Do You have a recommended LFXO 32.768 kHz crystal oscillators parts list ?
Best regards
Best regards
Hi, we do not recommend any specific brand, but anyone that matches the spec in the reference layout should be fine.
| X2 | 32.768 kHz | XTAL SMD 2012, 32.768 kHz, CI=9 pF, ±50 ppm | XTAL_2012 |
Hi, I found more detailed spec here : https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.nrf52832.ps.v1.1/clock.html?cp=4_2_0_18_3_3#unique_1385509760
There are mainly mentioned only max values. About frequency tolerance all is more or less clear.
But do You have recommended values for following parameters (or at least min. value):
| Symbol |
Description |
Min. | Typ. | Max. | Units | ||||
| CL_LFXO |
Load capacitance |
12.5 | pF | ||||||
| C0_LFXO |
Shunt capacitance |
2 | pF | ||||||
| RS_LFXO |
Equivalent series resistance |
100 | kohm | ||||||
| PD_LFXO |
Drive level |
1 | uW |
As for drive level to be on safe side it looks like that there is only one option - 1uW
It's as simple as you have to make sure you don't exceed the maximum values.
For the drive level, the maximum level the oscillator can drive the crystal is 1 µW. So the crystal must be able to handle at least this.
