APP GLOBAL DEF for class
Hi everyone,
Is there a function like APP_USBD_CDC_ACM_GLOBAL_DEF or APP_USBD_MSC_GLOBAL_DEF that allow to define a custom class?
I want to define a custom class using app function but in the nordic infocenter I didn't find any function like APP_USBD_CUSTOM_CLASS_GLOBAL_DEF.
BR
Sorry for my english but I'm sweden,
    No, unfortunately its not. If you want to setup your own app usbd class, you have to develop such a library.
    I want to define a custom class using app function ( high level library, as is done in CDC ACM example) but in the nordic infocenter I didn't find any function like APP_USBD_CUSTOM_CLASS_GLOBAL_DEF.
     If you want to do that, you should look into how the subsystem works:
    https://infocenter.nordicsemi.com/topic/sdk_nrf5_v17.0.2/lib_usbd.html?cp=7_1_3_56
    If you want to setup your own usb class/custom descriptor, I can also recommend looking at the usbd example in the sdk:
    nRF5_SDK_17.0.2_d674dde/examples/peripheral/usbd
    This uses the driver directly, and exposes most low-level usb specific functionality.
    Håkon
  • If you want to setup your own usb class/custom descriptor, I can also recommend looking at the usbd example in the sdk:
    Yes I started from USBD example and I setup my own class device. The problem is that I have a composite device (CDC ACM and custom class device). To init CDC ACM I use app_init, to init custom class device I use nrf_drv_usbd_init()...
    The problem is that there's a conflict and I don't know how to solve it.
