receive UDP on nRF9160-dk SLM application
I want to receive UPD message on my nRF9160-DK.
I can send UDP messages from my Nordic device to a server and from that messages I get the public IP address of my module. But when I try to receive messages, I don't receive anything.
I use the serial LTE modem application.
I see the following links to send messages:
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/applications/serial_lte_modem/doc/TCPIP_AT_commands.html#udp-receive-data-xrecvfrom
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/applications/serial_lte_modem/doc/slm_description.html
First try:
AT#XSOCKET=1,2,0
#XSOCKET: 1, 2, 0, 17
OK
AT#XSENDTO="x.x.x.x",20080,1,"Test UDP"
#XSENDTO: 8
OK
AT#XSOCKET=0
#XSOCKET: 0, closed
OK
AT#XSOCKET=1,2,1
#XSOCKET: 1, 2, 1, 17
OK
AT#XBIND=3442
OK
AT#XRECVFROM
and after this I get: "Error: 'AT#XRECVFROM' timed out"  and I cannot send AT command to LTE Link Monitor.
Second try:
AT#XSOCKET=1,2,0
OK
#XSENDTO: 8
OK
AT#XSOCKET=0
#XSOCKET: 0, closed
OK
AT#XSOCKET=1,2,1
OK
AT#UDPRECVFROM="x.x.x.x",3442
+CME: 0
Here I don't know how to solve this error.
Third try:
I set the UDP proxy to use the command AT#XUDPSVR;
So in "Configure nRF Connect SDK Project" I select "Stateful connection-oriented UDP client/server <SLM_UDP_PROXY>"
AT#XUDPCLI=1,"x.x.x.x",20080
#XUDPCLI: 1 connected
OK
%CESQ: 32,1,19,2
%CESQ: 29,1,24,3
AT#XUDPSEND=1,"Test UDP"
#XUDPSEND: 8
OK
AT#XUDPCLI=0
#XUDPCLI: disconnected
OK
AT#XUDPSVR=1,3442 or AT#XUDPSVR=2,3442
#XUDPSVR: 1 started
OK
Here it seems to work but I don't receive anything and retrying I get sometimes: "Error: 'AT#XUDPSVR=1,3442 ' timed out"
I try using the IP that I get in the receiving messages and also with the IP that I get with the command "AT+CGDCONT?"
I try also using the example script "client_udp.py" but nothing.
I try many times with all possible combinations.
What can I do? The nRF9160-DK receives messages but doesn't print them on the LTE Link Monitor or I'm using wrong AT command? Is there an error in the client code? Is the IP that I use the error? Is it possible that my server doesn't know how to reach my APN even if I specify the correct public IP address?
Please, help me to receive a simple "hello".
Thank you in advance.
Best regards
    Unluckily I had already tried with the IP that I got with AT+CGDCONT? and I have the same results.
    Just to let you know, I had done other test with different types of protocol of communication:
    MQTT works fine: I connect the nRF9160 to a topic of a block of NODE-RED and i can receive and send messages.
    TCP works fine only if I use the nRF9160 as client which has to connect to NODE-RED (as server). In this case I can send and receive message.
    But if I use NODE-RED as client which has to connect to nRF9160 (as server), when I use the commands AT#XLISTEN and AT#XACCEPT, nothing happens.
    I try both with the IP address of the screenshot (151.x.x.x) and with the IP address that I get with the command AT+CGDCONT? (10.x.x.x).
    I think it could be for the same reason of UDP RECVFROM.
    However I think that the correct IP address is 151.x.x.x and not 10.x.x.x.
    I found out also that in the LTE Link monitor if I got in the Log window:
     Error: 'at#xrecvfrom' timed out
    It doesn't block the code as I thought but it's still worked. I got the same error with TCP protocol and AT#XRECV but I can receive messages, too. So fine :).
    What kind of application do you use to send udp messages to nRF9160-dk? So I'll try with it, instead of NODE-RED. Probably has problem with UDP protocol.
    Now I try the commands you send me! Thank you very much! Slight smile
    I have just tried and it works. I receive my same message.
    The output file is shared.
    So the AT command works but I don't know why my NODE-RED for udp doesn't work. Could you see the IP address that is used by your server to reply to my message?
    *** Booting Zephyr OS build v2.4.0-ncs2  ***
    Ready
    [00:00:00.205,688] [1B][0m<inf> app: Serial LTE Modem[1B][0m
    [00:00:00.205,871] [1B][0m<dbg> at_host: TX
    52 65 61 64 79 0d 0a                             |Ready..          [1B][0m
    [00:00:00.205,902] [1B][0m<dbg> at_host.slm_at_host_init: at_host init done[1B][0m
    AT+CEREG=5
    OK
    [00:00:31.184,631] [1B][0m<dbg> at_host: RX
    41 54 2b 43 45 52 45 47  3d 35                   |AT+CEREG =5      [1B][0m
    [00:00:31.185,150] [1B][0m<dbg> at_host.uart_callback: RX_DISABLED[1B][0m
    [00:00:31.194,152] [1B][0m<dbg> at_host: TX[1B][0m
    [00:00:31.194,213] [1B][0m<dbg> at_host: TX
    4f 4b 0d 0a                                      |OK..             [1B][0m
    AT+CSCON=1
    OK
    [00:00:43.160,430] [1B][0m<dbg> at_host: RX
    41 54 2b 43 53 43 4f 4e  3d 31                   |AT+CSCON =1      [1B][0m
    [00:00:43.160,949] [1B][0m<dbg> at_host.uart_callback: RX_DISABLED[1B][0m
    [00:00:43.169,372] [1B][0m<dbg> at_host: TX[1B][0m
    [00:00:43.169,433] [1B][0m<dbg> at_host: TX
    AT+CFUN=1
    OK
    [00:00:55.841,583] [1B][0m<dbg> at_host: RX
    41 54 2b 43 46 55 4e 3d  31                      |AT+CFUN= 1       [1B][0m
    [00:00:55.842,102] [1B][0m<dbg> at_host.uart_callback: RX_DISABLED[1B][0m
    [00:00:55.881,561] [1B][0m<dbg> at_host: TX[1B][0m
    [00:00:55.881,622] [1B][0m<dbg> at_host: TX
    +CEREG: 2,"993A","0DC16447",9,0,0,"11100000","11100000"
    +CSCON: 1
    [00:00:59.546,997] [1B][0m<dbg> at_host: TX
    2b 43 45 52 45 47 3a 20  32 2c 22 39 39 33 41 22 |+CEREG:  2,"993A"
    2c 22 30 44 43 31 36 34  34 37 22 2c 39 2c 30 2c |,"0DC164 47",9,0,
    30 2c 22 31 31 31 30 30  30 30 30 22 2c 22 31 31 |0,"11100 000","11
    31 30 30 30 30 30 22 0d  0a                      |100000". .       [1B][0m
    [00:00:59.907,653] [1B][0m<dbg> at_host: TX
    2b 43 53 43 4f 4e 3a 20  31 0d 0a                |+CSCON:  1..     [1B][0m
    +CEREG: 1,"993A","0DC16447",9,,,"00011110","00011101"
    [00:01:02.925,445] [1B][0m<dbg> at_host: TX
    2b 43 45 52 45 47 3a 20  31 2c 22 39 39 33 41 22 |+CEREG:  1,"993A"
    2c 22 30 44 43 31 36 34  34 37 22 2c 39 2c 2c 2c |,"0DC164 47",9,,,
    22 30 30 30 31 31 31 31  30 22 2c 22 30 30 30 31 |"0001111 0","0001
    31 31 30 31 22 0d 0a                             |1101"..          [1B][0m
    +CSCON: 0
    [00:01:06.049,255] [1B][0m<dbg> at_host: TX
    2b 43 53 43 4f 4e 3a 20  30 0d 0a                |+CSCON:  0..     [1B][0m
    AT#XSOCKET=1,2,0
    OK
    [00:01:18.898,529] [1B][0m<dbg> at_host: RX
    41 54 23 58 53 4f 43 4b  45 54 3d 31 2c 32 2c 30 |AT#XSOCK ET=1,2,0[1B][0m
    [00:01:18.899,047] [1B][0m<dbg> at_host.uart_callback: RX_DISABLED[1B][0m
    [00:01:18.907,714] [1B][0m<dbg> at_host: TX
    23 58 53 4f 43 4b 45 54  3a 20 31 2c 20 32 2c 20 |#XSOCKET : 1, 2,
    30 2c 20 31 37 0d 0a                             |0, 17..          [1B][0m
    [00:01:18.907,714] [1B][0m<dbg> tcpip.do_socket_open: Socket opened[1B][0m
    [00:01:18.909,790] [1B][0m<dbg> at_host: TX
    AT#XSENDTO="84.215.43.232",56227,1,"Hi, I'm AndMar8"
    #XSENDTO: 15
    OK
    +CSCON: 1
    [00:01:43.649,810] [1B][0m<dbg> at_host: RX
    41 54 23 58 53 45 4e 44  54 4f 3d 22 38 34 2e 32 |AT#XSEND TO="84.2
    31 35 2e 34 33 2e 32 33  32 22 2c 35 36 32 32 37 |15.43.23 2",56227
    2c 31 2c 22 48 69 2c 20  49 27 6d 20 41 6e 64 4d |,1,"Hi,  I'm AndM
    61 72 38 22                                      |ar8"             [1B][0m
    [00:01:43.650,146] [1B][0m<dbg> tcpip.parse_host_by_ipv4: IPv4 Address 84.215.43.232[1B][0m
    [00:01:43.650,177] [1B][0m<dbg> tcpip.do_udp_init: UDP initialized[1B][0m
    [00:01:43.650,329] [1B][0m<dbg> at_host.uart_callback: RX_DISABLED[1B][0m
    [00:01:43.659,027] [1B][0m<dbg> at_host: TX
    23 58 53 45 4e 44 54 4f  3a 20 31 35 0d 0a       |#XSENDTO : 15..  [1B][0m
    [00:01:43.659,027] [1B][0m<dbg> tcpip.do_sendto: UDP sent[1B][0m
    [00:01:43.660,308] [1B][0m<dbg> at_host: TX
    [00:01:44.068,756] [1B][0m<dbg> at_host: TX
    +CSCON: 0
    [00:01:47.355,255] [1B][0m<dbg> at_host: TX
    AT#XRECVFROM
    Hi, I'm AndMar8
    #XRECVFROM: 1, 15
    OK
    [00:01:59.227,844] [1B][0m<dbg> at_host: RX
    41 54 23 58 52 45 43 56  46 52 4f 4d             |AT#XRECV FROM    [1B][0m
    [00:01:59.228,118] [1B][0m<dbg> at_host: TX
    48 69 2c 20 49 27 6d 20  41 6e 64 4d 61 72 38    |Hi, I'm  AndMar8 [1B][0m
    [00:01:59.228,363] [1B][0m<dbg> at_host.uart_callback: RX_DISABLED[1B][0m
    [00:01:59.229,492] [1B][0m<dbg> at_host: TX
    0d 0a 23 58 52 45 43 56  46 52 4f 4d 3a 20 31 2c |..#XRECV FROM: 1,
    20 31 35 0d 0a                                   | 15..            [1B][0m
    [00:01:59.229,522] [1B][0m<dbg> tcpip.do_recvfrom: UDP received[1B][0m
    [00:01:59.231,384] [1B][0m<dbg> at_host: TX
     It's a Rust application I have written myself, although at this point it is still mostly just one of the examples from the documentation. Below is a simplified version (fostly just fancy logging that is removed):
    fn single_udp_echo() -> std::io::Result<()> {
        let socket = std::net::UdpSocket::bind("0.0.0.0:56227")?;
        println!("Listening on socket 56227");
        let mut buf = [0; 1024];
        let (amt, src) = socket.recv_from(&mut buf)?;
        println!("Received message from {:?}", src);
        let buf = &buf[..amt];
        debug!("{}", std::str::from_utf8(&buf).unwrap());
        socket.send_to(buf, &src)?;
        Ok(())
    fn main() {
        println!("Starting UDP echo");
        loop {
            let udp_result = udp::single_udp_echo();
            println!("udp result: {:?}", udp_result);
    It is simply listening for a UDP message, printing it, and sending it back to the sender.
    Log from the server (including my own test to check that the server was up and running), timestamps are in UTC:
    [2021-03-01T13:31:10.504010113][INFO][server] Starting UDP echo
    [2021-03-01T13:31:10.504231159][INFO][server::udp] Listening on socket 56227
    [2021-03-01T13:32:10.600723109][DEBUG][server::udp] Received message from 62.93.143.64:44856
    [2021-03-01T13:32:10.601072018][DEBUG][server::udp] didrik port test
    [2021-03-01T13:32:10.601381792][WARN][server] udp result: Ok(())
    [2021-03-01T13:32:10.601632681][INFO][server::udp] Listening on socket 56227
    [2021-03-01T16:34:44.897245414][DEBUG][server::udp] Received message from 151.99.1.113:59409
    [2021-03-01T16:34:44.897544864][DEBUG][server::udp] Hi, I'm AndMar8
    [2021-03-01T16:34:44.897827920][WARN][server] udp result: Ok(())
    And .pcap:
    udp.pcap
    It is also worth noting that the log and .pcap shows NATing both in my and iBasis' networks.
    The IP address the server logs is not the same address as reported by my nRF9160, and the server's address in the .pcap is also a local address and not the one used by the devices.
     Correct. That error is reported by the Link Monitor, which has a rather short timeout for AT command responses. The error message can be useful for most AT commands, as they reply immediately. However, for commands which might take some time (such as waiting for a reply from a server), the timeout can be ignored.
    In conclusion, it seems the problem is with the NODE-RED server (or the server hits a limitation in the network). How fast does it reply to the UDP packets?
    We have often seen NAT timeouts of ~ 1 minute, but we have also seen networks where they are significantly shorter.
  • Hi Didrik!
    It works with my application (Node-Red). It was my trivial error.
    From your pcap file I understand that I have to bind the communication to the port used by the application to receive, in order to send a reply to nRF9160-dk. I thought that (with the udp protocol) it didn't matter to specify the port from which the message came out but only the destination one.
    My mistake was the following:
    nRF9160-dk sends from random port, for example 59222, to my Node-Red port 20080 a message.
    Node-Red has to send a reply from the same port 20080 to the port (in this case) 59222.
    Firstly I used a random port to send the reply from my Node-Red.
    Thank you so much for your time and your suggestion.
    I have one last question.
    If I send the AT command AT#XRECVFROM to my module, is there a AT command that allows to exit from RX mode without press the button reset? Or the only way is to change the timer in the code to stop the receive mode?
  • > Firstly I used a random port to send the reply from my Node-Red.
    That would have worked, if no NATs would be on the route. But with NATs, such traffic is blocked. The mapping contains the port as well and so from the view of the NAT there is no route back to the modem.
    That's at least what I do, and what is done in common. Therefore the setsockopt/SO_RCVTIMEO is for. Though I patched the SLM for that, I'm not sure, how to do that with AT#XSOCKETOPT/SO_RCVTIMEO.
