Zephyr version: 2.4.99
OS: Linux
Board : nrf9160dk
I am trying to read data on UART 1 with interrupt. I have below shown portion in my code for enabling UART 1. (I am keeping UART0 for debugging, printk/printf)
const struct uart_config uart_cfg = {
.baudrate = 9600,
.parity = UART_CFG_PARITY_NONE,
.stop_bits = UART_CFG_STOP_BITS_1,
.data_bits = UART_CFG_DATA_BITS_8,
.flow_ctrl = UART_CFG_FLOW_CTRL_NONE,
f_uart = device_get_binding(DT_LABEL(DT_ALIAS(fuart)));
if (f_uart == NULL) {
printf("NB-IoT UART could not be enabled!\n");
return;
ret = uart_configure(f_uart, &uart_cfg);
if (ret != 0) {
printf("UART can not be configured!\n");
uart_irq_rx_disable(f_uart);
uart_irq_tx_disable(f_uart);
uart_irq_callback_set(f_uart, uart_callback_fn);
uart_irq_rx_enable(f_uart);
DTS file has below change:
* These aliases are provided for compatibility with samples */
aliases {
led0 = &led0;
led1 = &led1;
led2 = &led2;
led3 = &led3;
pwm-led0 = &pwm_led0;
sw0 = &button2;
sw1 = &button3;
sw2 = &button0;
sw3 = &button1;
fuart = &fuart;
fuart: &uart1 {
status = "okay";
current-speed = <9600>;
tx-pin = <1>;
rx-pin = <0>;
rts-pin = <14>;
cts-pin = <15>;
Prj.conf file is:
CONFIG_UART_1_ASYNC=y CONFIG_UART_ASYNC_API=y CONFIG_UART_INTERRUPT_DRIVEN=y CONFIG_UART_1_NRF_HW_ASYNC=y CONFIG_UART_1_NRF_HW_ASYNC_TIMER=2
UART Callback function
void uart_callback_fn(const struct device *dev, void *user_data)
ARG_UNUSED(user_data);
uart_irq_update(dev);
if (uart_irq_rx_ready(dev)) {
rx_len = uart_fifo_read(dev, &rx_buf[0], 350);
//printf("%s", rx_buf[0]);
I am sending data of approx 350 bytes from nrf52840dk to nrf9160dk. I do not want to use DMA as we have variable length of receiving data, but we can know the end of the data by a special character . The issue I am facing is My uart_callback_fn() is called for every byte received; uart_fifo_read() is not reading all the data at once. What I have observed is
- Even though I give 350 as 3rd param in uart_fifo_read(), it only reads 1 byte. This is due to read function implementation in uart_nrfx_uarte.c file which gets bounded in device_get_binding. The function only reads 1 byte. How can I not bind uart_nrfx_uarte.c ? How can I bind uart_nrfx_uart.c which has implementation of reading multiple bytes. What are the Kconfigs for this? I tried defining " compatible = "nordic,nrf-uart" " in DTS file but did not work.
- I also observed that only partial data was received. I suspect that might be due to buffer size. How can I increase the buffer size. I can neither find API nor Kconfig for this.
- There are some Kconfig like CONFIG_UART_NRFX_UARTE1 which are not given in Zephyr documentation. How can I know all other Kconfigs specific to nrf series Soc?
Thanks in advance!
