We have been working with a Zigbee coordinator based on nRF52840 with nRF5_SDK_for_Thread_and_Zigbee_v4.0.0_dc7186b, Softdevice and FreeRTOS.
Zigbee task defines a stack of (64+2048)+4 = 8448 bytes. It is placed in RAM from 0x2000a3ac to 0x200082ac.
After a couple of days of normal operation, an external command is received and a bus fault error is generated when a function is triggered. The sp points to 0x2000a378 (within the stack limits) and the disassembly points the instruction at the very beginning of the implemented function zbm_get_free_row_query_table():
sub sp, sp, #8
Why is this generated if sp value is valid and pointing to a ram offset within the stack range?
The external command was successfully tested many times. We checked that the sp points to 0x2000a378 and no bus fault is generated. But a couple of days later, the bus fault is generated again on the same instruction
Please, find attached some helpful SES debug images.
Santiago
