Hello
I am using sdk v17.0 and nrf52832.
I'm using two timers through a button.
1. Timer for click & double-click. (Single Timer)
2. Timer for Long Press. (Repeated Timer)
Using them separately is not a problem, but if I use them together, It stop when I double-click. I checked by debugging, but no error occurred. (I think it stopped at the RTC.)
static void PairLED_timer_handler(void * p_context) //when advertising toggle led
nrf_gpio_pin_toggle(Pairing_LED); //toggle led
uint32_t press_time; //press time count
uint32_t press_time2; //press time count
int click_count; //click count(use double click)
bool buttonTimeout = false; //use double click
static void PowerOff_timer_handler(void * p_context)
press_time++;
printf("COUNT : %d\n", press_time);
if(press_time == 2) //press 2sec, Power Off
printf("Power Off!\n");
//nrf_gpio_pin_clear(POWER_SW); //LOW : power off
static void DoubleClick_timer_handler(void * p_context)
//printf("Timeout\n");
printf("%d\n", click_count);
buttonTimeout = true;
if(click_count == 1)
printf("One Click\n");
click_count = 0;
static void timers_init(void)
ret_code_t err_code;
// Initialize timer module.
err_code = app_timer_init();
//Create Pairing LED timers/
err_code = app_timer_create(&m_PairLED_timerid,
APP_TIMER_MODE_REPEATED,
PairLED_timer_handler);
//Create Power off Time timers/
err_code = app_timer_create(&m_PowerOff_timer_id,
PowerOff_timer_handler);
//Create DOuble Click Time timers/
err_code = app_timer_create(&m_DoubleClick_timer_id,
APP_TIMER_MODE_SINGLE_SHOT,
DoubleClick_timer_handler);
static void PairLED_timers_start()
err_code = app_timer_start(m_PairLED_timerid, APP_TIMER_TICKS(1000), NULL); //Toggle 1sec
printf("Scanning Start\n");
static void PairLED_timers_stop() //Stop Timer
err_code = app_timer_stop(m_PairLED_timerid);
static void PowerOff_timers_start()
err_code = app_timer_start(m_PowerOff_timer_id, APP_TIMER_TICKS(1000), NULL); //count 1sec
static void PowerOff_timers_stop()
//printf("No Power Off\n");
press_time = 0; //count reset
err_code = app_timer_stop(m_PowerOff_timer_id);
static void DoubleClick_timers_start()
err_code = app_timer_start(m_DoubleClick_timer_id, APP_TIMER_TICKS(500), NULL);
static void DoubleClick_timers_stop() //Stop Timer
err_code = app_timer_stop(m_DoubleClick_timer_id);
//printf("Stop Timer\n");
static uint32_t pressed_time, released_time, pressed_duration = 0;
static bool pressed_cnt= false;
static uint32_t app_button_duration(void) //press time
pressed_duration = (released_time - pressed_time)*2; //ms
return pressed_duration;
static void app_button_init_time_variable(void)
pressed_duration = 0; //press time
static void app_button_event_generator(void) //button press time
app_button_init_time_variable();
static void app_button_event_handler(uint8_t pin_no, uint8_t button_action)
switch (pin_no)
case BUTTON_1:
switch (button_action)
case APP_BUTTON_PUSH:
//printf("Button pressed\n");
//get pressed time
/*pressed_time = app_timer_cnt_get()*1000/32768;//milli-sec
NRF_LOG_INFO("pressed_time: %d", (int)pressed_time);
printf("pressed_time: %d\n", (int)pressed_time);
pressed_cnt = true; */
if(click_count == 0) //first click
DoubleClick_timers_start(); //buttonTimeout = true, click_count = 0;
PowerOff_timers_start(); //press time count
click_count++;
case APP_BUTTON_RELEASE:
//printf("Button releaed\n");
PowerOff_timers_stop();
/*if (pressed_cnt)
released_time = app_timer_cnt_get()*1000/32768; //milli-sec
NRF_LOG_INFO("released_time: %d", (int)released_time);
printf("released_time: %d\n", (int)released_time);
click_state = 0;
pressed_cnt = false; */
if(click_count == 2 && !buttonTimeout) //double click
DoubleClick_timers_stop();
click_count = 0;
printf("Double Click\n");
} break;
APP_ERROR_HANDLER(pin_no);
if(app_button_duration())
app_button_event_generator();
static void app_buttons_init(void)
uint32_t err_code;
static const app_button_cfg_t app_buttons[BUTTONS_NUMBER] =
{BUTTON_1, false, BUTTON_PULL, app_button_event_handler},
err_code = app_button_init((app_button_cfg_t *)app_buttons,
BUTTONS_NUMBER, // 1
APP_TIMER_TICKS(50)); //debounce
Could you tell me the cause of this problem?
Thank you!
