Initiation problem on Vodafone with NB-IoT from nrf9160-DK
After  a few configuration issues we have finally got a connection with the asset tracker application.  However we are not getting far enough to send data.
The log shows a lot of MQTT stuff that I don't understand.
[00:00:00.206,268] [0m<inf> asset_tracker: Asset tracker started[0m
[00:00:00.212,585] [0m<inf> watchdog: Watchdog timeout installed. Timeout: 60000[0m
[00:00:00.220,275] [0m<inf> watchdog: Watchdog started[0m
[00:00:00.225,708] [0m<inf> watchdog: Watchdog feed enabled. Timeout: 30000[0m
[00:00:00.239,990] [0m<dbg> nrf_cloud_transport.nct_client_id_get: client_id = nrf-352656100390296[0m
[00:00:00.249,267] [0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_base_topic: $aws/things/nrf-352656100390296/shadow[0m
[00:00:00.261,016] [0m<dbg> nrf_cloud_transport.nct_topics_populate: accepted_topic: nrf-352656100390296/shadow/get/accepted[0m
[00:00:00.272,583] [0m<dbg> nrf_cloud_transport.nct_topics_populate: rejected_topic: $aws/things/nrf-352656100390296/shadow/get/rejected[0m
[00:00:00.285,186] [0m<dbg> nrf_cloud_transport.nct_topics_populate: update_delta_topic: $aws/things/nrf-352656100390296/shadow/update/delta[0m
[00:00:00.298,156] [0m<dbg> nrf_cloud_transport.nct_topics_populate: update_topic: $aws/things/nrf-352656100390296/shadow/update[0m
[00:00:00.310,058] [0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_get_topic: $aws/things/nrf-352656100390296/shadow/get[0m
[00:00:00.322,570] [0m<inf> asset_tracker: Connecting to LTE network.[0m
[00:00:00.329,284] [0m<inf> asset_tracker: This may take several minutes.[0m
[00:00:00.350,341] [0m<inf> lte_lc: Using legacy LTE PCO mode...[0m
[00:00:00.363,372] [0m<inf> lte_lc: PDP Context: AT+CGDCONT=0,"IP","lpwa.vodafone.iot"[0m
+CEREG: 2,"1BE8","0029FF0B",9,0,0,"11100000","11100000"
[00:00:04.007,202] [0m<inf> asset_tracker: LTE cell changed: Cell ID: 2752267, Tracking area: 7144[0m
[00:00:04.016,510] [0m<inf> asset_tracker: PSM parameter update: TAU: -1, Active time: -1[0m+CSCON: 1
[00:00:04.364,044] [0m<inf> asset_tracker: RRC mode: Connected[0m+CEREG: 5,"1BE8","0029FF0B",9,,,"11100000","00101000"
[00:00:04.934,112] [0m<inf> asset_tracker: Connected to LTE network.[0m
[00:00:04.940,948] [0m<inf> asset_tracker: Network registration status: Connected - roaming[0m
[00:00:04.949,615] [0m<inf> asset_tracker: PSM parameter update: TAU: 28800, Active time: -1[0m
[00:00:05.448,760] [0m<inf> asset_tracker: DATE_TIME_OBTAINED_NTP[0m
[00:00:05.455,200] [0m<inf> asset_tracker: Connecting to cloud, attempt 1 of 8[0m
[00:00:05.462,738] [0m<inf> asset_tracker: Cloud connection request sent.[0m
[00:00:05.469,787] [0m<inf> asset_tracker: Connection response timeout is set to 30 seconds.[0m
[00:00:05.478,607] [0m<inf> asset_tracker: CLOUD_EVT_CONNECTING[0m
[00:00:06.114,532] [0m<dbg> nrf_cloud_transport.nct_connect: IPv4 address: 52.44.28.112[0m
[00:00:06.122,833] [0m<dbg> nrf_cloud_transport.nct_mqtt_connect: MQTT clean session flag: 1[0m
[00:00:13.407,073] [0m<inf> nrf_cloud_transport: Using socket send timeout of 60 seconds[0m
[00:00:13.415,496] [0m<dbg> nrf_cloud.nrf_cloud_run: Cloud connection request sent.[0m
[00:00:13.722,808] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_DISCONNECT: result = -128[0m
[00:00:13.732,696] [0m<dbg> nrf_cloud_fsm.drop_event_handler: Dropping FSM transition 9, current state 1[0m
[00:00:14.242,614] [0m<dbg> nrf_cloud.nrf_cloud_run: Socket error: POLLNVAL[0m
[00:00:14.249,847] [0m<dbg> nrf_cloud.nrf_cloud_run: The cloud socket was unexpectedly closed.[0m
[00:00:14.258,758] [0m<inf> asset_tracker: CLOUD_EVT_DISCONNECTED: 2[0m
[00:00:14.265,380] [0m<inf> asset_tracker: Cloud connection closed.[0m
[00:00:14.271,911] [0m<inf> asset_tracker: This can occur during initial nRF Cloud provisioning.[0m
[00:00:14.280,975] [0m<inf> asset_tracker: Attempting reconnect in 10 seconds...[0m
[00:00:14.288,665] [0m<dbg> nrf_cloud_transport.nct_disconnect: nct_disconnect[0m
+CSCON: 0
[00:00:23.913,269] [0m<inf> asset_tracker: RRC mode: Idle[0m
[00:00:24.288,726] [0m<inf> asset_tracker: Connecting to cloud, attempt 2 of 8[0m
[00:00:24.296,295] [0m<inf> asset_tracker: Cloud connection request sent.[0m
[00:00:24.303,344] [0m<inf> asset_tracker: Connection response timeout is set to 30 seconds.[0m
[00:00:24.312,103] [0m<inf> asset_tracker: CLOUD_EVT_CONNECTING[0m
[00:00:24.327,178] [0m<dbg> nrf_cloud_transport.nct_connect: IPv4 address: 52.44.28.112[0m
+CSCON: 1
[00:00:24.842,681] [0m<inf> asset_tracker: RRC mode: Connected[0m
[00:00:31.612,640] [0m<inf> nrf_cloud_transport: Using socket send timeout of 60 seconds[0m
[00:00:31.621,093] [0m<dbg> nrf_cloud.nrf_cloud_run: Cloud connection request sent.[0m
[00:00:31.890,716] [0m<dbg> aws_jobs.reg_topic: Subscribe: $aws/things/nrf-352656100390296/jobs/notify-next[0m
[00:00:31.901,611] [0m<dbg> aws_jobs.reg_topic: Subscribe: $aws/things/nrf-352656100390296/jobs/$next/get/#[0m
[00:00:31.912,475] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_CONNACK: result 0[0m
[00:00:31.921,569] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 2[0m
[00:00:31.929,321] [0m<dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_TRANSPORT_CONNECTED[0m
[00:00:31.937,866] [0m<inf> asset_tracker: CLOUD_EVT_CONNECTED[0m
[00:00:31.943,969] [0m<inf> asset_tracker: Persistent Sessions = 0[0m
[00:00:31.950,408] [0m<dbg> nrf_cloud_transport.nct_cc_connect: nct_cc_connect[0m
[00:00:31.958,770] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 3[0m
[00:00:32.155,639] [0m<dbg> aws_fota.aws_fota_mqtt_evt_handler: subscribed to notify-next topic[0m
[00:00:32.164,703] [0m<dbg> aws_jobs.publish: Publish topic: $aws/things/nrf-352656100390296/jobs/$next/get[0m
[00:00:32.174,743] [0m<dbg> aws_jobs.publish: Publish payload {"clientToken": ""}[0m
[00:00:32.315,643] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_SUBACK: id = 2114 result = 0[0m
[00:00:32.365,661] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_SUBACK: id = 1234 result = 0[0m
[00:00:32.375,732] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 4[0m
[00:00:32.383,514] [0m<dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id = 5678 opcode = 0 len = 0[0m
[00:00:32.394,439] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 5[0m
[00:00:32.500,671] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 5980 result = 0[0m
[00:00:32.578,796] [0m<dbg> aws_fota.on_publish_evt: Received topic: $aws/things/nrf-352656100390296/jobs/$next/get/accepted[0m
[00:00:32.590,332] [0m<dbg> aws_fota.on_publish_evt: Checking for an available job[0m
[00:00:32.598,297] [0m<dbg> aws_fota.get_job_execution: Job doc: {"clientToken":"","timestamp":1607691658}[0m
[00:00:32.608,551] [0m<dbg> aws_fota.get_job_execution: Got only one field[0m
[00:00:32.615,692] [0m<dbg> aws_fota.get_job_execution: No queued jobs for this device[0m
[00:00:32.804,656] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 5678 result = 0[0m
[00:00:32.814,727] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 5[0m
[00:00:32.955,657] [0m<dbg> aws_fota.on_publish_evt: Received topic: nrf-352656100390296/shadow/get/accepted[0m
[00:00:32.965,789] [0m<dbg> aws_fota.on_publish_evt: received an unhandled MQTT publish event on topic: nrf-352656100390296/shadow/get/accepted[0m
[00:00:32.978,942] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBLISH: id = 0 len = 50[0m
[00:00:32.990,509] [0m<dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id = 1 opcode = 1 len = 136[0m
[00:00:33.001,892] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 6[0m
[00:00:33.009,704] [0m<dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_USER_ASSOCIATION_REQUEST[0m
[00:00:33.018,676] [0m<inf> asset_tracker: CLOUD_EVT_PAIR_REQUEST[0m
[00:00:33.025,024] [0m<inf> asset_tracker: Add device to cloud account.[0m
[00:00:33.031,890] [0m<inf> asset_tracker: Waiting for cloud association...[0m
[00:00:33.246,002] [0m<dbg> aws_fota.on_publish_evt: Received topic: nrf-352656100390296/shadow/get/accepted[0m
[00:00:33.256,134] [0m<dbg> aws_fota.on_publish_evt: received an unhandled MQTT publish event on topic: nrf-352656100390296/shadow/get/accepted[0m
[00:00:33.269,317] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBLISH: id = 0 len = 323[0m
[00:00:33.282,867] [1;33m<wrn> nrf_cloud_codec: Unhandled data received from nRF Cloud.[0m
[00:00:33.291,137] [0m<inf> nrf_cloud_codec: Ensure device firmware is up to date.[0m
[00:00:33.298,980] [0m<inf> nrf_cloud_codec: Delete and re-add device to nRF Cloud if problem persists.[0m
[00:00:33.309,265] [1;31m<err> nrf_cloud_fsm: nrf_cloud_decode_requested_state Failed -2[0m
[00:00:33.317,626] [1;31m<err> nrf_cloud_fsm: Handler failed! state: 6, type: 3[0m
[00:00:33.325,225] [1;31m<err> nrf_cloud_transport: nct_input: failed -2[0m
[00:00:33.529,693] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 1 result = 0[0m
+CSCON: 0
[00:00:44.114,929] [0m<inf> asset_tracker: RRC mode: Idle[0m
AT+CGDCONT?+CGDCONT: 0,"IP","lpwa.vodafone.iot","100.93.252.210",0,0
OK
at%xsystemmode?%XSYSTEMMODE: 0,1,1,0
OK
+CSCON: 1
[00:02:33.418,823] [0m<inf> asset_tracker: RRC mode: Connected[0m
+CSCON: 0
[00:02:44.452,789] [0m<inf> asset_tracker: RRC mode: Idle[0m
+CSCON: 1
[00:04:33.742,675] [0m<inf> asset_tracker: RRC mode: Connected[0m
+CSCON: 0
[00:04:44.761,627] [0m<inf> asset_tracker: RRC mode: Idle[0m
at+cereg?
+CEREG: 5,5,"1BE8","0029FF0B",9,,,"11100000","00101000"
OK
[00:05:33.039,184] [0m<inf> asset_tracker: Disconnecting from cloud...[0m
[00:05:33.046,020] [0m<dbg> nrf_cloud_transport.nct_disconnect: nct_disconnect[0m
[00:05:33.063,995] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_DISCONNECT: result = 0[0m
[00:05:33.073,486] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 1[0m
[00:05:33.081,268] [0m<dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_TRANSPORT_DISCONNECTED[0m
[00:05:33.090,179] [0m<dbg> nrf_cloud.nrf_cloud_run: Expected disconnect event.[0m
[00:05:33.097,747] [0m<inf> asset_tracker: CLOUD_EVT_DISCONNECTED: 0[0m
[00:05:33.104,370] [0m<inf> asset_tracker: Attempting reconnect in 10 seconds...[0m
+CSCON: 1
[00:05:33.580,566] [0m<inf> asset_tracker: RRC mode: Connected[0m
[00:05:43.112,121] [0m<inf> asset_tracker: Connecting to cloud, attempt 1 of 8[0m
[00:05:43.119,659] [0m<inf> asset_tracker: Cloud connection request sent.[0m
[00:05:43.126,708] [0m<inf> asset_tracker: Connection response timeout is set to 30 seconds.[0m
[00:05:43.135,467] [0m<inf> asset_tracker: CLOUD_EVT_CONNECTING[0m
[00:05:43.683,380] [0m<dbg> nrf_cloud_transport.nct_connect: IPv4 address: 3.221.63.246[0m
[00:05:50.662,872] [0m<inf> nrf_cloud_transport: Using socket send timeout of 60 seconds[0m
[00:05:50.671,295] [0m<dbg> nrf_cloud.nrf_cloud_run: Cloud connection request sent.[0m
[00:05:50.964,935] [0m<dbg> aws_jobs.reg_topic: Subscribe: $aws/things/nrf-352656100390296/jobs/notify-next[0m
[00:05:50.975,830] [0m<dbg> aws_jobs.reg_topic: Subscribe: $aws/things/nrf-352656100390296/jobs/$next/get/#[0m
[00:05:50.986,694] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_CONNACK: result 0[0m
[00:05:50.995,758] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 2[0m
[00:05:51.003,509] [0m<dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_TRANSPORT_CONNECTED[0m
[00:05:51.012,054] [0m<inf> asset_tracker: CLOUD_EVT_CONNECTED[0m
[00:05:51.018,157] [0m<inf> asset_tracker: Persistent Sessions = 0[0m
[00:05:51.024,597] [0m<dbg> nrf_cloud_transport.nct_cc_connect: nct_cc_connect[0m
[00:05:51.032,836] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 3[0m
[00:05:51.276,885] [0m<dbg> aws_fota.aws_fota_mqtt_evt_handler: subscribed to notify-next topic[0m
[00:05:51.285,949] [0m<dbg> aws_jobs.publish: Publish topic: $aws/things/nrf-352656100390296/jobs/$next/get[0m
[00:05:51.295,989] [0m<dbg> aws_jobs.publish: Publish payload {"clientToken": ""}[0m
[00:05:51.420,898] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_SUBACK: id = 2114 result = 0[0m
[00:05:51.485,961] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_SUBACK: id = 1234 result = 0[0m
[00:05:51.496,032] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 4[0m
[00:05:51.503,784] [0m<dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id = 5678 opcode = 0 len = 0[0m
[00:05:51.514,404] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 5[0m
[00:05:51.580,902] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 42721 result = 0[0m
[00:05:51.675,018] [0m<dbg> aws_fota.on_publish_evt: Received topic: $aws/things/nrf-352656100390296/jobs/$next/get/accepted[0m
[00:05:51.686,553] [0m<dbg> aws_fota.on_publish_evt: Checking for an available job[0m
[00:05:51.694,488] [0m<dbg> aws_fota.get_job_execution: Job doc: {"clientToken":"","timestamp":1607691977}[0m
[00:05:51.704,742] [0m<dbg> aws_fota.get_job_execution: Got only one field[0m
[00:05:51.711,883] [0m<dbg> aws_fota.get_job_execution: No queued jobs for this device[0m
[00:05:51.899,902] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 5678 result = 0[0m
[00:05:51.909,942] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 5[0m
[00:05:52.005,981] [0m<dbg> aws_fota.on_publish_evt: Received topic: nrf-352656100390296/shadow/get/accepted[0m
[00:05:52.016,113] [0m<dbg> aws_fota.on_publish_evt: received an unhandled MQTT publish event on topic: nrf-352656100390296/shadow/get/accepted[0m
[00:05:52.029,296] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBLISH: id = 0 len = 50[0m
[00:05:52.040,893] [0m<dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id = 1 opcode = 1 len = 136[0m
[00:05:52.052,124] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 6[0m
[00:05:52.059,906] [0m<dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_USER_ASSOCIATION_REQUEST[0m
[00:05:52.068,878] [0m<inf> asset_tracker: CLOUD_EVT_PAIR_REQUEST[0m
[00:05:52.075,225] [0m<inf> asset_tracker: Add device to cloud account.[0m
[00:05:52.082,092] [0m<inf> asset_tracker: Waiting for cloud association...[0m
[00:05:52.259,185] [0m<dbg> aws_fota.on_publish_evt: Received topic: nrf-352656100390296/shadow/get/accepted[0m
[00:05:52.269,317] [0m<dbg> aws_fota.on_publish_evt: received an unhandled MQTT publish event on topic: nrf-352656100390296/shadow/get/accepted[0m
[00:05:52.282,501] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBLISH: id = 0 len = 358[0m
[00:05:52.296,386] [1;33m<wrn> nrf_cloud_codec: Unhandled data received from nRF Cloud.[0m
[00:05:52.304,656] [0m<inf> nrf_cloud_codec: Ensure device firmware is up to date.[0m
[00:05:52.312,500] [0m<inf> nrf_cloud_codec: Delete and re-add device to nRF Cloud if problem persists.[0m
[00:05:52.322,845] [1;31m<err> nrf_cloud_fsm: nrf_cloud_decode_requested_state Failed -2[0m
[00:05:52.331,207] [1;31m<err> nrf_cloud_fsm: Handler failed! state: 6, type: 3[0m
[00:05:52.338,806] [1;31m<err> nrf_cloud_transport: nct_input: failed -2[0m
[00:05:52.691,894] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 1 result = 0[0m
+CSCON: 0
[00:06:02.821,136] [0m<inf> asset_tracker: RRC mode: Idle[0m
+CSCON: 1
[00:07:53.141,113] [0m<inf> asset_tracker: RRC mode: Connected[0m
+CSCON: 0
[00:08:10.941,253] [0m<inf> asset_tracker: RRC mode: Idle[0m
+CEREG: 5,"1BE8","00335B15",9,,,"11100000","00101000"
[00:09:52.943,939] [0m<inf> asset_tracker: LTE cell changed: Cell ID: 3365653, Tracking area: 7144[0m
+CSCON: 1
[00:09:59.668,304] [0m<inf> asset_tracker: RRC mode: Connected[0m
[00:10:52.089,385] [0m<inf> asset_tracker: Disconnecting from cloud...[0m
[00:10:52.096,191] [0m<dbg> nrf_cloud_transport.nct_disconnect: nct_disconnect[0m
[00:10:52.105,804] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_DISCONNECT: result = 0[0m
[00:10:52.115,325] [0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 1[0m
[00:10:52.123,077] [0m<dbg> nrf_cloud.api_event_handler: NRF_CLOUD_EVT_TRANSPORT_DISCONNECTED[0m
[00:10:52.131,988] [0m<dbg> nrf_cloud.nrf_cloud_run: Expected disconnect event.[0m
[00:10:52.139,556] [0m<inf> asset_tracker: CLOUD_EVT_DISCONNECTED: 0[0m
[00:10:52.146,179] [0m<inf> asset_tracker: Attempting reconnect in 10 seconds...[0m
[00:11:02.153,930] [0m<inf> asset_tracker: Connecting to cloud, attempt 1 of 8[0m
[00:11:02.161,499] [0m<inf> asset_tracker: Cloud connection request sent.[0m
[00:11:02.168,548] [0m<inf> asset_tracker: Connection response timeout is set to 30 seconds.[0m
[00:11:02.177,276] [0m<inf> asset_tracker: CLOUD_EVT_CONNECTING[0m
+CSCON: 0
[00:11:08.071,166] [0m<inf> asset_tracker: RRC mode: Idle[0m
+CEREG: 5,"1BE8","00335B1F",9,,,"11100000","00101000"
[00:11:09.665,710] [0m<inf> asset_tracker: LTE cell changed: Cell ID: 3365663, Tracking area: 7144[0m
+CSCON: 1
[00:11:19.741,851] [0m<inf> asset_tracker: RRC mode: Connected[0m
+CSCON: 0
[00:11:51.101,348] [0m<inf> asset_tracker: RRC mode: Idle[0m
+CEREG: 5,"FFFE","FFFFFFFF",9,,,"11100000","00101000"
[00:11:51.763,946] [0m<inf> asset_tracker: LTE cell changed: Cell ID: -1, Tracking area: 65534[0m
[00:12:10.614,898] [0m<dbg> nrf_cloud_transport.nct_connect: getaddrinfo failed -11[0m
[00:12:10.622,863] [0m<inf> asset_tracker: CLOUD_EVT_CONNECTING[0m
[00:12:10.629,028] [1;31m<err> asset_tracker: Failed to connect to cloud, error -3[0m
[00:12:10.636,871] [1;31m<err> asset_tracker: Network error, check cloud configuration[0m
[00:12:10.645,050] [1;31m<err> asset_tracker: Device will reboot in 300 seconds[0m
[00:12:10.652,648] [1;31m<err> asset_tracker: LTE link disconnect[0m
+CEREG: 0,"FFFE","FFFFFFFF",9,0,0,"11100000","11100000"
[00:12:17.621,826] [0m<inf> asset_tracker: PSM parameter update: TAU: -1, Active time: -1[0m
[00:12:17.708,770] [1;31m<err> asset_tracker: Shutdown modem[0m
[00:17:10.652,679] [1;31m<err> asset_tracker: LTE link disconnect[0m
[00:17:10.659,057] [1;31m<err> asset_tracker: lte_lc_power_off failed: -5[0m
[00:17:10.666,137] [1;31m<err> asset_tracker: Shutdown modem[0m***
Can anyone shed any light please?  One of my theories is that differences between the Vodafone and nrfCloud could explain it?
