I am a student interested in Nordic.
My coding skills are very poor.
So I want to get help.
I want to use the vl53l1x sensor in nrf52. (My ultimate goal is to measure the distance using vl53l1x.)
I have put a lot of effort into using the vl53l1x sensor.
The conclusion I found is that the ST driver or arduino driver must be ported to nrf52.
So I am trying to change the arduino driver.
However, it is difficult to change the nrf_twi_rx and nrf_twi_tx functions due to wire.h.
The code I changed is:
/*******************************arduino code**********************************/
void VL53L1X::writeReg(uint16_t reg, uint8_t value)
bus->beginTransmission(address);
bus->write((reg >> 8) & 0xFF); // reg high byte
bus->write( reg & 0xFF); // reg low byte
bus->write(value);
last_status = bus->endTransmission();
uint8_t VL53L1X::readReg(regAddr reg)
uint8_t value;
bus->requestFrom(address, (uint8_t)1);
value = bus->read();
return value;
/**************************nRF52 Code******************************/
//void vl53l1x_set_mode()
void writeReg(uint16_t reg, uint8_t value)
ret_code_t err_code;
uint16_t tx_data[2];
tx_data[0] = ( ((reg >> 8)& 0xFF ) | reg & 0xFF);
tx_data[1] = value;
err_code = nrf_drv_twi_tx(&m_twi, VL53L1X_ADDR, tx_data, sizeof(tx_data), false);
return err_code;
//void read_vl53l1x_data()
uint8_t readReg(uint16_t reg)
uint16_t read_data[2];
uint16_t read_addr = ( ((reg >> 8)& 0xFF ) | reg & 0xFF);
#if 1
err_code = nrf_drv_twi_tx(&m_twi, VL53L1X_ADDR, &read_addr, 1, false);
if(err_code != NRF_SUCCESS)
return err_code;
err_code = nrf_drv_twi_rx(&m_twi, VL53L1X_ADDR, read_data, 1);
return read_data[0];
When I built, the result was only 0. (address or gpio pin was correct.) What am I doing wrong? Please help ㅠㅠ
