Multilink Central Example does not work with high connection intervals
If I set the centrals connection intervals values higher as a specific value it won't any longer find/connect/enable notifications on my peripheral.
0x00A0/0x0050/400/700/0/8100 working
0x00A0/0x0050/400/800/0/8100 not working.
0x00A0/0x0050/500/800/0/8100 not working.
0x00A0/0x0050/4000/4000/0/8100 not working. (preferred one)
This leaves me really clueless :( Of course I tried a lot more combinations.. I want to use the maximum interval of 4seconds. What else could cause this problem?
Central: (SD2.0.0 SDK8.0)(nRF51-DK)
#define SCAN_INTERVAL                    0x00A0                                         /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW                      0x0050                                         /**< Determines scan window in units of 0.625 millisecond. */
#define MIN_CONNECTION_INTERVAL          MSEC_TO_UNITS(2000, UNIT_1_25_MS)                /**< Determines minimum connection interval in millisecond. */
#define MAX_CONNECTION_INTERVAL          MSEC_TO_UNITS(4000, UNIT_1_25_MS)                /**< Determines maximum connection interval in millisecond. */
#define SLAVE_LATENCY                    0                                              /**< Determines slave latency in counts of connection events. */
#define SUPERVISION_TIMEOUT              MSEC_TO_UNITS(8100, UNIT_10_MS)                /**< Determines supervision time-out in units of 10 millisecond. */
Peripheral: (SD 7.1.0 SDK 6.1)(Custom Board: Seeed BLE Micro)
#define APP_ADV_INTERVAL                   MSEC_TO_UNITS(500, UNIT_0_625_MS)           /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS         0                                        /**< The advertising timeout (in units of seconds). */
#define MIN_CONN_INTERVAL                  MSEC_TO_UNITS(2000, UNIT_1_25_MS)           /**< Minimum acceptable connection interval (0.5 seconds). */
#define MAX_CONN_INTERVAL                  MSEC_TO_UNITS(4000, UNIT_1_25_MS)          /**< Maximum acceptable connection interval (1 second). */
#define SLAVE_LATENCY                      0                                          /**< Slave latency. */
#define CONN_SUP_TIMEOUT                   MSEC_TO_UNITS(8100, UNIT_10_MS)            /**< Connection supervisory timeout (4 seconds). */
It works with smaller intervals.. But these should be in range and fulfill all requirements.. don't they?(MCP@Android can still connect to the peripheral - so probably a central setting is out of bonds? but which and why?)(also tried Scan_interval=Scan_window)
Rule from ble_gap.h
 * @note If both conn_sup_timeout and max_conn_interval are specified, then the following constraint applies:
 *       conn_sup_timeout * 4 > (1 + slave_latency) * max_conn_interval
central main.c
peripheral main.c
I tested it now with unchanged example. And then only changed settings on central and then on central+peripheral. Only unchanged worked. Changed min/max/timeout to 2000/4000/8100 and changed nothing else.
default settings.txt
central_changed.txt
both_changed.txt
Disconnect Reason 0x0008.. so it timed out?
I thought the connection interval would only affect everything AFTER service discovery..
I do measurements on the periphal and send them with sd_ble_gatts_hvx. I just want to use as less power as possible. So only have the central and espeically the peripheral only wake up every x seconds to do the measurement and send them to the central.
The measurement and hvx is done by an timer. And works from 500ms-4s as far as I have tested. But shouldn't it be ok to use the same connection interval?
How much is the power use of an connection event where they do like nothing anyway?
    Error 0x0008 corresponds to BLE_HCI_CONNECTION_TIMEOUT. A common source for this error is timing issues caused by poor accuracy on the low frequency 32,768Hz crystal. According to the Seeed BLE Micro schematic there is an external crystal, but it doesn't say anything about the accuracy. Try to increase the ppm value in SOFTDEVICE_HANDLER_INIT() called in main.c. Try the largest value first: NRF_CLOCK_LFCLKSRC_XTAL_500_PPM.
    Here is a great thread explaining a bit about various low frequency clock sources.
    The reasons why I suspect a timing issue is that your values work fine on my own development kits from Nordic (with known clock accuracies). It just takes a long time for the devices to connect (a few seconds to a couple of minutes). On the peripheral side I have a PCA10001 kit with S110 V7.1 and SDK V6.1. On the central side I have a nRF51 Dongle (also tried DK) with S120 V2.0.0 and SDK V8.1 (also tried V8.0).
    To understand why it takes so long for your two devices to connect you can have a look at this thread. Your advertise interval is pretty high and your scan interval/window pretty low. Hence it will take a while before the peripheral is advertising and the central is listening at the same time (To make absolutely sure that the windows and intervals eventually overlap a small random delay is added to the advertisement interval).
    Here is a little more info about intervals etc.
    To speed up the connection time you can experiment with decreasing the adv interval or maybe also increase the scan interval and/or window. However this will draw power, as you know. In the end you will have to compromise. If you plan to stay most of the time advertising then maybe a long adv interval is best. If you, on the other hand, stay connected most of the time you can have short adv intervals and long connection intervals.
  • Thanks for your answer! But too bad they don't work for me, and I don't know what I could've changed that could cause this.. :( Oh. And of course I am using v2.0.0 my Bad... I waited up to 5 minutes and nothing happened. But why does connection interval influences the time they need to connect anyway? Shouldn't only advertising and scanning affect this?
    I tested it now again for 10 Minutes with the following settings:
    Peripheral: advinterval:500, min/max conn:2000/4000 timeout 8100
    Central: scanning interval/window A0/50 min/max/timeout as above.
    As far as my RTT Output goes the central starts scanning but then nothing more is happening.. If I change the centrals min/max conn. to e.g. 200/400 it connects and enables notifications in a few seconds.
  • Have you tried to run the example codes "as is", without your own code? And then use the parameters you mention above? It would be a quick way to see if your problem lies in your own application. I'm afraid the code you attached is too extensive for me to test or go through. Are you also able to debug your code and see if you get any asserts?
  • This is #1 on my schedule for today when I finally finished running around looking for a pressure-tight case. I will update this.
    Tested. Does not work. Please see edited questions for logfiles.
  • Error 0x0008 corresponds to BLE_HCI_CONNECTION_TIMEOUT. Some people experience this when their device goes out of range.
    Another possible solution might be timing issues caused by poor accuracy on the low frequency 32,768Hz crystal on the Seeed BLE Micro. According to the Seeed BLE Micro schematic there is a crystal, but it doesn't say anything about the accuracy. Try to increase the ppm value in SOFTDEVICE_HANDLER_INIT();. Try the largest value first: NRF_CLOCK_LFCLKSRC_XTAL_500_PPM.
