Serial rx interrupt does not work unless debugging
I am using SDK 14.2 and made some changes with serial example in the SDK. It works just fine while debugging but outside of debugging does not work at all.
I have an other mcu connected to nrf52832 via Rx, Tx pins and it sends some packages according to what it received. What might be causing this ? I saw this problem with my own project so i wanted to try on SDK example but resut is same.
Note: i will use latest SDK if it must.
 * Copyright (c) 2016 - 2017, Nordic Semiconductor ASA
 * All rights reserved.
#include <stdint.h>
#include <stdbool.h>
#include <stddef.h>
#include "nrf.h"
#include "nrf_drv_clock.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_power.h"
#include "nrf_serial.h"
#include "app_timer.h"
#include "app_error.h"
#include "app_util.h"
#include "boards.h"
bool a = false;
bool b = false;
/** @file
 * @defgroup nrf_serial_example main.c
 * @ingroup nrf_serial_example
 * @brief Example of @ref nrf_serial usage. Simple loopback.
#define OP_QUEUES_SIZE          3
#define APP_TIMER_PRESCALER     NRF_SERIAL_APP_TIMER_PRESCALER
NRF_SERIAL_UART_DEF(serial_uart, 0);
static void sleep_handler(void)
    __WFE();
    __SEV();
    __WFE();
static void serial_event_handler(struct nrf_serial_s const *p_serial, nrf_serial_event_t event)
  static uint8_t buffer[200] = {0};
  static uint8_t length = 0;
  switch (event)
    case NRF_SERIAL_EVENT_TX_DONE:
    case NRF_SERIAL_EVENT_RX_DATA:
        nrf_serial_read(&serial_uart, &buffer[length], 1, NULL, 0);
        //nrf_queue_read(p_serial->p_ctx->p_config->p_buffers->rx_size, length, 1);
        //nrf_queue_read(p_serial->p_ctx->p_config->p_queues->p_rxq->, &buffer[length], 1);
        if ((buffer[length] == '\n') || (length >= 200 - 1))
          if(memcmp(buffer, "SC,D001,1,200,200,0,0\n", sizeof("SC,D001,1,200,200,0,0\n")) == 0)
            a = true;
          else if(memcmp(buffer, "WC,1\n", sizeof("WC,1\n")) == 0)
            b = true;
          memset(buffer, 0, 200);
          length = 0;
          length++;
    case NRF_SERIAL_EVENT_DRV_ERR:
    case NRF_SERIAL_EVENT_FIFO_ERR:
NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uart0_drv_config,
                      8, 15,
                      RTS_PIN_NUMBER, CTS_PIN_NUMBER,
                      NRF_UART_HWFC_DISABLED, NRF_UART_PARITY_EXCLUDED,
                      NRF_UART_BAUDRATE_115200,
                      UART_DEFAULT_CONFIG_IRQ_PRIORITY);
#define SERIAL_FIFO_TX_SIZE 32
#define SERIAL_FIFO_RX_SIZE 32
NRF_SERIAL_QUEUES_DEF(serial_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
#define SERIAL_BUFF_TX_SIZE 1
#define SERIAL_BUFF_RX_SIZE 1
NRF_SERIAL_BUFFERS_DEF(serial_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
NRF_SERIAL_CONFIG_DEF(serial_config, NRF_SERIAL_MODE_IRQ,
                      &serial_queues, &serial_buffs, serial_event_handler, sleep_handler);
    ret_code_t ret;
    ret = nrf_drv_clock_init();
    APP_ERROR_CHECK(ret);
    ret = nrf_drv_power_init(NULL);
    ret = app_timer_init();
    bsp_board_leds_init();
    bsp_board_buttons_init();
    ret = nrf_serial_init(&serial_uart, &m_uart0_drv_config, &serial_config);
    static char tx_message[] = "LC,ST\n";
    ret = nrf_serial_write(&serial_uart,
                           tx_message,
                           strlen(tx_message),
                           NULL,
                           NRF_SERIAL_MAX_TIMEOUT);
    while (true)
        char d;
        //nrf_serial_read(&serial_uart, &d, 1, NULL, 0);
        if(a == false)
                           "LC,ST\n",
                           strlen("LC,ST\n"),
                           NULL,
        else if(b == false)
                           "LC,WC\n",
                           strlen("LC,WC\n"),
                           NULL,
        nrf_delay_ms(1000);
