There seems to be a problem using multiple app_timer() together.
Hello
I am using sdk v17.0 and nrf52832.
I'm using two timers through a button.
1. Timer for click & double-click. (Single Timer)
2. Timer for Long Press. (Repeated Timer)
Using them separately is not a problem, but if I use them together, It stop when I double-click. I checked by debugging, but no error occurred. (I think it stopped at the RTC.)
static void PairLED_timer_handler(void * p_context) //when advertising toggle led
  nrf_gpio_pin_toggle(Pairing_LED); //toggle led
uint32_t press_time; //press time count
uint32_t press_time2; //press time count
int click_count; //click count(use double click)
bool buttonTimeout = false; //use double click
static void PowerOff_timer_handler(void * p_context)
  press_time++;
  printf("COUNT : %d\n", press_time);
  if(press_time == 2) //press 2sec, Power Off
    printf("Power Off!\n");
    //nrf_gpio_pin_clear(POWER_SW); //LOW : power off
static void DoubleClick_timer_handler(void * p_context)
  //printf("Timeout\n");
  printf("%d\n", click_count);
  buttonTimeout = true;
  if(click_count == 1)
    printf("One Click\n");
  click_count = 0;
static void timers_init(void)
    ret_code_t err_code;
    // Initialize timer module.
    err_code = app_timer_init();
   //Create Pairing LED timers/
    err_code = app_timer_create(&m_PairLED_timerid,
                                APP_TIMER_MODE_REPEATED,
                                PairLED_timer_handler);
   //Create Power off Time timers/
    err_code = app_timer_create(&m_PowerOff_timer_id,
                                PowerOff_timer_handler);
   //Create DOuble Click Time timers/
    err_code = app_timer_create(&m_DoubleClick_timer_id,
                                APP_TIMER_MODE_SINGLE_SHOT,
                                DoubleClick_timer_handler);
static void PairLED_timers_start()
  err_code = app_timer_start(m_PairLED_timerid, APP_TIMER_TICKS(1000), NULL); //Toggle 1sec
  printf("Scanning Start\n");
static void PairLED_timers_stop() //Stop Timer
    err_code = app_timer_stop(m_PairLED_timerid);
static void PowerOff_timers_start()
  err_code = app_timer_start(m_PowerOff_timer_id, APP_TIMER_TICKS(1000), NULL); //count 1sec
static void PowerOff_timers_stop()
    //printf("No Power Off\n");
    press_time = 0; //count reset
    err_code = app_timer_stop(m_PowerOff_timer_id);
static void DoubleClick_timers_start()
  err_code = app_timer_start(m_DoubleClick_timer_id, APP_TIMER_TICKS(500), NULL);
static void DoubleClick_timers_stop() //Stop Timer
    err_code = app_timer_stop(m_DoubleClick_timer_id);
    //printf("Stop Timer\n");
static uint32_t pressed_time, released_time, pressed_duration = 0;
static bool pressed_cnt= false;
static uint32_t app_button_duration(void) //press time
  pressed_duration = (released_time - pressed_time)*2; //ms
  return pressed_duration;
static void app_button_init_time_variable(void)
  pressed_duration = 0; //press time
static void app_button_event_generator(void) //button press time
  app_button_init_time_variable();
static void app_button_event_handler(uint8_t pin_no, uint8_t button_action)
    switch (pin_no)
      case BUTTON_1:
        switch (button_action)
          case APP_BUTTON_PUSH:
            //printf("Button pressed\n");
            //get pressed time
            /*pressed_time = app_timer_cnt_get()*1000/32768;//milli-sec
            NRF_LOG_INFO("pressed_time: %d", (int)pressed_time);
            printf("pressed_time: %d\n", (int)pressed_time);
            pressed_cnt = true; */
            if(click_count == 0) //first click
              DoubleClick_timers_start();  //buttonTimeout = true, click_count = 0;
            PowerOff_timers_start(); //press time count
          click_count++;
           case APP_BUTTON_RELEASE:
              //printf("Button releaed\n");
              PowerOff_timers_stop();
              /*if (pressed_cnt)
                released_time = app_timer_cnt_get()*1000/32768; //milli-sec
                NRF_LOG_INFO("released_time: %d", (int)released_time);
                printf("released_time: %d\n", (int)released_time);
                click_state = 0;
              pressed_cnt = false; */
              if(click_count == 2 && !buttonTimeout) //double click
                DoubleClick_timers_stop();
                click_count = 0;
                printf("Double Click\n");
           } break;
         APP_ERROR_HANDLER(pin_no);
    if(app_button_duration())
      app_button_event_generator();
static void app_buttons_init(void)
  uint32_t err_code;
  static const app_button_cfg_t app_buttons[BUTTONS_NUMBER] =
    {BUTTON_1, false, BUTTON_PULL, app_button_event_handler},
  err_code = app_button_init((app_button_cfg_t *)app_buttons,
                                       BUTTONS_NUMBER,        // 1
                                       APP_TIMER_TICKS(50)); //debounce
Could you tell me the cause of this problem?
Thank you!
  • Hello
    I still have a problem with double-click the button.
    I attach my project file. I couldn't show you the whole code, so I wrote only the code for the ble_uart and button.
    Thank you for helping me.8715.TEST.zip
    There are some issues with the project. It uses A_LED and B_LED, but those are not defined. Removing that the project builds, but fails runtime in app_button_init(). Can you upload a working project (in the sense that it runs out of the box and reproduces the issue described in this thread out of the box)?
  • I'm sorry. I think there was a mistake.
    Reattach the source code you are currently working on without modifying it.
    I think the error in app_button_init() is because I modified BUTTONS_NUMBER in pca10040.
    Thank you.
    2705.TEST.zip
    pca10040.h
    #ifndef PCA10040_H
    #define PCA10040_H
    #ifdef __cplusplus
    extern "C" {
    #include "nrf_gpio.h"
    // LEDs definitions for PCA10040
    #define LEDS_NUMBER    4
    #define LED_START      17
    #define LED_1          17
    #define LED_2          18
    #define LED_3          19
    #define LED_4          20
    #define LED_STOP       20
    #define LEDS_ACTIVE_STATE 0
    #define LEDS_INV_MASK  LEDS_MASK
    #define LEDS_LIST { LED_1, LED_2, LED_3, LED_4 }
    #define BSP_LED_0      LED_1
    #define BSP_LED_1      LED_2
    #define BSP_LED_2      LED_3
    #define BSP_LED_3      LED_4
    #define BUTTONS_NUMBER 1 //4
    #define BUTTON_START   13
    #define BUTTON_1       13
    //#define BUTTON_2       14
    //#define BUTTON_3       15
    //#define BUTTON_4       16
    #define BUTTON_STOP    13 //16
    #define BUTTON_PULL    NRF_GPIO_PIN_PULLUP
    #define BUTTONS_ACTIVE_STATE 0
    //#define BUTTONS_LIST { BUTTON_1, BUTTON_2, BUTTON_3, BUTTON_4 }
    #define BUTTONS_LIST { BUTTON_1 }
    #define BSP_BUTTON_0   BUTTON_1
    /*#define BSP_BUTTON_1   BUTTON_2
    #define BSP_BUTTON_2   BUTTON_3
    #define BSP_BUTTON_3   BUTTON_4
    #define RX_PIN_NUMBER  8
    #define TX_PIN_NUMBER  6
    #define CTS_PIN_NUMBER 7
    #define RTS_PIN_NUMBER 5
    #define HWFC           true
    #define SPIS_MISO_PIN   28  // SPI MISO signal.
    #define SPIS_CSN_PIN    12  // SPI CSN signal.
    #define SPIS_MOSI_PIN   25  // SPI MOSI signal.
    #define SPIS_SCK_PIN    29  // SPI SCK signal.
    #define SPIM0_SCK_PIN   29  // SPI clock GPIO pin number.
    #define SPIM0_MOSI_PIN  25  // SPI Master Out Slave In GPIO pin number.
    #define SPIM0_MISO_PIN  28  // SPI Master In Slave Out GPIO pin number.
    #define SPIM0_SS_PIN    12  // SPI Slave Select GPIO pin number.
    #define SPIM1_SCK_PIN   2   // SPI clock GPIO pin number.
    #define SPIM1_MOSI_PIN  3   // SPI Master Out Slave In GPIO pin number.
    #define SPIM1_MISO_PIN  4   // SPI Master In Slave Out GPIO pin number.
    #define SPIM1_SS_PIN    5   // SPI Slave Select GPIO pin number.
    #define SPIM2_SCK_PIN   12  // SPI clock GPIO pin number.
    #define SPIM2_MOSI_PIN  13  // SPI Master Out Slave In GPIO pin number.
    #define SPIM2_MISO_PIN  14  // SPI Master In Slave Out GPIO pin number.
    #define SPIM2_SS_PIN    15  // SPI Slave Select GPIO pin number.
    // serialization APPLICATION board - temp. setup for running serialized MEMU tests
    #define SER_APP_RX_PIN              23    // UART RX pin number.
    #define SER_APP_TX_PIN              24    // UART TX pin number.
    #define SER_APP_CTS_PIN             2     // UART Clear To Send pin number.
    #define SER_APP_RTS_PIN             25    // UART Request To Send pin number.
    #define SER_APP_SPIM0_SCK_PIN       27     // SPI clock GPIO pin number.
    #define SER_APP_SPIM0_MOSI_PIN      2      // SPI Master Out Slave In GPIO pin number
    #define SER_APP_SPIM0_MISO_PIN      26     // SPI Master In Slave Out GPIO pin number
    #define SER_APP_SPIM0_SS_PIN        23     // SPI Slave Select GPIO pin number
    #define SER_APP_SPIM0_RDY_PIN       25     // SPI READY GPIO pin number
    #define SER_APP_SPIM0_REQ_PIN       24     // SPI REQUEST GPIO pin number
    // serialization CONNECTIVITY board
    #define SER_CON_RX_PIN              24    // UART RX pin number.
    #define SER_CON_TX_PIN              23    // UART TX pin number.
    #define SER_CON_CTS_PIN             25    // UART Clear To Send pin number. Not used if HWFC is set to false.
    #define SER_CON_RTS_PIN             2     // UART Request To Send pin number. Not used if HWFC is set to false.
    #define SER_CON_SPIS_SCK_PIN        27    // SPI SCK signal.
    #define SER_CON_SPIS_MOSI_PIN       2     // SPI MOSI signal.
    #define SER_CON_SPIS_MISO_PIN       26    // SPI MISO signal.
    #define SER_CON_SPIS_CSN_PIN        23    // SPI CSN signal.
    #define SER_CON_SPIS_RDY_PIN        25    // SPI READY GPIO pin number.
    #define SER_CON_SPIS_REQ_PIN        24    // SPI REQUEST GPIO pin number.
    #define SER_CONN_CHIP_RESET_PIN     11    // Pin used to reset connectivity chip
    // Arduino board mappings
    #define ARDUINO_SCL_PIN             27    // SCL signal pin
    #define ARDUINO_SDA_PIN             26    // SDA signal pin
    #define ARDUINO_AREF_PIN            2     // Aref pin
    #define ARDUINO_13_PIN              25    // Digital pin 13
    #define ARDUINO_12_PIN              24    // Digital pin 12
    #define ARDUINO_11_PIN              23    // Digital pin 11
    #define ARDUINO_10_PIN              22    // Digital pin 10
    #define ARDUINO_9_PIN               20    // Digital pin 9
    #define ARDUINO_8_PIN               19    // Digital pin 8
    #define ARDUINO_7_PIN               18    // Digital pin 7
    #define ARDUINO_6_PIN               17    // Digital pin 6
    #define ARDUINO_5_PIN               16    // Digital pin 5
    #define ARDUINO_4_PIN               15    // Digital pin 4
    #define ARDUINO_3_PIN               14    // Digital pin 3
    #define ARDUINO_2_PIN               13    // Digital pin 2
    #define ARDUINO_1_PIN               12    // Digital pin 1
    #define ARDUINO_0_PIN               11    // Digital pin 0
    #define ARDUINO_A0_PIN              3     // Analog channel 0
    #define ARDUINO_A1_PIN              4     // Analog channel 1
    #define ARDUINO_A2_PIN              28    // Analog channel 2
    #define ARDUINO_A3_PIN              29    // Analog channel 3
    #define ARDUINO_A4_PIN              30    // Analog channel 4
    #define ARDUINO_A5_PIN              31    // Analog channel 5
    //digital pin
    #define BUZZER          25
    #define Magnetic        24
    #define Piezo           23 //ultrasonic pin
    #define UVC_LED         22
    #ifdef __cplusplus
    #endif // PCA10040_H
    Testing the project I see some issues. I see that for instance if only doing single clicks, every single single click is ignored. Adding more logging I see that the timeout handle for the click count timer then runs repeatedly with the click count 0. First of all, it should probably be a single shot timer instead of a repeated timer. But even so, there is something fishy making the click count 0.
    This issue does not seem related to the app_timer itself, but rather some issue with the logic. I did not spot all issues, though, so it still does not work. I suspect it would be better to take out just the click detection code (single click, double click, long click) so that you get an overview and make that work separately. That should not be a big task, so it may be better to just start that from scratch, and copy it to your app when you know it is working.
  • Hello, Einar
    I think this problem has been solved well.
    Actually, I don't understand what's wrong with it yet, but when I double-click, I think it's the problem that the long-click timer calls twice. So I fixed the problem by preventing the long-click timer from being called when double-click.
    I will try more to see if there is a better solution.
    Thank you very much for your help!
