[nRF52832] Central, ble_nus_chars_received_uart_print
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
    ret_code_t ret_val;
    printf("Receiving data.");
    app_uart_put("receiving data.\r");
    NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
    for (uint32_t i = 0; i < data_len; i++)
        do
            ret_val = app_uart_put(p_data[i]);
            if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
                printf("app_uart_put failed for index 0x%04x.", i);
                APP_ERROR_CHECK(ret_val);
        } while (ret_val == NRF_ERROR_BUSY);
    if (p_data[data_len-1] == '\r')
        while (app_uart_put('\n') == NRF_ERROR_BUSY);
    if (ECHOBACK_BLE_UART_DATA)
        // Send data back to the peripheral.
        do
            ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
                printf("Failed sending NUS message. Error 0x%x. ", ret_val);
Hi
using sdk17, softdevice132...
There are some parts of the central implementation that I don't understand.
It is based on cle_uart_app_c.
Isn't the function bl_nus_chars_received_outprint_print_called when connected?
There is no action when associated with peripheral.
  • Have you ever config NUS service UUID with peripherial & central?  ble_nus_c_evt_handler() will handle tx
    static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
    ret_code_t err_code;
    switch (p_ble_nus_evt->evt_type)
    case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
    NRF_LOG_INFO("Discovery complete.");
    err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
    err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
    NRF_LOG_INFO("Connected to device with Nordic UART Service.");
    case BLE_NUS_C_EVT_NUS_TX_EVT:
    ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
    case BLE_NUS_C_EVT_DISCONNECTED:
    NRF_LOG_INFO("Disconnected.");
    scan_start();
    Here you are.
  • I have this handler.
    If BLE_NUS_C_EVT_NUS_TX_EVT is called, isn't the DATA transmitted?
    But I don't think this handler is being called.
    Peripheral was made using nRF52810.
    This is not what I made.
                printf("Discovery complete.");
                printf("Connected to device with Nordic UART Service.");
                printf("BLE_NUS_C_EVT_NUS_TX_EVT\n");
                printf("Disconnected.");
                scan_start();
                printf("client evt handler\r");
    I have this nus handler...
    The ble_nus_chars_received_uart_print() function is not called when a peripheral is connected, it is only called when the peripheral transfers some data to the central (through notifications). If you are testing towards the ble_app_uart example, connect a serial terminal to the board and write a string after the devices have established a connection. This string will be sent over NUS to the central, which will print it on its own serial terminal/UART connection.
    The TX part of the event (BLE_NUS_C_EVT_NUS_TX_EVT) may be a bit confusing, but it is indicating that the central received data from the peripheral.
    Jørgen
