Having issue to read manufacturer ID from SPI flash memory
Hello Nordic Team
I am working on SDK v-17.0.2 SPI example to interface with external flash memory. I have Winbond W25Q128FV and Fudan FM25Q08 flash memory but have same issue to read manufacturer ID. I am getting 0x00 in response.
I attached test code below:
 * @brief SPI user event handler.
 * @param event
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                       void *                    p_context)
    spi_xfer_done = true;
    NRF_LOG_INFO("Transfer completed.");
    if (m_rx_buf[0] != 0)
        NRF_LOG_INFO(" Received:");
        NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
    spi_config.ss_pin   = SPI_SS_PIN;
    spi_config.miso_pin = SPI_MISO_PIN;
    spi_config.mosi_pin = SPI_MOSI_PIN;
    spi_config.sck_pin  = SPI_SCK_PIN;
    spi_config.mode = NRF_DRV_SPI_MODE_3;
    spi_config.bit_order = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST;
    spi_config.frequency = NRF_DRV_SPI_FREQ_1M;
    APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
    NRF_LOG_INFO("SPI example started.");
    while (1)
        m_tx_buf[0] = 0x90;
        m_tx_buf[1] - 0x00;
        m_tx_buf[2] = 0x00;
        m_tx_buf[3] = 0x00;
        // Reset rx buffer and transfer done flag
        memset(m_rx_buf, 0, m_length);
        spi_xfer_done = false;
        APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, 4, m_rx_buf, 6));
        while (!spi_xfer_done)
            __WFE();
        NRF_LOG_FLUSH();
        bsp_board_led_invert(BSP_BOARD_LED_0);
        nrf_delay_ms(200);
I am stuck here and trying since 2 days but no luck. Any help or right direction on this will be great.
Thanks and Regards
Raj
