I am trying to measure distance with a vl53l1x sensor through the twi_sensor example.
I uploaded the code to segger by referring to sparkfun, but twi_handler does not work. It seems to be a problem because the write function and the read function are used incorrectly, but I don't know what's wrong. why!
This is sparkfun_arduino library code.
VL53L1X_ERROR VL53L1X::VL53L1_WrByte(VL53L1_DEV Dev, uint16_t index, uint8_t data)
int status;
//VL53L1_I2CWrite(uint8_t dev, uint16_t index, uint8_t *data, uint16_t number_of_bytes);
status = VL53L1_I2CWrite(Dev->I2cDevAddr, index, &data, 1);
return status;
VL53L1X_ERROR VL53L1X::VL53L1_RdWord(VL53L1_DEV Dev, uint16_t index, uint16_t *data)
int status;
uint8_t buffer[2] = {0, 0};
//VL53L1_I2CRead(uint8_t dev, uint16_t index, uint8_t *data, uint16_t number_of_bytes);
status = VL53L1_I2CRead(Dev->I2cDevAddr, index, buffer, 2);
if (!status)
*data = (buffer[0] << 8) + buffer[1];
return status;
VL53L1X_ERROR VL53L1X::VL53L1_I2CWrite(uint8_t DeviceAddr, uint16_t RegisterAddr, uint8_t *pBuffer, uint16_t NumByteToWrite)
#ifdef DEBUG_MODE
Serial.print("Beginning transmission to ");
Serial.println(((DeviceAddr) >> 1) & 0x7F);
dev_i2c->beginTransmission(((uint8_t)(((DeviceAddr) >> 1) & 0x7F)));
#ifdef DEBUG_MODE
Serial.print("Writing port number ");
Serial.println(RegisterAddr);
uint8_t buffer[2];
buffer[0] = RegisterAddr >> 8;
buffer[1] = RegisterAddr & 0xFF;
dev_i2c->write(buffer, 2);
for (int i = 0; i < NumByteToWrite; i++)
dev_i2c->write(pBuffer[i]);
dev_i2c->endTransmission(true);
return 0;
VL53L1X_ERROR VL53L1X::VL53L1_I2CRead(uint8_t DeviceAddr, uint16_t RegisterAddr, uint8_t *pBuffer, uint16_t NumByteToRead)
int status = 0;
//Loop until the port is transmitted correctly
uint8_t maxAttempts = 5;
for (uint8_t x = 0; x < maxAttempts; x++)
#ifdef DEBUG_MODE
#ifdef DEBUG_MODE
uint8_t buffer[2];
status = dev_i2c->endTransmission(false);
if (status == 0)
//Fix for some STM32 boards
//Reinitialize th i2c bus with the default parameters
#ifdef ARDUINO_ARCH_STM32
if (status)
dev_i2c->end();
dev_i2c->begin();
//End of fix
dev_i2c->requestFrom(((uint8_t)(((DeviceAddr) >> 1) & 0x7F)), (byte)NumByteToRead);
int i = 0;
while (dev_i2c->available())
pBuffer[i] = dev_i2c->read();
i++;
return 0;
This is my code.
static uint8_t m_sample[2];
__STATIC_INLINE void data_handler(uint8_t newValue)
NRF_LOG_INFO("New value: %d ", newValue);
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
NRF_LOG_INFO("handler!");
switch (p_event->type)
case NRF_DRV_TWI_EVT_DONE:
if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
data_handler(m_sample);
void twi_init (void)
ret_code_t err_code;
const nrf_drv_twi_config_t twi_vl53l1x_config = {
.scl = ARDUINO_SCL_PIN, //ORANGE 27
.sda = ARDUINO_SDA_PIN, //RED 26
.frequency = NRF_DRV_TWI_FREQ_400K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false
err_code = nrf_drv_twi_init(&m_twi, &twi_vl53l1x_config, twi_handler, NULL);
nrf_drv_twi_enable(&m_twi);
VL53L1X_ERROR VL53L1_WrByte(uint16_t reg, uint8_t p_tx_data)
uint8_t tx_data[3];
tx_data[0] = ( (reg >> 8)& 0xFF );
tx_data[1] = reg & 0xFF;
tx_data[2] = p_tx_data;
err_code = nrf_drv_twi_tx(&m_twi, VL53L1X_ADDR, tx_data, sizeof(tx_data), false);
return err_code;
VL53L1X_ERROR VL53L1_RdWord(uint16_t reg, uint16_t *p_rx_data)
ret_code_t ret_code;
uint8_t addr_data[2];
addr_data[0] = (reg >> 8) & 0xFF;
addr_data[1] = reg & 0xFF;
ret_code = nrf_drv_twi_tx(&m_twi, VL53L1X_ADDR, addr_data, sizeof(addr_data), false);
if(ret_code != NRF_SUCCESS)
NRF_LOG_INFO("TWI RdWord NRF_SUCCESS FAIL");
return ret_code;
ret_code = nrf_drv_twi_rx(&m_twi, VL53L1X_ADDR, m_sample, sizeof(m_sample));
*p_rx_data = (uint16_t) ( (m_sample[0] << 8) | m_sample[1] );
return *p_rx_data;
NRF_LOG_INFO("\r\nTWI sensor example started.");
NRF_LOG_FLUSH();
twi_init();
while (true)
startRanging();
nrf_delay_ms(1000);
while(!checkForDataReady())
nrf_delay_ms(1000);
clearInterrupt();
stopRanging();
NRF_LOG_INFO("%d==============", cnt);
int distance = getDistance();
NRF_LOG_INFO("Distance : %d ", distance);
//for(uint32_t i = 0; i < 2; i++)
// printf("%d = 0x%02X \n",i, m_sample[i] );
NRF_LOG_FLUSH();
When I build and check through SerialPort, twi_handler does not come over and "TWI RdWord NRF_SUCCESS FAIL" comes out.
Why does the result come out like this?
Where is it wrong? Please let me know ㅠㅠ
