nRF libUART transmit data from read only memory
I am using libUARTE and libUARTE ASYNC for reliable communication over UART.
I need to transmit data that is stored in read only memory but this module seems to only support transmitting data from read/writable memory. Is there any way to do this other then to make a copy of all the data to another location?
I am using existing code that I should not be changing and it stores a bunch of predefined data packets in read only memory. I could probably change the linker script to store my constant data in read/write memory but that is not a great solution either.
It seems very odd that this module doesn't support transmitting data from constant data (I've never experienced an SDK like this). I'm sure someone had a reason for implementing it this way, I am curious as to why?
If I pass the data from read only memory then nothing gets written out the UART.
Any advice is much appreciated!
Liam
I am using:
SDK: nRF SDK 17.0.2
Device: nRF52840
Compiler: armgcc
