Programming nRF52 DK in C++ in Segger Embedded Studio
Hi.
I am writing software for my custom nRF52832 device but hardware wise it is identical to the nRF52 DK.
I'm not that good of an embedded coder (or any kind of coder for that matter) and I am trying to integrate some i2c sensors on my device.
But all the libraries of these sensors are written in C++, and are using objects and classes. Which C doesn't support.
I have managed to convert *some* of the code (in probably a very inefficient way) to plain C, but most of the code is beyond my capabilities.
How can I code with C++ on this thing using Segger Embedded Studio?
Any help would be greatly appreciated.
- Usman
  • Hi Torbjørn.
    Thanks for the correction. I did exactly as you told, but it still gives the same old errors
    I even tried removing ALL code from the cpp file and just put a printf( ) just to see if that works, but doesn't compile either. At this point, I think its more of a configuration issue, but I could be wrong.
    Any guidance would be highly appreciated.
    Regards
    Usman
  • Hi Usman
    Did you move all the instance definitions at the top of main.c into the separate file?
    They should look something like this:
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    These macros will not compile in C++, and they will also have to be available to the rest of the BLE code if you move this into a separate file.
    Best regards
    Torbjørn
  • Hi Torbjørn
    Yes, I tried that as well. But no good.
    And so I tried to compile them with just printf( ) in it and here's what my files look like:
    main.cpp:
    #include "c_file.h"
        func();
    c_file.h:
    #ifndef CFile_H
    #define CFILE_H
    #include <stdbool.h>
    #include <stdint.h>
    #include <string.h>
    int func();
    c_file.c:
    #ifndef CFile_C
    #define CFILE_C
    #include <stdint.h>
    #include <string.h>
    int func()
        printf("this c file");
        return 0;
    And it gives me this error: undefined reference to `func()'
    Am I doing something wrong here?
    Regards
    Usman
  • Hi Usman
    Good point, I forgot to mention this. Every header file that defines functions that you need to include in a C++ file needs to use the extern "C" header, otherwise they won't be visible to the C++ linker.
    If you open any of the standard header files in the SDK you can spot this.
    Essentially they will have the following somewhere at the top of the header file (after any includes but before any defines or function prototypes):
    #ifdef __cplusplus
    extern "C" {
    And then the following at the bottom of the file (before the final #endif):
    #ifdef __cplusplus
    Best regards
    Torbjørn
  • Hi Torbjørn
    After a few attempts, I finally managed to get this working
    and it compiled.
    So I put in my original code in these files, and now it returns the same old error.
    expected constructor, destructor, or type conversion before '(' token
    How could it be that it is compiling the simple .c file inside the .cpp file perfectly, but as soon as I add my other code to the .c file, it fails to compile? The my code in original .c file itself was compiling and working perfectly.
