Hi Nordic,
I am testing the sensor LSM9DS1 with the nrf52840. I try to make one pin attach to handle the interruption for the FIFO full interrupt.The FIFO handling function is"uint8_t read_out_FIFO_float(void)" in line No.41 to No.53. But I find in the FIFO handling it did not finish all the logs, seems line 46 to 49 is not running correctly. Could you please help to check? I have attached my code here.
the code is based on the example of "ble_app_uart_peripheral"
//reference
//https://github.com/cypresssemiconductorco/mtb-example-btsdk-sensorhub
//https://github.com/drvrh/nRF52-DK-and-LSM9DS1/blob/master/main.c
void lsm9ds1_niklas_fifo_setup(void)
uint32_t ret;
uint8_t value;
lsm9ds1_fifo_mode_set(&dev_ctx_imu, LSM9DS1_STREAM_TO_FIFO_MODE);
lsm9ds1_fifo_stop_on_wtm_set(&dev_ctx_imu, 28);
lsm9ds1_pin_int1_route_t value_set;
value_set.int1_drdy_xl=1;
value_set.int1_drdy_g =1;
value_set.int1_boot =1;
value_set.int1_fth =0;
value_set.int1_ovr =1;
value_set.int1_fss5 =0;
value_set.int1_ig_xl =0;
value_set.int1_ig_g =0;
lsm9ds1_pin_int1_route_set(&dev_ctx_imu, value_set); // need to check the LSM9DS1documentation
lsm9ds1_pin_int1_route_get(&dev_ctx_imu, &value_set);
value=(value_set.int1_drdy_xl<<7)+(value_set.int1_drdy_g <<6)+(value_set.int1_boot <<5)+ (value_set.int1_fth <<4)+(value_set.int1_ovr <<3)+(value_set.int1_fss5 <<2)+(value_set.int1_ig_xl <<1)+value_set.int1_ig_g ;
#ifdef DEBUG_FIFO_SIZE_INSIDE
printf("i1_r_s= %02x\n", value); nrf_delay_ms(1);
lsm9ds1_fifo_watermark_set(&dev_ctx_imu, 28);
value=0;
lsm9ds1_fifo_watermark_get(&dev_ctx_imu, &value);
printf("wtm= %02x \n", value); nrf_delay_ms(1);
uint8_t i=0;
uint8_t k=0;
uint8_t unread_size;
lsm9ds1_fifo_data_level_get(&dev_ctx_imu, &unread_size);
printf("P1:%d", unread_size);nrf_delay_ms(10);
return unread_size;
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
printf("INTC\n");nrf_delay_ms(1);
//read_out_FIFO_float();
printf("P1:%d", unread_size);nrf_delay_ms(1);
static void interrupt_pin_init(void)
ret_code_t err_code;
nrf_drv_gpiote_in_config_t in_config =GPIOTE_RAW_CONFIG_IN_SENSE_LOTOHI(true);// GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
in_config.pull = NRF_GPIO_PIN_PULLDOWN;//NRF_GPIO_PIN_PULLUP;
err_code = nrf_drv_gpiote_in_init(PIN_INTERRUPT, &in_config, in_pin_handler);
nrf_drv_gpiote_in_event_enable(PIN_INTERRUPT, true);
In the below is the main function code part
bool erase_bonds;
//Initialize.
uart_init();
log_init();
//bsp_board_init(BSP_INIT_LEDS);
timers_init();
//buttons_leds_init(&erase_bonds);
interrupt_pin_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
// Start execution.
printf("\r\nUART started.\r\n");nrf_delay_ms(1);
advertising_start();
uint8_t sample_data;
bool detected_device = false;
uint32_t ret;
printf("\r\n SPI started.\r\n");nrf_delay_ms(1);
spi_init();
sensor_reset();
//Initialize inertial sensors (IMU) driver interface
dev_ctx_mag.write_reg = platform_write;
dev_ctx_mag.read_reg = platform_read;
dev_ctx_mag.handle = (void*)&spi_add_mag;
// Initialize magnetic sensors driver interface
dev_ctx_imu.write_reg = platform_write;
dev_ctx_imu.read_reg = platform_read;
dev_ctx_imu.handle = (void*)&spi_add_imu;
// Check device ID
lsm9ds1_dev_id_get(&dev_ctx_mag, &dev_ctx_imu, &whoamI);
nrf_delay_ms(1);
printf("who imu= %X\n",whoamI.imu);nrf_delay_ms(1);//nrf_delay_ms(1);//app_uart_flush();
printf("who mag= %X\n",whoamI.mag);nrf_delay_ms(1);//nrf_delay_ms(1);//app_uart_flush();
if (whoamI.imu != LSM9DS1_IMU_ID || whoamI.mag != LSM9DS1_MAG_ID){
while(1){
printf("\r\nCannot find the LSM9DS1.********\r\n");nrf_delay_ms(1000);
sensor_reset();
printf("Who am I register [IMU]: 0x%x [MAG]: 0x%x \r\n\n", whoamI.imu, whoamI.mag); nrf_delay_ms(1);//app_uart_flush();
printf(" L0 \r\n");nrf_delay_ms(1);
//Restore default configuration
lsm9ds1_dev_reset_set(&dev_ctx_mag, &dev_ctx_imu, PROPERTY_ENABLE);
printf(" L1 \r\n");nrf_delay_ms(1);
do {
lsm9ds1_dev_reset_get(&dev_ctx_mag, &dev_ctx_imu, &rst);
printf("rst =:0x%x \r\n", rst); nrf_delay_ms(500);
} while (rst);
printf(" L2 \r\n");nrf_delay_ms(1);
//Enable Block Data Update
lsm9ds1_block_data_update_set(&dev_ctx_mag, &dev_ctx_imu, PROPERTY_ENABLE);
printf(" L3 \r\n");nrf_delay_ms(1);
//Set full scale
lsm9ds1_xl_full_scale_set(&dev_ctx_imu, LSM9DS1_4g);
lsm9ds1_gy_full_scale_set(&dev_ctx_imu, LSM9DS1_2000dps);
lsm9ds1_mag_full_scale_set(&dev_ctx_mag, LSM9DS1_16Ga);
printf(" L4 \r\n");nrf_delay_ms(1);
//Configure filtering chain - See datasheet for filtering chain details
//Accelerometer filtering chain
lsm9ds1_xl_filter_aalias_bandwidth_set(&dev_ctx_imu, LSM9DS1_AUTO);
lsm9ds1_xl_filter_lp_bandwidth_set(&dev_ctx_imu, LSM9DS1_LP_ODR_DIV_50);
lsm9ds1_xl_filter_out_path_set(&dev_ctx_imu, LSM9DS1_LP_OUT);
printf(" L5 \r\n");nrf_delay_ms(1);
//Gyroscope filtering chain
lsm9ds1_gy_filter_lp_bandwidth_set(&dev_ctx_imu, LSM9DS1_LP_ULTRA_LIGHT);//LSM9DS1_LP_STRONG);//
lsm9ds1_gy_filter_hp_bandwidth_set(&dev_ctx_imu, LSM9DS1_HP_MEDIUM);
lsm9ds1_gy_filter_out_path_set(&dev_ctx_imu, LSM9DS1_LPF1_HPF_LPF2_OUT);
printf(" L6 \r\n");nrf_delay_ms(1);
//Set Output Data Rate / Power mode
lsm9ds1_imu_data_rate_set(&dev_ctx_imu, LSM9DS1_IMU_59Hz5);
//lsm9ds1_imu_data_rate_set(&dev_ctx_imu, LSM9DS1_IMU_952Hz);
lsm9ds1_mag_data_rate_set(&dev_ctx_mag, LSM9DS1_MAG_UHP_10Hz);
//lsm9ds1_mag_data_rate_set(&dev_ctx_mag, LSM9DS1_MAG_LP_1000Hz);
printf(" L7 \r\n");nrf_delay_ms(1);
lsm9ds1_niklas_fifo_setup();
for (;;)
printf("\r\n1088\n");//nrf_delay_ms(1);
idle_state_handle();
printf("\r\n1090\n");//nrf_delay_ms(1);
Thank you in advance.
