questions about go into the interruption handle function
Hi Nordic,
I am testing the sensor LSM9DS1 with the nrf52840. I try to make one pin attach to handle the interruption for the FIFO full interrupt.The FIFO handling function is"uint8_t read_out_FIFO_float(void)" in line No.41 to No.53.  But I find in the FIFO handling it did not finish all the logs, seems line 46 to 49 is not running correctly. Could you please help to check? I have attached my code here.
the code is based on the example of "ble_app_uart_peripheral"
//reference
//https://github.com/cypresssemiconductorco/mtb-example-btsdk-sensorhub
//https://github.com/drvrh/nRF52-DK-and-LSM9DS1/blob/master/main.c
void lsm9ds1_niklas_fifo_setup(void)
	uint32_t ret;
        uint8_t value;
	lsm9ds1_fifo_mode_set(&dev_ctx_imu, LSM9DS1_STREAM_TO_FIFO_MODE);
	lsm9ds1_fifo_stop_on_wtm_set(&dev_ctx_imu,  28);
	lsm9ds1_pin_int1_route_t value_set;
        value_set.int1_drdy_xl=1;
        value_set.int1_drdy_g =1;
        value_set.int1_boot   =1;
        value_set.int1_fth    =0;
        value_set.int1_ovr    =1;
        value_set.int1_fss5   =0;
        value_set.int1_ig_xl  =0;
        value_set.int1_ig_g   =0;
	lsm9ds1_pin_int1_route_set(&dev_ctx_imu, value_set); // need to check the LSM9DS1documentation
        lsm9ds1_pin_int1_route_get(&dev_ctx_imu, &value_set);
        value=(value_set.int1_drdy_xl<<7)+(value_set.int1_drdy_g <<6)+(value_set.int1_boot <<5)+ (value_set.int1_fth <<4)+(value_set.int1_ovr <<3)+(value_set.int1_fss5 <<2)+(value_set.int1_ig_xl  <<1)+value_set.int1_ig_g ;
        #ifdef DEBUG_FIFO_SIZE_INSIDE
        printf("i1_r_s= %02x\n", value);  nrf_delay_ms(1);
        lsm9ds1_fifo_watermark_set(&dev_ctx_imu, 28);
        value=0;
        lsm9ds1_fifo_watermark_get(&dev_ctx_imu, &value);
        printf("wtm= %02x \n", value);  nrf_delay_ms(1);
  uint8_t i=0;
  uint8_t k=0;
  uint8_t unread_size;
  lsm9ds1_fifo_data_level_get(&dev_ctx_imu, &unread_size);
   printf("P1:%d", unread_size);nrf_delay_ms(10);
  return unread_size;
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
  printf("INTC\n");nrf_delay_ms(1);
  //read_out_FIFO_float();
   printf("P1:%d", unread_size);nrf_delay_ms(1);
static void interrupt_pin_init(void)
    ret_code_t err_code;
    nrf_drv_gpiote_in_config_t in_config =GPIOTE_RAW_CONFIG_IN_SENSE_LOTOHI(true);// GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
    in_config.pull = NRF_GPIO_PIN_PULLDOWN;//NRF_GPIO_PIN_PULLUP;
    err_code = nrf_drv_gpiote_in_init(PIN_INTERRUPT, &in_config, in_pin_handler);
    nrf_drv_gpiote_in_event_enable(PIN_INTERRUPT, true);
In the below is the main function code part
    bool erase_bonds;
    //Initialize.
    uart_init();
    log_init();
    //bsp_board_init(BSP_INIT_LEDS);
    timers_init();
    //buttons_leds_init(&erase_bonds);
    interrupt_pin_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    printf("\r\nUART started.\r\n");nrf_delay_ms(1);
    advertising_start();
    uint8_t sample_data;
    bool detected_device = false;
    uint32_t ret;
    printf("\r\n SPI started.\r\n");nrf_delay_ms(1);
    spi_init();
    sensor_reset();
    //Initialize inertial sensors (IMU) driver interface
    dev_ctx_mag.write_reg = platform_write;
    dev_ctx_mag.read_reg = platform_read;
    dev_ctx_mag.handle = (void*)&spi_add_mag;
    // Initialize magnetic sensors driver interface
    dev_ctx_imu.write_reg = platform_write;
    dev_ctx_imu.read_reg = platform_read;
    dev_ctx_imu.handle = (void*)&spi_add_imu;
    // Check device ID
    lsm9ds1_dev_id_get(&dev_ctx_mag, &dev_ctx_imu, &whoamI);
	nrf_delay_ms(1);
        printf("who imu= %X\n",whoamI.imu);nrf_delay_ms(1);//nrf_delay_ms(1);//app_uart_flush();
	printf("who mag= %X\n",whoamI.mag);nrf_delay_ms(1);//nrf_delay_ms(1);//app_uart_flush();
    if (whoamI.imu != LSM9DS1_IMU_ID || whoamI.mag != LSM9DS1_MAG_ID){
      while(1){
        printf("\r\nCannot find the LSM9DS1.********\r\n");nrf_delay_ms(1000);
        sensor_reset();
    printf("Who am I register [IMU]: 0x%x [MAG]: 0x%x \r\n\n", whoamI.imu, whoamI.mag);  nrf_delay_ms(1);//app_uart_flush();
     printf("                 L0 \r\n");nrf_delay_ms(1);
     //Restore default configuration
     lsm9ds1_dev_reset_set(&dev_ctx_mag, &dev_ctx_imu, PROPERTY_ENABLE);
     printf("                 L1 \r\n");nrf_delay_ms(1);
     do {
      lsm9ds1_dev_reset_get(&dev_ctx_mag, &dev_ctx_imu, &rst);
      printf("rst =:0x%x \r\n", rst);  nrf_delay_ms(500);
    } while (rst);
     printf("                 L2 \r\n");nrf_delay_ms(1);
    //Enable Block Data Update
    lsm9ds1_block_data_update_set(&dev_ctx_mag, &dev_ctx_imu, PROPERTY_ENABLE);
     printf("                 L3 \r\n");nrf_delay_ms(1);
    //Set full scale
    lsm9ds1_xl_full_scale_set(&dev_ctx_imu, LSM9DS1_4g);
    lsm9ds1_gy_full_scale_set(&dev_ctx_imu, LSM9DS1_2000dps);
    lsm9ds1_mag_full_scale_set(&dev_ctx_mag, LSM9DS1_16Ga);
    printf("                 L4 \r\n");nrf_delay_ms(1);
    //Configure filtering chain - See datasheet for filtering chain details
    //Accelerometer filtering chain
    lsm9ds1_xl_filter_aalias_bandwidth_set(&dev_ctx_imu, LSM9DS1_AUTO);
    lsm9ds1_xl_filter_lp_bandwidth_set(&dev_ctx_imu, LSM9DS1_LP_ODR_DIV_50);
    lsm9ds1_xl_filter_out_path_set(&dev_ctx_imu, LSM9DS1_LP_OUT);
    printf("                 L5 \r\n");nrf_delay_ms(1);
    //Gyroscope filtering chain
    lsm9ds1_gy_filter_lp_bandwidth_set(&dev_ctx_imu, LSM9DS1_LP_ULTRA_LIGHT);//LSM9DS1_LP_STRONG);//
    lsm9ds1_gy_filter_hp_bandwidth_set(&dev_ctx_imu, LSM9DS1_HP_MEDIUM);
    lsm9ds1_gy_filter_out_path_set(&dev_ctx_imu, LSM9DS1_LPF1_HPF_LPF2_OUT);
    printf("                 L6 \r\n");nrf_delay_ms(1);
    //Set Output Data Rate / Power mode
    lsm9ds1_imu_data_rate_set(&dev_ctx_imu, LSM9DS1_IMU_59Hz5);
    //lsm9ds1_imu_data_rate_set(&dev_ctx_imu, LSM9DS1_IMU_952Hz);
    lsm9ds1_mag_data_rate_set(&dev_ctx_mag, LSM9DS1_MAG_UHP_10Hz);
    //lsm9ds1_mag_data_rate_set(&dev_ctx_mag, LSM9DS1_MAG_LP_1000Hz);
    printf("                 L7 \r\n");nrf_delay_ms(1);
    lsm9ds1_niklas_fifo_setup();
    for (;;)
        printf("\r\n1088\n");//nrf_delay_ms(1);
        idle_state_handle();
        printf("\r\n1090\n");//nrf_delay_ms(1);
Thank you in advance.
