BLE discovery failure
Hi Team,
We have seen 10 instances in past 2 months where customer mobile phones failed to discover BLE device. This has happened 8 times with Moto G7 power (Android) and twice with iPhone mobile phones. We were able to reproduce this issue locally by streaming music over Bluetooth on Samsung Galaxy S20+ mobile. Same phone was able to discover and connect to device when music is turned off. Hence we are thinking that this issue is not due to BLE Tx power. It seems to be more related to coex mechanism on the phones.
As of now, the BLE advertisement interval is set to 300ms on device. We were thinking of using Burst advertisement mechanism on device to overcome this problem. Rather than sending one BLE advertisement every 300 ms, we can have multiple events, say 5 or 10, sent every 20 ms and then repeat it after 1 second. Can you please let us know how we can achieve this with SoftDevice? Also, feel free to suggest any other fix to solve this problem.
Pranesh
  • I see. That is also 12.5 pF so it should be good.
  • ok, do you see any issue with clock accuracy setting (20 ppm)? or is there any other setting that we should look into?
    The crystal is specified at 20 ppm, so that should be fine. You could configure a higher clock accuracy to get more margin, but this is probably not the root cause of what you are seeing.
    Reading the case again I recall you only see this issue on some phones, and only when they also have BLE audio connection active. This would lead to less time to do scanning, so I suspect that is the problem here. Either the phone does not scan at all, or the scan window is short and occurs quite celdom, or it just co-varies in an unfortunate way with the advertising interval on the nRF. If that is the case, the only thing you can do is to reduce the advertising interval and see if that helps. As mentioned you should also pick an interval that is in line with Apple's recommendations, which also typically work well with Android devices.
  • Hey Einar,
    We have collected more data around this issue, it is now being seen with other device model as well. We plan to do the following:
    1. Move to 152.5ms advertisement interval from 300ms.
    2. Start an SOP to capture more info on other devices in the BLE environment using nRF connect app.
    3. Increase discovery timeout on mobile apps from 6 secs.
    We will capture data again after these changes are deployed to production fleet. In the meantime, we have got the recommendation from our wireless technology team to use burst advertisement to solve this issue. We want to send multiple adv. events, say 5 or 10, sent every 20 ms and then repeat it after 1 second. This can't be implemented by us since we have access to start and stop APIs only, we don't have control on number of packets sent in a window. Can Nordic implement burst advertisement for us? or is it part of Nordic's roadmap?
  • Hi Pranesh,
    Reducing the advertising interval and increasing the timeout time on the phone seems very sensible. Regarding the burst advertising I think no matter what changes you make it is difficult to know if it would improve the situation or not without knowing the scan pattern of the phone when you see this issue. So while I understand that you want to try this approach, I do not immediately understand why it would improve the situation.
    Does the nRF have any other connections active at this stage, or is the only radio activity to advertise? If so, then you can count advertising packets by using radio notifications which is an API that exists in the SoftDevice today.
    Also, I wonder if you really need to know the exact amount of advertising packets? If not, you could just configure advertising with a high duty cycle and keep that for some time, and then reconfigure after the elapsed duration. As you know, a random delay of 0-10 ms is added after a advertising interval, so on average, the time between advertising packets would be the specified advertising interval + 5 ms. So if you advertise for 1 second with 20 ms advertising interval, you would on average get 1000 ms / (20 ms - 5 ms) = 66.67 advertising events. Multiplied by 3 for each channel, that would mean 200 advertising packets.
    Einar
