Need FOTA Support in LWM2M firmware update object using block2 coap process.
Hi
We searched a lot of stuff regarding FOTA update in nRF52840DK using Lwm2m and coap protocol. But we could not get help in the right direction. We could not find any stuff or documentation (explanation) regarding BACKROUND_DFU in nRF16_SDK.
We already implemented firmware object and its instance callback with existing lwm2m client example. Now we want to update the firmware over the air using lwm2m and coap protocols. Please share any kind of stuff or example you have so that we can get out from this trouble
    I have looked at the log now. It looks like you are logging a bit too much or have too small buffers, as I see the log is incomplete and with some messages indicating logs have been dropped). In any case, I see a long log with logs indicating that the image is transferred (completely or not?), and then cose to the end there is a reset, and the only DFU related information is this:
    <info> background_dfu: Storing block (b:445 c:445).
    <error> nrf_dfu_req_handler: Write request too long
    <info> background_dfu: state=DFU_DOWNLOAD_FIRMWARE event=DFU_EVEare.
    I do not see any indication of attempting to post validating the app after transferring it. Do you? This thread might be relevant in that regard.
     * Copyright (c) 2017 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup background_dfu_coap_transport background_dfu_coap.c
     * @ingroup background_dfu
     * @brief Background DFU CoAP transport implementation.
    #include "background_dfu_transport.h"
    #include "coap_dfu.h"
    #include <string.h>
    #include <stdlib.h>
    #include <stdbool.h>
    #include <stdint.h>
    #include "sdk_config.h"
    #include "boards.h"
    #include "app_util.h"
    #include "app_timer.h"
    #include "app_scheduler.h"
    #include "nrf_delay.h"
    #include "nrf_error.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_dfu_settings.h"
    #include "nrf_dfu_req_handler.h"
    #include "nrf_dfu_utils.h"
    #include "nordic_common.h"
    #include "iot_errors.h"
    #include "coap_api.h"
    #include "coap_block.h"
    #include "coap_option.h"
    #include "background_dfu_block.h"
    #include "openthread/random_noncrypto.h"
    #define NRF_LOG_LEVEL 4
    #define NRF_LOG_MODULE_NAME COAP_DFU
    #include "nrf_log.h"
    NRF_LOG_MODULE_REGISTER();
    /** @brief Maximum delay (in ms) between requesting consecutive image blocks. */
    #define DEFAULT_DELAY_MAX_MS    128
    #define REALM_LOCAL_ADDR        (uint8_t []){0xff, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, \
                                                 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01}
    #ifndef DFU_DEBUG_RANDOM_INIT_BLOCK_LOSS_ENABLE
    #define DFU_DEBUG_RANDOM_INIT_BLOCK_LOSS_ENABLE  0  /**< Enable random init block loss for debugging purposes. */
    #ifndef DFU_DEBUG_RANDOM_IMAGE_BLOCK_LOSS_ENABLE
    #define DFU_DEBUG_RANDOM_IMAGE_BLOCK_LOSS_ENABLE 0  /**< Enable random image block loss for debugging purposes. */
    #ifndef DFU_DEBUG_RANDOM_BLOCK_LOSS_RATE
    #define DFU_DEBUG_RANDOM_BLOCK_LOSS_RATE         50 /**< Block loss rate, in percent.*/
    #define DFU_RESOURCE_PREFIX     "dfu"
    #define INIT_RESOURCE_NAME      "i"
    #define IMAGE_RESOURCE_NAME     "f"
    #define TRIGGER_RESOURCE_NAME   "t"
    #define DIAG_RESOURCE_NAME      "d"
    #define BITMAP_RESOURCE_NAME    "b"
    #define RESET_RESOURCE_NAME     "r"
    #define RESOURCE_PATH(name)     (DFU_RESOURCE_PREFIX "/" name)
    #define SCHED_QUEUE_SIZE      32                                                              /**< Maximum number of events in the scheduler queue. */
    #define SCHED_EVENT_DATA_SIZE MAX(sizeof(nrf_dfu_request_t), APP_TIMER_SCHED_EVENT_DATA_SIZE) /**< Maximum app_scheduler event size. */
    typedef struct
        coap_resource_t          root;            /**< Root resource. */
        coap_resource_t          prefix;          /**< Prefix resource. */
        coap_resource_t          trigger;         /**< Trigger resource. */
        coap_resource_t          init;            /**< Init resource. Used in multicast DFU transfer. */
        coap_resource_t          image;           /**< Image resource. Used in multicast DFU transfer. */
        coap_resource_t          diagnostic;      /**< Diagnostic resource. */
        coap_resource_t          reset;           /**< Reset resource. */
        coap_response_callback_t handler;         /**< A pointer to the current response handler. */
        const char             * p_resource_path; /**< Downloaded resource path on the remote host. */
        coap_remote_t            remote;          /**< Remote host from which the resource is being downloaded. */
        bool                     timer_active;    /**< True if a CoAP request is pending, false otherwise. */
    } coap_dfu_context_t;
    /** @brief Coap Message Id. */
    static uint16_t m_coap_message_id = 0;
    /** @brief CoAP token. */
    static uint16_t m_coap_token;
    /** @brief DFU client context. */
    static background_dfu_context_t m_dfu_ctx;
    static coap_dfu_context_t       m_coap_dfu_ctx;
    /** @brief Request delay timer. */
    APP_TIMER_DEF(m_send_timer);
    APP_TIMER_DEF(m_reset_timer);
    APP_TIMER_DEF(m_coap_delayed_error_handling_timer);
    static void reset_application(void)
        NRF_LOG_FINAL_FLUSH();
    #if NRF_MODULE_ENABLED(NRF_LOG_BACKEND_RTT)
        // To allow the buffer to be flushed by the host.
        nrf_delay_ms(100);
        NVIC_SystemReset();
    /** @brief Check if given address is multicast.
     *  @param[in] p_remote A pointer to the address.
     *  @return True if address is a multicast, false otherwise.
    static bool is_addr_multicast(const coap_remote_t * p_remote)
        return p_remote->addr[0] == 0xff;
     * @brief Function notifies certain events in DFU process.
    static void dfu_observer(nrf_dfu_evt_type_t evt_type)
        switch (evt_type)
            case NRF_DFU_EVT_DFU_COMPLETED:
                if (!m_dfu_ctx.reset_suppress)
                    NRF_LOG_INFO("Reset after DFU");
                    reset_application();
                    NRF_LOG_INFO("Automatic reset suppressed by the server");
     * @section Block processing
    /** @brief Parse and return CoAP Block1 option from a given message.
     *  @param[in]  p_message        A pointer to CoAP message.
     *  @param[out] p_block1_option  A pointer to parsed Block1 option.
     *  @return True if message has Block1 option, false otherwise.
    static bool get_block1_opt(const coap_message_t    * p_message,
                               coap_block_opt_block1_t * p_block1_option)
        uint32_t        err_code;
        uint8_t         option_index;
        uint32_t        option_value;
        coap_option_t * p_option;
        if (coap_message_opt_index_get(&option_index,
                                       (coap_message_t *)p_message,
                                       COAP_OPT_BLOCK1) != NRF_SUCCESS)
            return false;
        p_option = (coap_option_t *)&p_message->options[option_index];
        err_code = coap_opt_uint_decode(&option_value,
                                        p_option->length,
                                        p_option->p_data);
        if (err_code != NRF_SUCCESS)
            return false;
        err_code = coap_block_opt_block1_decode(p_block1_option, option_value);
        return (err_code == NRF_SUCCESS);
    /** @brief Parse and return CoAP block option from a given message.
     *  @param[out] p_block2_option  A pointer to parsed block 2 option.
     *  @return True if message has Block2 option, false otherwise.
    static bool get_block2_opt(const coap_message_t    * p_message,
                               coap_block_opt_block2_t * p_block2_option)
        uint32_t        err_code;
                                       COAP_OPT_BLOCK2) != NRF_SUCCESS)
            return false;
        p_option = (coap_option_t * )&p_message->options[option_index];
                                        p_option->length,
                                        p_option->p_data);
            return false;
        err_code = coap_block_opt_block2_decode(p_block2_option, option_value);
    /** @brief Set CoAP block2 option on a given message.
     *  @param[inout]  p_message    A pointer to CoAP message.
     *  @param[in]     block_size   Block size to set.
     *  @param[in]     block_number Block number to set.
     *  @return NRF_SUCCESS if succesful, error code otherwise.
    static uint32_t set_block2_opt(coap_message_t * p_message,
                                   uint16_t         block_size,
                                   uint32_t         block_number)
        uint32_t err_code;
        coap_block_opt_block2_t block2_option =
            .number = block_number,
            .size   = block_size
        err_code = coap_block_opt_block2_encode(&option_value, &block2_option);
        if (err_code == NRF_SUCCESS)
            err_code = coap_message_opt_uint_add(p_message, COAP_OPT_BLOCK2, option_value);
        return err_code;
     * @section Response handling
    /**@brief Check status and common CoAP parameters for a response.
     * @param[in] status     Status code indicating if response was received.
     * @param[in] p_response A response recevied. May be invalid if status is not NRF_SUCCESS.
     * @return True if a valid response was received, false otherwise.
    static bool is_valid_response_received(uint32_t status, const coap_message_t * p_response)
        if (status != NRF_SUCCESS)
            if (status == COAP_TRANSMISSION_TIMEOUT)
                NRF_LOG_WARNING("Request timeout");
                NRF_LOG_WARNING("Unknown error");
            return false;
        if (p_response->header.code != COAP_CODE_205_CONTENT)
            NRF_LOG_WARNING("Request response code: %d", p_response->header.code);
            return false;
        if ((p_response->header.token_len != sizeof(m_coap_token)) ||
            (memcmp(p_response->token, &m_coap_token, p_response->header.token_len) != 0))
            NRF_LOG_WARNING("Token mismatch");
            return false;
        return true;
    /**@brief CoAP response handler for request sent to a trigger resource (@ref TRIGGER_RESOURCE_NAME).
     * An implementation of @ref coap_response_callback_t function type.
    static void handle_trigger_response(uint32_t status, void * p_arg, coap_message_t * p_response)
        background_dfu_context_t * p_dfu_ctx = (background_dfu_context_t *)p_arg;
        if (p_dfu_ctx->dfu_state != BACKGROUND_DFU_DOWNLOAD_TRIG)
            NRF_LOG_WARNING("Token response callback called in invalid state (s:%s)",
                    (uint32_t)background_dfu_state_to_string(p_dfu_ctx->dfu_state));
            return;
        if (!is_valid_response_received(status, p_response))
            background_dfu_handle_event(&m_dfu_ctx, BACKGROUND_DFU_EVENT_TRANSFER_ERROR);
            return;
        if (background_dfu_validate_trigger(&m_dfu_ctx, p_response->p_payload, p_response->payload_len))
            m_coap_dfu_ctx.remote = p_response->remote;
            background_dfu_process_trigger(&m_dfu_ctx, p_response->p_payload, p_response->payload_len);
    /**@brief CoAP response handler for request sent to an init (@ref INIT_RESOURCE_NAME) or an image (@ref IMAGE_RESOURCE_NAME) resource.
    static void handle_block_response(uint32_t status, void * p_arg, coap_message_t * p_response)
        coap_block_opt_block2_t    block_opt = {0};
        do
            if ((p_dfu_ctx->dfu_state != BACKGROUND_DFU_DOWNLOAD_INIT_CMD) &&
                (p_dfu_ctx->dfu_state != BACKGROUND_DFU_DOWNLOAD_FIRMWARE))
                NRF_LOG_WARNING("Block response callback called in invalid state (s:%s)",
                return;
            if (!get_block2_opt(p_response, &block_opt))
                NRF_LOG_WARNING("No block 2 option in response message.");
                background_dfu_handle_event(p_dfu_ctx, BACKGROUND_DFU_EVENT_TRANSFER_CONTINUE);
            NRF_LOG_DEBUG("Received block %3lu", block_opt.number);
            if (block_opt.number != p_dfu_ctx->block_num)
                NRF_LOG_WARNING("Requested %d but got %d", p_dfu_ctx->block_num, block_opt.number);
            background_dfu_block_t block;
            block.number    = block_opt.number;
            block.size      = block_opt.size;
            block.p_payload = p_response->p_payload;
            background_dfu_process_block(p_dfu_ctx, &block);
        } while (0);
     * @section Message helpers
    /** @brief Set CoAP URI option on a given message.
     *  @param[in]    p_resource An URI as NULL terminated string which should be converted to CoAP options.
    static uint32_t set_uri_opt(coap_message_t * p_message, const char * p_resource)
        uint32_t     err_code;
        const char * p_start = p_resource;
        const char * p_end;
        uint32_t     len;
        if (*p_start == '/')
            p_start++;
        do {
            p_end = strchr(p_start, '/');
            if (p_end)
                len = p_end - p_start;
                len = strlen(p_start);
            err_code = coap_message_opt_str_add(p_message,
                                                COAP_OPT_URI_PATH,
                                                (uint8_t *) p_start,
                                                len);
            p_start += (len + 1);
        } while ((err_code == NRF_SUCCESS) && p_end);
        return err_code;
    /**@brief Get next message id.
     * @return An unique message id.
    static uint16_t message_id_get(void)
        return m_coap_message_id++;
    /**@brief Create a CoAP message with specific payload and remote.
     * @param[in] p_conf      A pointer to the message configuration.
     * @param[in] p_resource  A pointer to a string with resource name.
     * @param[in] p_payload   A pointer to the message payload. NULL if message shall not contain any payload.
     * @param[in] payload_len Payload length in bytes, ignored if p_payload is NULL.
     * @param[in] p_remote    An address of the remote endpoint.
     * @return A pointer to the message created or NULL if could not be created.
    static coap_message_t * message_create(const coap_message_conf_t * p_conf,
                                           const char                * p_resource,
                                           const uint8_t             * p_payload,
                                           uint16_t                    payload_len,
        uint32_t         err_code;
        coap_message_t * p_message = NULL;
        do
            err_code = coap_message_new(&p_message, (coap_message_conf_t *)p_conf);
            err_code = coap_message_remote_addr_set(p_message, (coap_remote_t *)p_remote);
            if (p_resource != NULL)
                err_code = set_uri_opt(p_message, p_resource);
            if (p_payload != NULL)
                err_code = coap_message_payload_set(p_message, (void *)p_payload, payload_len);
        } while (0);
        if ((err_code != NRF_SUCCESS) && (p_message != NULL))
            coap_message_delete(p_message);
            p_message = NULL;
        return p_message;
    /**@brief Create an empty reset response.
     * @param[in] p_request A pointer to the request.
     * @return A pointer to the reset response or NULL if could not be created.
    static coap_message_t * empty_reset_response_create(const coap_message_t * p_request)
        coap_message_conf_t message_conf;
        memset(&message_conf, 0, sizeof(message_conf));
        message_conf.type             = COAP_TYPE_RST;
        message_conf.code             = COAP_CODE_EMPTY_MESSAGE;
        message_conf.id               = p_request->header.id;
        message_conf.port.port_number = DFU_UDP_PORT;
        return message_create(&message_conf, NULL, NULL, 0, &p_request->remote);
    /**@brief Create a response with diag resource.
     * @param[in] type      A message type of the response.
     * @param[in] code      A message code to send back.
     * @return A pointer to the response message or NULL if could not be created.
    static coap_message_t * diagnostic_response_create(coap_msg_type_t         type,
                                                       coap_msg_code_t         code,
        message_conf.type             = type;
        message_conf.code             = code;
        message_conf.token_len        = p_request->header.token_len;
        memcpy(message_conf.token, p_request->token, message_conf.token_len);
        if (type == COAP_TYPE_ACK)
            message_conf.id = message_id_get();
        // Create a copy and invert endianess.
        background_dfu_diagnostic_t diag = m_dfu_ctx.dfu_diag;
        diag.state                       = m_dfu_ctx.dfu_state;
        diag.build_id                    = uint32_big_decode((const uint8_t *)&diag.build_id);
        diag.image_blocks_requested      = uint16_big_decode((const uint8_t *)&diag.image_blocks_requested);
        diag.init_blocks_requested       = uint16_big_decode((const uint8_t *)&diag.init_blocks_requested);
        diag.total_image_blocks_received = uint16_big_decode((const uint8_t *)&diag.total_image_blocks_received);
        diag.total_init_blocks_received  = uint16_big_decode((const uint8_t *)&diag.total_init_blocks_received);
        diag.triggers_received           = uint16_big_decode((const uint8_t *)&diag.triggers_received);
                              NULL,
                              (uint8_t *)&diag,
                              sizeof(diag),
    /**@brief A function for sending CoAP messages.
     * @param[inout] p_request A pointer to CoAP message which should be sent.
    static void coap_dfu_message_send(coap_message_t * p_message)
        uint32_t handle;
        NRF_LOG_DEBUG("Sending message [mid:%d]", p_message->header.id);
        if (coap_message_send(&handle, p_message) != NRF_SUCCESS)
            // Notify application about internal error.
            if (m_coap_dfu_ctx.handler)
                app_timer_start(m_coap_delayed_error_handling_timer, APP_TIMER_TICKS(1000*COAP_MAX_TRANSMISSION_SPAN), NULL);
            NRF_LOG_ERROR("Failed to send CoAP message");
    /**@brief A function for sending delayed CoAP messages.
     * Maximum delay is specified by @ref DEFAULT_DELAY_MAX_MS.
     * In case that another message is pending for sending, the message is dropped.
    static void coap_dfu_delayed_message_send(coap_message_t * p_message)
        if (!m_coap_dfu_ctx.timer_active)
            uint8_t delay = (background_dfu_random() % DEFAULT_DELAY_MAX_MS) + 1;
            m_coap_dfu_ctx.timer_active = true;
            app_timer_start(m_send_timer, APP_TIMER_TICKS(delay), p_message);
            // Drop the message in case another message is pending for transmission.
     * @section Resources
    /**@brief A request callback for /dfu/t resource.
     * This method is called when a request to trigger resource is received.
     * An implementation of @ref coap_method_callback_t function type.
     * @param[in] p_resource A pointer to resource.
     * @param[in] p_request  A pointer to request.
    static void trigger_request_callback(coap_resource_t * p_resource, coap_message_t * p_request)
        NRF_LOG_INFO("DFU trigger request received");
        if (p_request->header.code != COAP_CODE_POST)
            NRF_LOG_INFO("Trigger request: method not supported");
            return;
        m_dfu_ctx.dfu_diag.triggers_received++;
        if (background_dfu_validate_trigger(&m_dfu_ctx, p_request->p_payload, p_request->payload_len))
            m_coap_dfu_ctx.remote = p_request->remote;
            background_dfu_process_trigger(&m_dfu_ctx, p_request->p_payload, p_request->payload_len);
    /**@brief A request callback for /dfu/i resource.
    static void init_request_callback(coap_resource_t * p_resource, coap_message_t * p_request)
        coap_message_t          * p_response = NULL;
        coap_block_opt_block1_t   block_opt  = {0};
        do
            // Resource only active in multicast mode firmware download state.
            if ((m_dfu_ctx.dfu_mode != BACKGROUND_DFU_MODE_MULTICAST) ||
                (m_dfu_ctx.dfu_state != BACKGROUND_DFU_DOWNLOAD_INIT_CMD))
                NRF_LOG_WARNING("Init data received in invalid state: (m:%d s:%d).",
                                m_dfu_ctx.dfu_mode, m_dfu_ctx.dfu_state);
                if (!is_addr_multicast(&p_request->local))
                    p_response = empty_reset_response_create(p_request);
            if (!get_block1_opt(p_request, &block_opt))
                NRF_LOG_WARNING("No block 1 option in init request message.");
                block.p_payload = p_request->p_payload;
    #if (DFU_DEBUG_RANDOM_INIT_BLOCK_LOSS_ENABLE == 1)
                if ((background_dfu_random() % 100) >= DFU_DEBUG_RANDOM_BLOCK_LOSS_RATE)
                    background_dfu_process_block(&m_dfu_ctx, &block);
    #else  // DFU_DEBUG_RANDOM_INIT_BLOCK_LOSS_ENABLE
    #endif // DFU_DEBUG_RANDOM_INIT_BLOCK_LOSS_ENABLE
            m_dfu_ctx.dfu_diag.total_init_blocks_received++;
        } while (0);
        // Send response, if created.
        if (p_response != NULL)
            coap_dfu_message_send(p_response);
    /**@brief A request callback for /dfu/f resource.
    static void image_request_callback(coap_resource_t * p_resource, coap_message_t * p_request)
        do
                (m_dfu_ctx.dfu_state != BACKGROUND_DFU_DOWNLOAD_FIRMWARE))
                NRF_LOG_WARNING("Image data received in invalid state: (m:%d s:%d).",
                NRF_LOG_WARNING("No block 1 option in image request message.");
    #if (DFU_DEBUG_RANDOM_IMAGE_BLOCK_LOSS_ENABLE == 1)
    #else  // DFU_DEBUG_RANDOM_IMAGE_BLOCK_LOSS_ENABLE
    #endif // DFU_DEBUG_RANDOM_IMAGE_BLOCK_LOSS_ENABLE
            m_dfu_ctx.dfu_diag.total_image_blocks_received++;
        } while (0);
    /**@brief A request callback for /dfu/d resource.
    static void diagnostic_request_callback(coap_resource_t * p_resource, coap_message_t * p_request)
        // Process only CON messages.
        if (p_request->header.type == COAP_TYPE_CON)
            p_response = diagnostic_response_create(COAP_TYPE_ACK, COAP_CODE_205_CONTENT, p_request);
            p_response = diagnostic_response_create(COAP_TYPE_NON, COAP_CODE_205_CONTENT, p_request);
            coap_dfu_delayed_message_send(p_response);
    /**@brief A request callback for /dfu/r resource.
    static void reset_request_callback(coap_resource_t * p_resource, coap_message_t * p_request)
        uint32_t reset_delay_ms;
        do
            if (m_dfu_ctx.dfu_state != BACKGROUND_DFU_WAIT_FOR_RESET)
                NRF_LOG_WARNING("Reset command received in invalid state: (m:%d s:%d).",
            if (p_request->payload_len != sizeof(uint32_t))
                NRF_LOG_WARNING("Invalid reset command payload length (l:%d).",
                NRF_LOG_WARNING("Received unicast reset command. Only multicast is allowed.");
            reset_delay_ms = uint32_big_decode((const uint8_t *)p_request->p_payload);
            app_timer_start(m_reset_timer, APP_TIMER_TICKS(reset_delay_ms), NULL);
        } while (0);
    /**@brief Initialize DFU Server resources.
     * @param[in] p_dfu_ctx A pointer to DFU client context.
     * @return NRF_SUCCESS on success, otherwise an error code is returned.
    static uint32_t endpoints_init(coap_dfu_context_t * p_coap_dfu_ctx)
        uint32_t err_code = NRF_SUCCESS;
        do
            err_code = coap_resource_create(&(p_coap_dfu_ctx->root), "/");
            err_code = coap_resource_create(&(p_coap_dfu_ctx->trigger), TRIGGER_RESOURCE_NAME);
            // We allow for GET method, so that the CoAP library doesn't send 'Method not allowed'
            // response. Methods other that POST are rejected in the callback.
            p_coap_dfu_ctx->trigger.permission = (COAP_PERM_POST | COAP_PERM_GET);
            p_coap_dfu_ctx->trigger.callback   = trigger_request_callback;
            err_code = coap_resource_create(&(p_coap_dfu_ctx->init), INIT_RESOURCE_NAME);
            p_coap_dfu_ctx->init.permission = COAP_PERM_PUT;
            p_coap_dfu_ctx->init.callback   = init_request_callback;
            err_code = coap_resource_create(&(p_coap_dfu_ctx->image), IMAGE_RESOURCE_NAME);
            p_coap_dfu_ctx->image.permission = COAP_PERM_PUT;
            p_coap_dfu_ctx->image.callback   = image_request_callback;
            err_code = coap_resource_create(&(p_coap_dfu_ctx->diagnostic), DIAG_RESOURCE_NAME);
            p_coap_dfu_ctx->diagnostic.permission = COAP_PERM_GET;
            p_coap_dfu_ctx->diagnostic.callback   = diagnostic_request_callback;
            err_code = coap_resource_create(&(p_coap_dfu_ctx->reset), RESET_RESOURCE_NAME);
            p_coap_dfu_ctx->reset.permission = COAP_PERM_PUT;
            p_coap_dfu_ctx->reset.callback   = reset_request_callback;
            // Create resource hierarchy.
            err_code = coap_resource_child_add(&(p_coap_dfu_ctx->root), &(p_coap_dfu_ctx->trigger));
            err_code = coap_resource_child_add(&(p_coap_dfu_ctx->root), &(p_coap_dfu_ctx->init));
            err_code = coap_resource_child_add(&(p_coap_dfu_ctx->root), &(p_coap_dfu_ctx->image));
            err_code = coap_resource_child_add(&(p_coap_dfu_ctx->root), &(p_coap_dfu_ctx->diagnostic));
            err_code = coap_resource_child_add(&(p_coap_dfu_ctx->root), &(p_coap_dfu_ctx->reset));
            NRF_LOG_INFO("Endpoints initialized");
        } while (0);
        return err_code;
     * @section Timer handlers
    static void delayed_send_handler(void * p_context)
        coap_dfu_message_send((coap_message_t *)p_context);
        m_coap_dfu_ctx.timer_active = false;
    static void delayed_reset_handler(void * p_context)
        NRF_LOG_INFO("Handling delayed reset");
    /**@brief Handle events from m_coap_delayed_error_handling_timer.
    static void coap_delayed_error_handler(void * p_context)
        UNUSED_VARIABLE(p_context);
        NRF_LOG_INFO("Handling delayed dfu error handling");
     * @section Private API
    /**@brief Create COAP GET request.
     * @param[in] p_remote        A pointer to host.
     * @param[in] p_resource_path An URI of the resource which should be requested.
     * @param[in] block_size      Requested block size.
     * @param[in] block_num       Requested block number.
     * @param[in] callback        A pointer to the callback function that is called on response reception or error.
     * @return A pointer to CoAP message or NULL on error.
    static coap_message_t * coap_dfu_create_request(coap_remote_t            * p_remote,
                                                    const char               * p_resource_path,
                                                    uint32_t                   block_num,
                                                    coap_response_callback_t   callback)
        coap_message_t      * p_request;
        do
            if (is_addr_multicast(p_remote))
                message_conf.type = COAP_TYPE_NON;
                message_conf.type = COAP_TYPE_CON;
            message_conf.code              = COAP_CODE_GET;
            message_conf.response_callback = callback;
            message_conf.token_len         = 2;
            m_coap_token = (uint16_t)background_dfu_random();
            memcpy(message_conf.token, &m_coap_token, 2);
            p_request = message_create(&message_conf, p_resource_path, NULL, 0, p_remote);
            if (p_request == NULL)
            p_request->p_arg = (void *)&m_dfu_ctx;
            if (block_size > 0)
                err_code = set_block2_opt(p_request, block_size, block_num);
        } while (0);
        if ((err_code != NRF_SUCCESS) && (p_request != NULL))
            coap_message_delete(p_request);
            p_request = NULL;
        return p_request;
    /**@brief Count blocks present in a block bitmap.
     * @param[in] p_req_bmp A block bitmap to count.
     * @return Number of blocks counted.
    static uint16_t blocks_count(const background_dfu_request_bitmap_t * p_req_bmp)
        uint16_t count = 0;
        for (uint8_t i = 0; i < p_req_bmp->size; i++)
            for (uint8_t j = 0; j < 8; j++)
                if ((p_req_bmp->bitmap[i] >> j) & 0x01)
                    count++;
        return count;
    /**@brief An implmentation of @ref coap_error_callback_t type. */
    static void coap_error_handler(uint32_t error_code, coap_message_t * p_message)
        UNUSED_PARAMETER(error_code);
        UNUSED_PARAMETER(p_message);
        // Intentionally empty.
    /**@brief Initialize CoAP protocol.
     * @param[in] p_context An application specific context.
    static uint32_t coap_protocol_init(const void * p_context)
        uint32_t    err_code;
        coap_port_t local_port_list[COAP_PORT_COUNT] =
        coap_transport_init_t transport_params;
        transport_params.p_port_table = &local_port_list[0];
        transport_params.p_arg        = (void *)p_context;
        NRF_LOG_DEBUG("Init coap");
        m_coap_message_id = background_dfu_random();
        err_code = coap_init(otRandomNonCryptoGetUint32(), &transport_params);
            err_code = coap_error_handler_register(coap_error_handler);
        return err_code;
    void background_dfu_transport_block_request_send(background_dfu_context_t        * p_dfu_ctx,
        uint16_big_encode(p_req_bmp->offset, (uint8_t *)&p_req_bmp->offset);
        NRF_LOG_INFO("Sending block request!");
        message_conf.code             = COAP_CODE_PUT;
        const char * p_resource_name  = NULL;
        if (m_dfu_ctx.dfu_state == BACKGROUND_DFU_DOWNLOAD_INIT_CMD)
            m_dfu_ctx.dfu_diag.init_blocks_requested += blocks_count(p_req_bmp);
            p_resource_name = BITMAP_RESOURCE_NAME "/" INIT_RESOURCE_NAME;
        else if (m_dfu_ctx.dfu_state == BACKGROUND_DFU_DOWNLOAD_FIRMWARE)
            p_resource_name = BITMAP_RESOURCE_NAME "/" IMAGE_RESOURCE_NAME;
            m_dfu_ctx.dfu_diag.image_blocks_requested += blocks_count(p_req_bmp);
        coap_message_t * p_message =  message_create(&message_conf,
                                                     p_resource_name,
                                                     (uint8_t *)(&p_req_bmp->offset),
                                                     sizeof(p_req_bmp->bitmap) + sizeof(uint16_t),
                                                     &m_coap_dfu_ctx.remote);
        if (p_message != NULL)
            coap_dfu_message_send(p_message);
    uint32_t background_dfu_random(void)
        return otRandomNonCryptoGetUint32();
    void background_dfu_transport_state_update(background_dfu_context_t * p_dfu_ctx)
        switch (p_dfu_ctx->dfu_state)
            case BACKGROUND_DFU_DOWNLOAD_TRIG:
                m_coap_dfu_ctx.p_resource_path = TRIGGER_RESOURCE_NAME;
                m_coap_dfu_ctx.handler         = handle_trigger_response;
            case BACKGROUND_DFU_DOWNLOAD_INIT_CMD:
                m_coap_dfu_ctx.p_resource_path = INIT_RESOURCE_NAME;
                m_coap_dfu_ctx.handler         = handle_block_response;
            case BACKGROUND_DFU_DOWNLOAD_FIRMWARE:
                m_coap_dfu_ctx.p_resource_path = IMAGE_RESOURCE_NAME;
            case BACKGROUND_DFU_WAIT_FOR_RESET:
            case BACKGROUND_DFU_IDLE:
                NRF_LOG_WARNING("Unhandled state in background_dfu_transport_state_update (s: %s).",
    void background_dfu_transport_send_request(background_dfu_context_t * p_dfu_ctx)
        uint16_t block_size = (p_dfu_ctx->dfu_state == BACKGROUND_DFU_DOWNLOAD_TRIG) ?
                                0 : DEFAULT_BLOCK_SIZE;
        coap_message_t * p_request = coap_dfu_create_request(&m_coap_dfu_ctx.remote,
                                                             m_coap_dfu_ctx.p_resource_path,
                                                             block_size,
                                                             m_coap_dfu_ctx.handler);
        if (p_request != NULL)
            NRF_LOG_INFO("Requesting [%s] (block:%u mid:%d)",
                        (uint32_t)m_coap_dfu_ctx.p_resource_path,
                        p_request->header.id);
            coap_dfu_delayed_message_send(p_request);
            NRF_LOG_ERROR("Failed to create a request.")
     * @section Public API
    void background_dfu_handle_error(void)
        coap_dfu_handle_error();
    __WEAK void coap_dfu_handle_error(void)
    void coap_dfu_diagnostic_get(struct background_dfu_diagnostic *p_diag)
        if (p_diag)
            memcpy(p_diag, &m_dfu_ctx.dfu_diag, sizeof(background_dfu_diagnostic_t));
            p_diag->state = m_dfu_ctx.dfu_state;
    uint32_t coap_dfu_trigger(const coap_remote_t * p_remote)
        NRF_LOG_INFO("Triggering DFU");
        if (m_dfu_ctx.dfu_state != BACKGROUND_DFU_IDLE)
            NRF_LOG_WARNING("Invalid state");
        if (p_remote != NULL)
            memcpy(&m_coap_dfu_ctx.remote, p_remote, sizeof(*p_remote));
            memcpy(&m_coap_dfu_ctx.remote.addr, REALM_LOCAL_ADDR, 16);
            m_coap_dfu_ctx.remote.port_number = DFU_UDP_PORT;
        // Transition from DFU_IDLE to DFU_DOWNLOAD_TRIG.
        return background_dfu_handle_event(&m_dfu_ctx, BACKGROUND_DFU_EVENT_TRANSFER_COMPLETE);
    uint32_t coap_dfu_init(const void * p_context)
        uint32_t err_code;
        do
            memset(&m_coap_dfu_ctx, 0 , sizeof(m_coap_dfu_ctx));
            err_code = coap_protocol_init(p_context);
            err_code = endpoints_init(&m_coap_dfu_ctx);
            nrf_dfu_settings_init(false);
            nrf_dfu_req_handler_init(dfu_observer);
            background_dfu_state_init(&m_dfu_ctx);
            app_timer_create(&m_send_timer, APP_TIMER_MODE_SINGLE_SHOT, delayed_send_handler);
            app_timer_create(&m_reset_timer, APP_TIMER_MODE_SINGLE_SHOT, delayed_reset_handler);
            app_timer_create(&m_coap_delayed_error_handling_timer, APP_TIMER_MODE_SINGLE_SHOT, coap_delayed_error_handler);
            APP_SCHED_INIT(SCHED_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
        } while (0);
        return err_code;
    void coap_dfu_process(void)
        app_sched_execute();
    void coap_dfu_reset_state(void)
        background_dfu_reset_state(&m_dfu_ctx);
    coap_dfu.h4212.terminal.log
    Here i attached new Terminal log file and Coap_DFU file for transport layer.
    I used background DFU module with this file(coap_dfu.c). Please revert as soon as possible.
    Br
    Pankaj Jaswal
  • Hi Pankaj,
    I noticed that you never call background_dfu_handle_event() with BACKGROUND_DFU_EVENT_TRANSFER_COMPLETE. In fact, I do not see any code that should active the new firmware after it has been completely received?
  • Thanks Einar,
    How could i activate the new firmware and which function is to be called. Please guide me Einar.
    Br
    Pankaj Jaswal
