sd_ble_gap_addr_set is the correct way to change device real MAC ?
Hi, I try to change my MAC address, but return error code 8.
API void set_dev_mac(uint8_t * mac){
    ble_gap_addr_t p_addr;
    ret_code_t err_code = sd_ble_gap_addr_get(&p_addr);
    p_addr.addr_type = BLE_GAP_ADDR_TYPE_RANDOM_STATIC;
    for(int i=0; i<6;i++)
        p_addr.addr[5-i]=mac[i];
    p_addr.addr[5] = 0xfd;// 0xC0; //ensure MSB 2BIT is 11 for BT MAC format
    char sname[24];
    sprintf(sname,  "Set mac:%02X%02X%02X%02X%02X%02X", p_addr.addr[5],p_addr.addr[4],p_addr.addr[3],p_addr.addr[2],p_addr.addr[1],p_addr.addr[0]);
    NRF_LOG_INFO("MAC :%s",sname);
    NRF_LOG_FLUSH();
    err_code = sd_ble_gap_addr_set(&p_addr);
    if( err_code != NRF_SUCCESS ){
        NRF_LOG_INFO("Set MAC FAILE:%d",err_code);
00> <info> app: MAC :Set mac:FD3456ABCDEF
00>
00> <info> app: Set MAC FAILE:8
check error code 8 is :
#define NRF_ERROR_INVALID_STATE               (NRF_ERROR_BASE_NUM + 8)  ///< Invalid state, operation disallowed in this state
So I try set the mac address after ble connected. and the function sd_ble_gap_addr_set retrun success, and try use sd_ble_gap_addr_get is what my last set.
But after device reboot ,  MAC change back to the origin Nordic random MAC address!!!
The usage of sd_ble_gap_addr_set is the correct way to change device real MAC ?
BR.
    The address must be set with sd_ble_gap_addr_set() before you start start advertising or enter a connection, otherwise it will return error 8 (NRF_ERROR_INVALID_STATE) as you experienced.
     This is as excepted. The Softdevice will not store the address you provide in persistent memory, so you have to call sd_ble_gap_addr_set() with your address on every reboot (unless you want to use the device's random address)
    Vidar
