldown resistor on the input pin
    err_code = nrf_drv_saadc_channel_init(0, &channel_config);
    channel_config.gain = NRF_SAADC_GAIN1_2 ;
    channel_config.pin_p = NRF_SAADC_INPUT_AIN2;
    err_code = nrf_drv_saadc_channel_init(1, &channel_config);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
the timer is setup as follows:
    /* setup m_timer for compare event every 100us*/
    uint32_t ticks = nrf_drv_timer_us_to_ticks(&m_timer, 100);
                                   NRF_TIMER_CC_CHANNEL0,
                                   ticks,
                                   NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                   false);
    uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL0);
                                          timer_compare_event_addr,
                                          saadc_sample_task_addr);
i used a 50Hz test tone connected to both of the AIN pins configured.  i get what looks like unsettled data (i plotted only a single channel in this case, using every other sample as ch0, and a similar plot is achieved using ch1).
if i slow the sample rate down to 1kHz, the results improves as per the below:
I would have thought that the input mux could scan between two samples and settle faster than 10ksps accurately.  I likely have configured something incorrectly.  any guidance or advice is greatly appreciated!
  • Hi Jared,
    please see attached
     * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup nrf_adc_example main.c
     * @ingroup nrf_adc_example
     * @brief ADC Example Application main file.
     * This file contains the source code for a sample application using ADC.
     * @image html example_board_setup_a.jpg "Use board setup A for this example."
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "nrf.h"
    #include "nrf_drv_saadc.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_timer.h"
    #include "boards.h"
    #include "app_error.h"
    #include "nrf_delay.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define SAMPLES_IN_BUFFER 1024
    volatile uint8_t state = 1;
    static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(0);
    static nrf_saadc_value_t     m_buffer_pool[2][SAMPLES_IN_BUFFER];
    static nrf_ppi_channel_t     m_ppi_channel;
    static uint32_t              m_adc_evt_counter;
    void timer_handler(nrf_timer_event_t event_type, void * p_context)
                                       ticks,
                                       false);
            err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
            int i;
            //NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
            for (i = 0; i < SAMPLES_IN_BUFFER; i++)
                NRF_LOG_RAW_INFO("%d \n", p_event->data.done.p_buffer[i]);
            m_adc_evt_counter++;
        saadc_config.low_power_mode = false;
        saadc_config.interrupt_priority = APP_IRQ_PRIORITY_HIGH;
        channel_config.acq_time = NRF_SAADC_ACQTIME_10US;
        channel_config.gain = NRF_SAADC_GAIN1_6;
        channel_config.burst = NRF_SAADC_BURST_ENABLED;
        channel_config.gain = NRF_SAADC_GAIN1_6 ;
        uint32_t err_code = NRF_LOG_INIT(NULL);
        ret_code_t ret_code = nrf_pwr_mgmt_init();
        APP_ERROR_CHECK(ret_code);
        saadc_init();
        saadc_sampling_event_init();
        NRF_LOG_INFO("SAADC HAL simple example started.");
        while (1)
            nrf_pwr_mgmt_run();
            NRF_LOG_FLUSH();
    So I looked over your code and it's mostly correct. I do have some suggestions/questions that I want you to try/answer:
    1.I see that you're using BURST mode but at the same time has disabled OVERSAMPLE on the channel. Could try without using the BURST mode?
    2.Are you able to reproduce the issue if you only use one channel?
    3.We have seen some issues when switching buffers in the SAADC. This can be the case if another tasks preempts the ongoing task before it's able to trigger the START task in nrf_drv_saadc_buffer_convert(). The suggested solution is to use PPI to bind the START task with the END event. The bug and solution is described in more detail here. Could you try the suggested solution?
    4. Regarding the plot that you've shared. It seems that the issue happens somewhat periodically and at the same place. It's difficult to tell based on the plot if this coincides with the switching of buffers. It would therefore be better if you could provide the raw data from the buffer? Maybe you could print out the raw data in the buffer and signalize when you switch buffers. That way, we could see if there is a certain pattern.
    regards
    Jared
