Data len is set to 0xF4(244) ERROR
Hello
When I send data over BLE, I got this messages in debug terminal.
<info> app: Debug logging for UART over RTT started.
<info> app: Connected
<info> app: Data len is set to 0xF4(244)
<error> app: Fatal error
I changed BLE_GATT_ATT_MTU 23 to 247 in code(static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;)
However, There was no changes.
Also, there is my connection parameters.
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(8, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(700, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3
And, the picture is call stack after <error> app : Fatal error
How can I solve this problem??
