Why I use TIMER1 in demo "ble_uart" and encounter error "NRF_BREAKPOINT_COND"
Hi engineers,
This is my timer init code. I place it before functions timers_init() and ble_stack_init().
#include "tim.h"
#include "led.h"
const nrf_drv_timer_t TIMER_SAMPLE = NRF_DRV_TIMER_INSTANCE(0);
 * @brief Handler for timer events.
void timer_led_event_handler(nrf_timer_event_t event_type, void* p_context)
    switch (event_type)
        case NRF_TIMER_EVENT_COMPARE0:
            led1_toggle();
            //Do nothing.
void tim_init(void)
    uint32_t time_ms = 500; //Time(in miliseconds) between consecutive compare events.
    uint32_t time_ticks;
    uint32_t err_code = NRF_SUCCESS;
    //Configure TIMER_SAMPLE for generating simple light effect - leds on board will invert his state one after the other.
    timer_cfg.frequency          = (nrf_timer_frequency_t)9;
    timer_cfg.mode               = (nrf_timer_mode_t)0;
    timer_cfg.bit_width          = (nrf_timer_bit_width_t)0;
    timer_cfg.interrupt_priority = 7;
    timer_cfg.p_context          = NULL;
    err_code = nrf_drv_timer_init(&TIMER_SAMPLE, &timer_cfg, timer_led_event_handler);
    time_ticks = nrf_drv_timer_ms_to_ticks(&TIMER_SAMPLE, time_ms);
    nrf_drv_timer_extended_compare(
         &TIMER_SAMPLE, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
    nrf_drv_timer_enable(&TIMER_SAMPLE);
app_init() includes led and timer init function.
/**@brief Application main function.
    bool erase_bonds;
    ringbuffer_init();
    app_init();//include led and timer init code
    // Initialize.
    //uart_init();
    //log_init();
    //buttons_leds_init(&erase_bonds);
    //power_management_init();
    timers_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    //printf("\r\nUART started.\r\n");
    //NRF_LOG_INFO("Debug logging for UART over RTT started.");
    advertising_start();
    // Enter main loop.
    for (;;)
        //idle_state_handle();
Cheers,
Sean
    TIMER0 is reserved to the Softdevice, so please try one of the other TIMER instances. E.g., const nrf_drv_timer_t TIMER_SAMPLE = NRF_DRV_TIMER_INSTANCE(1); //TIMER1
    Vidar
    Softdevice - System on Chip resource requirements
  • Hi Vidar,
    Thanks for your reply! It works, and I change the default configuration shown as below.
    I think the previous default frequency is too high(16MHz), so I cannot see the led blinks.
    #include "tim.h"
    #include "led.h"
    const nrf_drv_timer_t TIMER_LED = NRF_DRV_TIMER_INSTANCE(1);
        switch (event_type)
            case NRF_TIMER_EVENT_COMPARE1:
                led1_toggle();
                //Do nothing.
    void tim_init(void)
        //Configure TIMER_LED for generating simple light effect - leds on board will invert his state one after the other.
        nrf_drv_timer_config_t timer_cfg = //NRF_DRV_TIMER_DEFAULT_CONFIG;
            .frequency          = (nrf_timer_frequency_t)4,     /* 1MHz */
            .mode               = (nrf_timer_mode_t)0,          /* Timer mode */
            .bit_width          = (nrf_timer_bit_width_t)3,     /* 32 bit */
            .interrupt_priority = 7,
            .p_context          = NULL,
        err_code = nrf_drv_timer_init(&TIMER_LED, &timer_cfg, timer_led_event_handler);
        time_ticks = nrf_drv_timer_ms_to_ticks(&TIMER_LED, time_ms);
             &TIMER_LED, NRF_TIMER_CC_CHANNEL1, time_ticks, NRF_TIMER_SHORT_COMPARE1_CLEAR_MASK, true);
        nrf_drv_timer_enable(&TIMER_LED);
    Cheers,
    Sean
