receive UDP on nRF9160-dk SLM application
I want to receive UPD message on my nRF9160-DK.
I can send UDP messages from my Nordic device to a server and from that messages I get the public IP address of my module. But when I try to receive messages, I don't receive anything.
I use the serial LTE modem application.
I see the following links to send messages:
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/applications/serial_lte_modem/doc/TCPIP_AT_commands.html#udp-receive-data-xrecvfrom
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/applications/serial_lte_modem/doc/slm_description.html
First try:
AT#XSOCKET=1,2,0
#XSOCKET: 1, 2, 0, 17
OK
AT#XSENDTO="x.x.x.x",20080,1,"Test UDP"
#XSENDTO: 8
OK
AT#XSOCKET=0
#XSOCKET: 0, closed
OK
AT#XSOCKET=1,2,1
#XSOCKET: 1, 2, 1, 17
OK
AT#XBIND=3442
OK
AT#XRECVFROM
and after this I get: "Error: 'AT#XRECVFROM' timed out"  and I cannot send AT command to LTE Link Monitor.
Second try:
AT#XSOCKET=1,2,0
OK
#XSENDTO: 8
OK
AT#XSOCKET=0
#XSOCKET: 0, closed
OK
AT#XSOCKET=1,2,1
OK
AT#UDPRECVFROM="x.x.x.x",3442
+CME: 0
Here I don't know how to solve this error.
Third try:
I set the UDP proxy to use the command AT#XUDPSVR;
So in "Configure nRF Connect SDK Project" I select "Stateful connection-oriented UDP client/server <SLM_UDP_PROXY>"
AT#XUDPCLI=1,"x.x.x.x",20080
#XUDPCLI: 1 connected
OK
%CESQ: 32,1,19,2
%CESQ: 29,1,24,3
AT#XUDPSEND=1,"Test UDP"
#XUDPSEND: 8
OK
AT#XUDPCLI=0
#XUDPCLI: disconnected
OK
AT#XUDPSVR=1,3442 or AT#XUDPSVR=2,3442
#XUDPSVR: 1 started
OK
Here it seems to work but I don't receive anything and retrying I get sometimes: "Error: 'AT#XUDPSVR=1,3442 ' timed out"
I try using the IP that I get in the receiving messages and also with the IP that I get with the command "AT+CGDCONT?"
I try also using the example script "client_udp.py" but nothing.
I try many times with all possible combinations.
What can I do? The nRF9160-DK receives messages but doesn't print them on the LTE Link Monitor or I'm using wrong AT command? Is there an error in the client code? Is the IP that I use the error? Is it possible that my server doesn't know how to reach my APN even if I specify the correct public IP address?
Please, help me to receive a simple "hello".
Thank you in advance.
Best regards
    I've had a quick look at your traces so far, and I have noticed two things:
    1. Neither the IP address or the source port (from the device) matches your screenshot from the server. Are you sure the screenshot is from the nRF9160?
    2. The modem never receives an recvfrom RPC call from the application core.
    To debug 2 further, could you enable debug logging in the SLM (by setting CONFIG_SLM_LOG_LEVEL=y), and capture the debug log which will be sent over RTT (as well as the UART log and a modem trace)?
    But, the device never receives the reply from the server, so even if the recvfrom call had been there, you still wouldn't have seen any response.
    1. I believe that the messages are sent by my device because when I send messages from nRF9160 they appear on the node-red debug messages window (as in the screeshot). However to be sure is there an at command to get the IP address of my nRF9160?
    2. Debug:
    I didn't find CONFIG_SLM_LOG_LEVEL=y so I guess you mean CONFIG_SLM_LOG_LEVEL_DBG=y (I hope it's correct).
    For the debugging I also set in the prj.config file:
    CONFIG_USE_SEGGER_RTT=n
    CONFIG_RTT_CONSOLE=n
    CONFIG_UART_CONSOLE=y
    CONFIG_LOG_BACKEND_RTT=n
    CONFIG_LOG_BACKEND_UART=y
    I attached the zip with modem trace bin, terminal of Termite, logfile of LTE Link Monitor and the prj.config file
    nRF9160 log.rar
  • Usually, neither the local ip-address your nRF9160 nor the local port you use will be visible at the server. The mobile provider mostly use a NAT, which exchanges that address and port. And because of that NAT, you must respond "in time". I would try to start with less than 30s.
     Yes, sorry. That was a typo on my part.
    I also forgot to mention that you have to comment out the CONFIG_SLM_LOG_LEVEL_INF=y line (or replace it with *_DBG=y).
    I have also done some more tests myself, and it doesn't seem like the recvfrom call actually gets registered in the modem trace unless it returns some data.
    So the 2nd point in my last comment doesn't seem to be an actual problem, just another indication that the device never receives the response.
     AT+CGDCONT?
    But, it is worth noting what says about NAT.
  • Hi ,
    Could you try the following sequence of commands (with the same server and port)?
    AT+CEREG=5
    AT+CSCON=1
    AT+CFUN=1
    // Wait for the nRF9160 to be connected (CEREG 1 or 5)
    AT#XSOCKET=1,2,0
    AT#XSENDTO="84.215.43.232",56227,1,"<some text here>"
    AT#XRECVFROM
    You should then end up with a log similar to this (if you have enabled debug logging):
    *** Booting Zephyr OS build v2.4.0-ncs1  ***
    Ready
    [00:00:00.231,994] <inf> app: Serial LTE Modem
    [00:00:00.232,177] <dbg> at_host: TX
    52 65 61 64 79 0d 0a                             |Ready..
    [00:00:00.232,177] <dbg> at_host.slm_at_host_init: at_host init done
    at+cereg=5
    OK
    [00:00:06.317,932] <dbg> at_host: RX
    61 74 2b 63 65 72 65 67  3d 35                   |at+cereg =5
    [00:00:06.318,450] <dbg> at_host.uart_callback: RX_DISABLED
    [00:00:06.328,948] <dbg> at_host: TX
    [00:00:06.329,010] <dbg> at_host: TX
    4f 4b 0d 0a                                      |OK..
    at+cscon=1
    OK
    [00:00:09.456,085] <dbg> at_host: RX
    61 74 2b 63 73 63 6f 6e  3d 31                   |at+cscon =1
    [00:00:09.456,604] <dbg> at_host.uart_callback: RX_DISABLED
    [00:00:09.466,735] <dbg> at_host: TX
    [00:00:09.466,796] <dbg> at_host: TX
    4f 4b 0d 0a                                      |OK..
    at+cfun=1
    OK
    [00:00:12.772,094] <dbg> at_host: RX
    61 74 2b 63 66 75 6e 3d  31                      |at+cfun= 1
    [00:00:12.772,613] <dbg> at_host.uart_callback: RX_DISABLED
    [00:00:12.844,238] <dbg> at_host: TX
    [00:00:12.844,299] <dbg> at_host: TX
    4f 4b 0d 0a                                      |OK..
    +CEREG: 2,"76C1","014A3901",7,0,0,"11100000","11100000"
    +CSCON: 1
    [00:00:14.167,694] <dbg> at_host: TX
    2b 43 45 52 45 47 3a 20  32 2c 22 37 36 43 31 22 |+CEREG:  2,"76C1"
    2c 22 30 31 34 41 33 39  30 31 22 2c 37 2c 30 2c |,"014A39 01",7,0,
    30 2c 22 31 31 31 30 30  30 30 30 22 2c 22 31 31 |0,"11100 000","11
    31 30 30 30 30 30 22 0d  0a                      |100000". .
    [00:00:14.195,556] <dbg> at_host: TX
    2b 43 53 43 4f 4e 3a 20  31 0d 0a                |+CSCON:  1..
    +CEREG: 5,"76C1","014A3901",7,,,"00000010","00000110"
    [00:00:16.082,397] <dbg> at_host: TX
    2b 43 45 52 45 47 3a 20  35 2c 22 37 36 43 31 22 |+CEREG:  5,"76C1"
    2c 22 30 31 34 41 33 39  30 31 22 2c 37 2c 2c 2c |,"014A39 01",7,,,
    22 30 30 30 30 30 30 31  30 22 2c 22 30 30 30 30 |"0000001 0","0000
    30 31 31 30 22 0d 0a                             |0110"..
    at+cgdcont?
    +CGDCONT: 0,"IP","ibasis.iot","10.160.177.45",0,0
    OK
    [00:00:18.583,740] <dbg> at_host: RX
    61 74 2b 63 67 64 63 6f  6e 74 3f                |at+cgdco nt?
    [00:00:18.584,259] <dbg> at_host.uart_callback: RX_DISABLED
    [00:00:18.595,428] <dbg> at_host: TX
    2b 43 47 44 43 4f 4e 54  3a 20 30 2c 22 49 50 22 |+CGDCONT : 0,"IP"
    2c 22 69 62 61 73 69 73  2e 69 6f 74 22 2c 22 31 |,"ibasis .iot","1
    30 2e 31 36 30 2e 31 37  37 2e 34 35 22 2c 30 2c |0.160.17 7.45",0,
    30 0d 0a                                         |0..
    [00:00:18.599,945] <dbg> at_host: TX
    4f 4b 0d 0a                                      |OK..
    at#xsocket=1,2,0
    OK
    [00:00:24.831,848] <dbg> at_host: RX
    61 74 23 78 73 6f 63 6b  65 74 3d 31 2c 32 2c 30 |at#xsock et=1,2,0
    [00:00:24.832,366] <dbg> at_host.uart_callback: RX_DISABLED
    [00:00:24.842,163] <dbg> at_host: TX
    23 58 53 4f 43 4b 45 54  3a 20 31 2c 20 32 2c 20 |#XSOCKET : 1, 2,
    30 2c 20 31 37 0d 0a                             |0, 17..
    [00:00:24.842,163] <dbg> tcpip.do_socket_open: Socket opened
    [00:00:24.844,238] <dbg> at_host: TX
    4f 4b 0d 0a                                      |OK..
    +CSCON: 0
    [00:00:27.609,008] <dbg> at_host: TX
    2b 43 53 43 4f 4e 3a 20  30 0d 0a                |+CSCON:  0..
    at#xsendto="84.215.43.232",56227,1,"didrik port test"
    #XSENDTO: 16
    OK
    +CSCON: 1
    [00:00:30.552,490] <dbg> at_host: RX
    61 74 23 78 73 65 6e 64  74 6f 3d 22 38 34 2e 32 |at#xsend to="84.2
    31 35 2e 34 33 2e 32 33  32 22 2c 35 36 32 32 37 |15.43.23 2",56227
    2c 31 2c 22 64 69 64 72  69 6b 20 70 6f 72 74 20 |,1,"didr ik port
    74 65 73 74 22                                   |test"
    [00:00:30.552,825] <dbg> tcpip.parse_host_by_ipv4: IPv4 Address 84.215.43.232
    [00:00:30.552,856] <dbg> tcpip.do_udp_init: UDP initialized
    [00:00:30.553,009] <dbg> at_host.uart_callback: RX_DISABLED
    [00:00:30.561,676] <dbg> at_host: TX
    23 58 53 45 4e 44 54 4f  3a 20 31 36 0d 0a       |#XSENDTO : 16..
    [00:00:30.561,706] <dbg> tcpip.do_sendto: UDP sent
    [00:00:30.580,383] <dbg> at_host: TX
    4f 4b 0d 0a                                      |OK..
    [00:00:30.665,832] <dbg> at_host: TX
    at#xrecvfrom
    didrik port test
    #XRECVFROM: 1, 16
    OK
    [00:00:40.058,105] <dbg> at_host: RX
    61 74 23 78 72 65 63 76  66 72 6f 6d             |at#xrecv from
    [00:00:40.058,410] <dbg> at_host: TX
    64 69 64 72 69 6b 20 70  6f 72 74 20 74 65 73 74 |didrik p ort test
    [00:00:40.058,624] <dbg> at_host.uart_callback: RX_DISABLED
    [00:00:40.059,875] <dbg> at_host: TX
    0d 0a 23 58 52 45 43 56  46 52 4f 4d 3a 20 31 2c |..#XRECV FROM: 1,
    20 31 36 0d 0a                                   | 16..
    [00:00:40.059,875] <dbg> tcpip.do_recvfrom: UDP received
    [00:00:40.061,798] <dbg> at_host: TX
    4f 4b 0d 0a                                      |OK..
    +CSCON: 0
    [00:00:42.356,109] <dbg> at_host: TX
    As you can see from the log, I have verified that this server works, and I am able to communicate with it with my nRF9160DK and iBasis SIM card.
    I also have some logging running on the server, so it I can confirm that it receives the packet and sends a response.
    And, as always, if you could share the log and modem trace afterwards, that would be great.
