I am doing the project in nRF2832 , where I need to collect some data from the sensor and temperature value that i need to save in the .CSV file format in SD cARD. and I need to Transfer the particular File to the Central device (Mobile phone or another nRF52 device) using BLE .
I have gone through the FATFS example there i found the interfacing the SD card and creating the file and writing the text in it . and build and run successfully.
When I am try to read the file i have occur an issue called
Building ‘fatfs_pca10040’ from solution ‘fatfs_pca10040’ in configuration ‘Release’
Compiling ‘main.c’
Linking fatfs_pca10040.elf
.bss is too large to fit in RAM memory segment
.heap is too large to fit in RAM memory segment
section .heap overlaps absolute placed section .stack
Build failed
I gone thorugh the link and attached file also here
Main.c file is
* Copyright (c) 2016 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup fatfs_example_main main.c
* @ingroup fatfs_example
* @brief FATFS Example Application main file.
* This file contains the source code for a sample application using FAT filesystem and SD card library.
#include "nrf.h"
#include "bsp.h"
#include "ff.h"
#include "diskio_blkdev.h"
#include "nrf_block_dev_sdc.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define FILE_NAME "NORDIC.TXT"
#define TEST_STRING "SD card example."
#define FILE_SIZE_MAX 65535
#define SDC_SCK_PIN ARDUINO_13_PIN ///< SDC serial clock (SCK) pin.
#define SDC_MOSI_PIN ARDUINO_11_PIN ///< SDC serial data in (DI) pin.
#define SDC_MISO_PIN ARDUINO_12_PIN ///< SDC serial data out (DO) pin.
#define SDC_CS_PIN ARDUINO_10_PIN ///< SDC chip select (CS) pin.
static uint8_t file_found_on_sdcard = false;
static uint8_t file_buffer[FILE_SIZE_MAX];
static uint16_t file_actual_read_size = 0;
static uint8_t file_send_to_peripheral = false;
* @brief SDC block device definition
NRF_BLOCK_DEV_SDC_DEFINE(
m_block_dev_sdc,
NRF_BLOCK_DEV_SDC_CONFIG(
SDC_SECTOR_SIZE,
APP_SDCARD_CONFIG(SDC_MOSI_PIN, SDC_MISO_PIN, SDC_SCK_PIN, SDC_CS_PIN)
NFR_BLOCK_DEV_INFO_CONFIG("Nordic", "SDC", "1.00")
* @brief Function for demonstrating FAFTS usage.
static void fatfs_example()
static FATFS fs;
static DIR dir;
static FILINFO fno;
static FIL file;
uint32_t bytes_written;
uint32_t bytes_read;
FRESULT ff_result;
DSTATUS disk_state = STA_NOINIT;
// Initialize FATFS disk I/O interface by providing the block device.
static diskio_blkdev_t drives[] =
DISKIO_BLOCKDEV_CONFIG(NRF_BLOCKDEV_BASE_ADDR(m_block_dev_sdc, block_dev), NULL)
diskio_blockdev_register(drives, ARRAY_SIZE(drives));
NRF_LOG_INFO("Initializing disk 0 (SDC)...");
for (uint32_t retries = 3; retries && disk_state; --retries)
disk_state = disk_initialize(0);
if (disk_state)
NRF_LOG_INFO("Disk initialization failed.");
return;
uint32_t blocks_per_mb = (1024uL * 1024uL) / m_block_dev_sdc.block_dev.p_ops->geometry(&m_block_dev_sdc.block_dev)->blk_size;
uint32_t capacity = m_block_dev_sdc.block_dev.p_ops->geometry(&m_block_dev_sdc.block_dev)->blk_count / blocks_per_mb;
NRF_LOG_INFO("Capacity: %d MB", capacity);
NRF_LOG_INFO("Mounting volume...");
ff_result = f_mount(&fs, "", 1);
if (ff_result)
NRF_LOG_INFO("Mount failed.");
return;
NRF_LOG_INFO("\r\n Listing directory: /");
ff_result = f_opendir(&dir, "/");
if (ff_result)
NRF_LOG_INFO("Directory listing failed!");
return;
do
ff_result = f_readdir(&dir, &fno);
if (ff_result != FR_OK)
NRF_LOG_INFO("Directory read failed.");
return;
if (fno.fname[0])
if (fno.fattrib & AM_DIR)
NRF_LOG_RAW_INFO(" <DIR> %s",(uint32_t)fno.fname);
NRF_LOG_RAW_INFO("%9lu %s", fno.fsize, (uint32_t)fno.fname);
while (fno.fname[0]);
NRF_LOG_RAW_INFO("");
NRF_LOG_INFO("Writing to file " FILE_NAME "...");
ff_result = f_open(&file, FILE_NAME, FA_READ | FA_WRITE | FA_OPEN_APPEND);
NRF_LOG_INFO("Unable to open or create file: " FILE_NAME ".");
return;
ff_result = f_write(&file, TEST_STRING, sizeof(TEST_STRING) - 1, (UINT *) &bytes_written);
NRF_LOG_INFO("Write failed\r\n.");
NRF_LOG_INFO("%d bytes written.", bytes_written);
(void) f_close(&file);
NRF_LOG_INFO("Reading from file " FILE_NAME "...");
ff_result = f_open(&file, FILE_NAME, FA_READ);
return;
ff_result = f_read(&file, file_buffer, FILE_SIZE_MAX, (UINT *) &bytes_read);
NRF_LOG_INFO("Read failed\r\n.");
NRF_LOG_INFO("%d bytes read.", bytes_read);
file_actual_read_size = bytes_read;
return;
NRF_LOG_INFO("FATFS example started.");
fatfs_example();
while (true)
__WFE();
I am Using nrf52832 SES . SDK 17.0.2 and also tried in SDK 16.0
