BLE Sniffer stops when a connection established
I used this user guide: https://infocenter.nordicsemi.com/pdf/nRF_Sniffer_UG_v2.2.pdf.
I am using the nRF52840 DK for the sniffer, and managed to connect it and see the advertising data for the peripheral (nRF52840) BLE.
When I power on the central board (another nRF52840) I stop receiving sniffer data from the peripheral board, and not sure if the connection is really established.
When I don't power on the sniffer the connection between the two nRF52840 boards done as expected.
Without the sniffer I don't face any problems, when I sniff the peripheral board with the central turned off it works and I got the sniffer data for the advertising data from the peripheral, but I still facing a problem when I turn on the central board.
Please help me to   fix this issue, I need to see the data passed between my peripheral and the central board.
Best Regards
JK
  • Hi
    Can you confirm that you have chosen the correct peripheral device from the "Device list" mentioned in section 3.1 of the User guide. Does the peripheral and central not connect as intended if the sniffer is on, how do you see that the connection is established as intended when the sniffer is off?
    If the devices are already paired, the issue might be that they detect the sniffer device and cancel the connection due to the sniffer device not having the correct OOB key. Please check out the Just Works -sniffing an encrypted connection  and Sniffing a connection between devices that are already paired on pages 15 and 16 in the nRF sniffer user guide for more information on how to sniff a secure connection.
    Simon
    Thank you for your help.
    I erased the pairing data from the peripheral board and sniffed the pairing process at the connection and now I can sniff all the communication between the dongle and the device.
    Best Regards
    JK
  • Great news JK! Please "verify" the answer if this ticket can be closed. That will help users with the same problem in the future find the solution quicker as well.
    Simon
  • Hi Simonr,
    I looked into it, But the two devices is a nRF5280 !, how can I find the passkey? I didn't find it in the project
    Best Regards
    JK
  • Hi
    That depends on how you do encryption in your application. If you use a passkey to do pairing, it should be printed to the terminal over the DKs COM port, and you can add it in the sniffer and central device to pair while the sniffer is "in".
    If you don't use a passkey, I guess you're pairing using OOB. If so, you will need the OOB key. To get it, you will need to output the OOB key from the application somehow, for instance by printing it to UART using NRF_LOG_INFO(). The OOB key is requested in the BLE_GAP_EVT_AUTH_KEY_REQUEST event, and you provide the key using the sd_ble_gap_auth_key_reply() function. So I would suggest printing it right after or before the sd_ble_gap_auth_key_reply() function is called in this case. Either should be fine.
    Simon
