Programming nRF52 DK in C++ in Segger Embedded Studio
Hi.
I am writing software for my custom nRF52832 device but hardware wise it is identical to the nRF52 DK.
I'm not that good of an embedded coder (or any kind of coder for that matter) and I am trying to integrate some i2c sensors on my device.
But all the libraries of these sensors are written in C++, and are using objects and classes. Which C doesn't support.
I have managed to convert *some* of the code (in probably a very inefficient way) to plain C, but most of the code is beyond my capabilities.
How can I code with C++ on this thing using Segger Embedded Studio?
Any help would be greatly appreciated.
- Usman
  • Hi Torbjørn. Thanks for the information.
    I did just that and got a plethora of  errors.
    How do I fix these?
    Best regards
    Usman
  • Hi Usman
    Which example are you using?
    Unfortunately many of the API's in the SDK, including several of the BLE API's, don't support C++. As such the standard example will not build in C++, unless you move the BLE functionality out of the main file and into a separate C file (that you can then call from the main.cpp file).
    Best regards
    Torbjørn
  • Hi Torbjørn.
    Thanks for the insight. It makes a lot of sense, since I'm using ble_app_uart example as a base.
    So what I should do is, make a main.cpp file, put my non BLE code into it, rename the old main.c file into something else, and call the .c file in my main.cpp file?
    Usman
  • Hi Torbjørn
    I did this, now my code is like this, but it shows the exact same errors.
    If I remove #include "c_file.c" from the top, and mainx() in the main function, then it compiles. But now with them. What am I doing wrong here?
    #include <stdint.h>
    #include <stdbool.h>
    #include <string.h>
    #include "c_file.c"
        mainx();
    Thanks, and regards,
    Usman
  • Hi Usman
    First off you shouldn't include a C file from another C file. Instead you need to create a header file (c_file.h essentially) that contains the function prototypes for the functions in c_file.c that you need to access, and include this header file only from main.c.
    Also, in this file I would suggest splitting the code into a couple of independent functions for doing things such as:
    - Initializing the Bluetooth stack
    - Starting advertising
    - Sending or receiving data from a connected device
    - anything else that your application needs to do over Bluetooth
    In the end your main file could look something like this:
    static void on_ble_event(app_ble_event_t *event)
        switch(event->type)
            case APP_BLE_EVT_DATA_RECEIVED:
            case APP_BLE_EVT_CONNECTED:
            // And any other events you need to send back to the main function
        app_ble_initialize(/*Arguments here*/);
        app_ble_set_callback(on_ble_event);
        app_ble_start_advertising();
        // Main loop
        while(1)
            // If you have something to do repeatedly in the main loop in c_file.c then you can call it from here:
            app_ble_execute();
    Hopefully this makes sense?
    Please note that my pseudo code suggestion above is not the only way to do it, but I think it's a good way to move the details of configuring and managing the Bluetooth stack into a separate file (I think it's a good idea to do this even if you don't need to compile your project for C++).
    Best regards
    Torbjørn
