DFU SERVICE ON SDK 12
I do have a PCA10040 board, I'm using the examples from Nordic.
On the DFU example for SDK 12 I have pressed button 4 and RESET the board to active BOOT .
I’m testing the DFU example for SDK 12 and it seems that I can not have DFU service active in my application.
I would like to set up my environment to enter in DFU mode by software(without using a button during the startup)
I would like to have NUS (nRF UART service) and DFU active in my application,
I did the same tests  with SDK 17 and it works, but as my application was written with SDK12 and I'm trying to minimize the development time.
Thanks in advance,
Carlos
  • Hi Carlos,
    You can use the Experimental: Buttonless DFU Template Application as a reference to add buttonless support to your project. It may actually be quicker to start with this project and add the NUS service if you have just started development.
    Vidar
  • Hi, I'm testing the BOOTLOADER with DFU,
    I'm using nRF connect on my Android device to send the ZIP files to my PCA10040 card.
    I have some questions:
    1) I noticed that the blue tooth MAC ADDRESS  changes when I'm using the DFU protocol,
    My nRF device MAC ADR is FD:A7:EC:76:BD:51 when I'm using it as UART BLE
    My nRF device MAC ADR is FD:A7:EC:76:BD:52 when I'm using it as DFU
    2) Today I'm using SDK12, but I intend to use the SDK 17 on the future, may I do the SOFTDEVICE, APLICATION  and BOOTLOADER update using DFU BLE from SDK 12 to SDK 17 or I have to use JTAG programmer?
    1. The reason for this address change is explained in the docs here: Buttonless Secure DFU Service without bonds. It's basically done to make it appear as a different device while in DFU mode.
    2. Yes, this should work. Below is the nrfutil command you can use to generate a full Softdevice+bootloader+application DFU package to upgrade to SDK 17. What Softdevice FWID to pass to --sd-req and --sd-id depends on which Softdevice variants you use, check SD release notes to find the  FWID for a particular Softdevice variant+version.
    nrfutil pkg generate --hw-version 52 ^
    --bootloader-version <bootloader version> ^
    --sd-req 0x91 ^
    --sd-id 0x0101 ^
    --application-version <application version> ^
    --application APPLICATION.HEX ^
    --softdevice SOFTDEVICE.HEX ^
    --bootloader BOOTLOADER.HEX ^
    --key-file FILE sd_ble_app_dfu.zip
    I did the test for SDK 12 and it works,
    I will test the SDK17 udate,
    Thank you,
    Carlos
  • Hi, I solved this issue, but the ticket remained open, how can I close this ticket?
    Carlos
