Status and approach for PA/LNA Support in BLE/Thread Concurrent Multiprotocol
I am migrating to the Fanstel BT840XE module with nRF52840 and a Skyworks PA/LNA.  I need some assistance in getting my PA/LNA working in a multiprotocol setup.
I have successfully implemented and tested the Softdevice portion of PA/LNA control for BLE, and tested it on my custom hardware platform.  I confirmed operation using a BLE-only example from the SDK and confirmed the transmit power is indeed higher when the PA/LNA flag is set -- I think this demonstrates my code is correct and hardware is working.
My actual multiprotocol project implements the same BLE PA/LNA setup tested above (code snippets below).  I have *not yet* implemented any PA/LNA control for Thread.
1. At this point, I would expect my BLE advertisements would be send with higher power with the PA/LNA enabled, but they are not.  Is the multiprotocol usage somehow defeating the PA/LNA initialization I am doing?
2. What is the recommended approach to PA/LNA in a BLE/Thread multiprotocol concurrent project?
DETAILS:
My project uses concurrent BLE/Thread Multiprotocol with nRF5_SDK_for_Thread_and_Zigbee_3.1.0_c7c4730 and S140 6.1.1.
My custom board file includes the following section for PA/LNA and transmit power:
#define APP_PA_LNA
// This board has a Power Amplifier and LNA  "APP_PA_LNA" will trigger main to initialize it.
#ifdef APP_PA_LNA
#define APP_PA_PIN      17
#define APP_LNA_PIN     19
#define APP_CHL_PIN	8
#define APP_CPS_PIN	6
#endif //APP_PA_LNA
#define MAX_BLE_XMIT_PWR_DBM  0   //Fanstel BT840XE max transmit power from radio IC is +2dBm.  PA adds 21dBm!  Use with 0dBm gain antenna max for FCC/IC.
#define THREAD_POWER 0    // <i> Transmit Power (in dBm) used by Thread.
In main, after softdevice init, I configure the PA/LNA:
    ble_stack_init();
    // set up PA/LNA if present - NOTE: must be done after softdevice is enabled.
    #ifdef APP_PA_LNA
	nrf_gpio_cfg_output(APP_CPS_PIN);
	nrf_gpio_cfg_output(APP_CHL_PIN);
	nrf_gpio_pin_set(APP_CHL_PIN);
	nrf_gpio_pin_clear(APP_CPS_PIN); //enable
	pa_lna_init(APP_PA_PIN,APP_LNA_PIN);
Here is my PA/LNA init code:
#include "fanstel_pa_lna.h"
#include "nrf_assert.h"
#include "nrf_log.h"
#include "ble.h"
#include "app_error.h"
#include "nrf_drv_gpiote.h"
#include "nrf_drv_ppi.h"
void pa_lna_init(uint32_t gpio_pa_pin, uint32_t gpio_lna_pin)
    ble_opt_t opt;
    uint32_t gpiote_ch = NULL;
    ret_code_t err_code;
    memset(&opt, 0, sizeof(ble_opt_t));
    if(err_code != NRF_ERROR_INVALID_STATE)
    //if(err_code != MODULE_ALREADY_INITIALIZED)
    nrf_ppi_channel_t ppi_set_ch;
    nrf_ppi_channel_t ppi_clr_ch;
    err_code = nrf_drv_ppi_channel_alloc(&ppi_set_ch);
    err_code = nrf_drv_ppi_channel_alloc(&ppi_clr_ch);
    nrf_drv_gpiote_out_config_t config = GPIOTE_CONFIG_OUT_TASK_TOGGLE(false);
    if((gpio_pa_pin == NULL) && (gpio_lna_pin == NULL))
        err_code = NRF_ERROR_INVALID_PARAM;
    if(gpio_pa_pin != NULL)
        if(gpiote_ch == NULL)
            err_code = nrf_drv_gpiote_out_init(gpio_pa_pin, &config);
            gpiote_ch = nrf_drv_gpiote_out_task_addr_get(gpio_pa_pin);
        // PA config
        opt.common_opt.pa_lna.pa_cfg.active_high = 1;   // Set the pin to be active high
        opt.common_opt.pa_lna.pa_cfg.enable      = 1;   // Enable toggling
        opt.common_opt.pa_lna.pa_cfg.gpio_pin    = gpio_pa_pin; // The GPIO pin to toggle tx
    if(gpio_lna_pin != NULL)
            err_code = nrf_drv_gpiote_out_init(gpio_lna_pin, &config);
            gpiote_ch = nrf_drv_gpiote_out_task_addr_get(gpio_lna_pin);
        // LNA config
        opt.common_opt.pa_lna.lna_cfg.active_high  = 1; // Set the pin to be active high
        opt.common_opt.pa_lna.lna_cfg.enable       = 1; // Enable toggling
        opt.common_opt.pa_lna.lna_cfg.gpio_pin     = gpio_lna_pin;  // The GPIO pin to toggle rx
    // Common PA/LNA config
    opt.common_opt.pa_lna.gpiote_ch_id  = (gpiote_ch - NRF_GPIOTE_BASE) >> 2;   // GPIOTE channel used for radio pin toggling
    opt.common_opt.pa_lna.ppi_ch_id_clr = ppi_clr_ch;   // PPI channel used for radio pin clearing
    opt.common_opt.pa_lna.ppi_ch_id_set = ppi_set_ch;   // PPI channel used for radio pin setting
    err_code = sd_ble_opt_set(BLE_COMMON_OPT_PA_LNA, &opt);
    if (err_code == NRF_SUCCESS)
        NRF_LOG_INFO("PA/LNA Successfully Enabled");
    return;
When I start advertising, I set the radio transmit power using the power level defined in the board file:
#define BLE_GAP_ADV_POWER               MAX_BLE_XMIT_PWR_DBM                    /**< BLE Transmit power to use for advertising, in dBm. */
    // NORDIC: SET TX POWER FOR ADVERTISING
    err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, BLE_GAP_ADV_POWER);
    err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    // We don't have a good way of knowing current adv state, so ignore the error
    if ((err_code != NRF_SUCCESS) )  //&& (err_code != NRF_ERROR_INVALID_STATE))
    NRF_LOG_INFO("advertising is started");
  • You may have discovered a bug here.
    The softdevice does the cleanup of settings on few peripherals before ends its timeslot and gives the control to different Radio timeslot. Based on your description and code, it is possible that it might have cleaned incorrectly.
    Since I cannot see anything wrong with your code snippets, could you help me reproduce this on my desk by giving me a minimalistic project? Trust me, if I can reproduce it here, it goes much faster than me trying to guess what could be wrong.
  • Yes, I will try to do this today, however, I think we need to agree on a hardware platform (I am assuming you don't have a Fanstel BT840XE).  I could allocate PA/LNA pins to GPIO on a PCA so you could observe them toggling on an oscilloscope.  Or do you have another idea?
  • I decided to go with PCA10056 and configured a fake PA/LNA as follows:
    #define APP_PA_PIN 28
    #define APP_LNA_PIN 29
    #define APP_CHL_PIN 30
    #define APP_CPS_PIN 31
    Rather than stripping down my own project, I decided to start with another multiprotocol example:  ble_thread_dyn_eddystone_pca10056_s140 to produce a minimalist implementation.
    I have been so far *unable to recreate my own issue* with this setup.  Probing pin 28 with a scope, I clearly see the 3 PA pulses coincident with each advertisement.  I confirmed the device was active on the Thread network using the CLI.
    On Monday, I will go back to my custom project and board, but redirect the PA/LNA control signals to accessible GPIO.  I'll get back to you as soon as I know more.
    Thanks!
  • Thanks for doing your part of experiments to confirm that you see no issue with hardware .
     Sure, Good luck Bob.
  • I think I found the problem.  The OpenThread library uses Pin 0.06 and 0.08 for the Thread CLI UART0.
