app_timer start/stop fragile for being triggered from interrupt context
Hello there,
During my development I have discovered an issue with app_timer library. It is fragile for calling stop/start functions from interrupts which has higher priority than app_timer. This results in missing some timers interrupts - which may be crucial (like in my case - since I have a communication watchdog based on app_timer).  Here is the code taken from file app_timer2.c with my comments:
static void timer_req_process(drv_rtc_t const * const  p_instance)
    nrf_atfifo_item_get_t fifo_ctx;
    timer_req_t *         p_req = nrf_atfifo_item_get(m_req_fifo, &fifo_ctx);
    while (p_req)
        switch (p_req->type)
            case TIMER_REQ_START:
                if (!p_req->p_timer->active)
// my input->       < place where an interrupt may trigger problems >
                    p_req->p_timer->active = true;
                    nrf_sortlist_add(&m_app_timer_sortlist, &(p_req->p_timer->list_item));
                    NRF_LOG_INST_DEBUG(p_req->p_timer->p_log,"Start request (expiring at %d/0x%08x).",
                                                  p_req->p_timer->end_val, p_req->p_timer->end_val);
            case TIMER_REQ_STOP:
                if (p_req->p_timer == mp_active_timer)
                    mp_active_timer = NULL;
                    bool found = nrf_sortlist_remove(&m_app_timer_sortlist, &(p_req->p_timer->list_item));
                    if (!found)
                         NRF_LOG_INFO("Timer not found on sortlist (stopping expired timer).");
// my input->   v solution proposition
// my input->   p_req->p_timer->active = false;
                NRF_LOG_INST_DEBUG(p_req->p_timer->p_log,"Stop request.");
            case TIMER_REQ_STOP_ALL:
                sorted_list_stop_all();
                m_global_active = true;
                NRF_LOG_INFO("Stop all request.");
So, there is a chance that `p_req->p_timer->active` variable is set to false by app_timer_stop call during timer activation in `case TIMER_REQ_START:`. This may lead to serious issues.
My question is - is it going to be fixed in the future or do I have to make some permanent workaround for this (for example such like shown in `case TIMER_REQ_STOP:`)?
I am using SDK 16.0
