How to manage SAADC and BLE run in parallel
 I'm trying to send ADC data through BLE using nRF52840.
 According to the example codes named ble_peripheral/ble_app_uart, peripheral/saadc, I wrote a code and it is able to transmit the data.
 But the problem is that the throughput is about 850 kbps, which is much lower than I expected. When I ran the throughput demo, it was able to get 1M(conn_interval =7.5ms)~1.3M(conn_interval=400ms) bps.
 So I wonder whether one of the ADC sampling or BLE task becomes a bottleneck as I aligned them in a serial way like the below code.
        ret_code_t err_code;
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
        //SEGGER_RTT_WriteString(0, "saadc_callback function\n");
        saadc2ble_convert();
        uint16_t length = (uint16_t)(SAMPLES_IN_BUFFER * 2);
        //SEGGER_RTT_WriteString(0, "Trying to send data.\n");
        notification_err_code = ble_nus_data_send(&m_nus, adc_output, &length, m_conn_handle);
        //sprintf(error_string, "Error number: %#x\n", notification_err_code);
        //SEGGER_RTT_WriteString(0, error_string);
        if ((notification_err_code != NRF_ERROR_INVALID_STATE) &&
                    (notification_err_code != NRF_ERROR_RESOURCES) &&
                    (notification_err_code != NRF_ERROR_NOT_FOUND))
            APP_ERROR_CHECK(notification_err_code);
 For now, ble_nus_data_send() is called every time when the SAADC buffer is full.
 Will there be some advances if I save the ADC samples in a kind of buffer and call ble_nus_data_send() several times when the data are collected?
