How to discover vendor service
I want to develop central code to discover vender specific service using pc-ble-driver-py.
The service_discovery function defined in ble_adapter.py can discover the vender service, but cannot collect it.
Because, the following guard conditions on Line: 326 prevent collection.
The following is an excerpt of the service_discovery function defined in ble_adapter.py. (line: 322-329)
322:            if response["status"] == BLEGattStatusCode.success:
323:                # Assign UUIDBase manually
324:                # See:
325:                #  https://github.com/NordicSemiconductor/pc-ble-driver-py/issues/38
326:                for s in response["services"]:
327:                    if s.uuid.value != BLEUUID.Standard.unknown:
328:                        s.uuid.base = base
329:                        self.db_conns[conn_handle].services.append(s)
What is the intent of this guard condition?
I have confirmed that the vender service can be collected by deleting the guard condition in line 326.
    To discover vendor specific services you need add the UUIDBase manually as noted in the comment. Attached below is an example I have made to discover the 128-bit Nordic UART service which you can use as a reference.
    # Copyright (c) 2016 Nordic Semiconductor ASA
    # All rights reserved.
    # Redistribution and use in source and binary forms, with or without modification,
    # are permitted provided that the following conditions are met:
    #   1. Redistributions of source code must retain the above copyright notice, this
    #   list of conditions and the following disclaimer.
    #   2. Redistributions in binary form must reproduce the above copyright notice, this
    #   list of conditions and the following disclaimer in the documentation and/or
    #   other materials provided with the distribution.
    #   3. Neither the name of Nordic Semiconductor ASA nor the names of other
    #   contributors to this software may be used to endorse or promote products
    #   derived from this software without specific prior written permission.
    #   4. This software must only be used in or with a processor manufactured by Nordic
    #   Semiconductor ASA, or in or with a processor manufactured by a third party that
    #   is used in combination with a processor manufactured by Nordic Semiconductor.
    #   5. Any software provided in binary or object form under this license must not be
    #   reverse engineered, decompiled, modified and/or disassembled.
    # THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
    # ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
    # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
    # DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
    # ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
    # (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
    # LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
    # ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    # (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
    # SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    import sys
    import time
    import logging
    from queue import Queue, Empty
    from pc_ble_driver_py.observers import *
    TARGET_DEV_NAME = "Nordic_UART"
    CONNECTIONS = 1
    CFG_TAG = 1
    def init(conn_ic_id):
        # noinspection PyGlobalUndefined
        global config, BLEDriver, BLEAdvData, BLEEvtID, BLEAdapter, BLEEnableParams, BLEGapTimeoutSrc, BLEUUID, BLEUUIDBase, BLEConfigCommon, BLEConfig, BLEConfigConnGatt, BLEGapScanParams
        from pc_ble_driver_py import config
        config.__conn_ic_id__ = conn_ic_id
        # noinspection PyUnresolvedReferences
        from pc_ble_driver_py.ble_driver import (
            BLEDriver,
            BLEAdvData,
            BLEEvtID,
            BLEEnableParams,
            BLEGapTimeoutSrc,
            BLEUUID,
            BLEUUIDBase,
            BLEGapScanParams,
            BLEConfigCommon,
            BLEConfig,
            BLEConfigConnGatt,
        from pc_ble_driver_py.ble_adapter import BLEAdapter
        global nrf_sd_ble_api_ver
        nrf_sd_ble_api_ver = config.sd_api_ver_get()
    class NusCollector(BLEDriverObserver, BLEAdapterObserver):
        def __init__(self, adapter):
            super(NusCollector, self).__init__()
            self.first = 1
            self.adapter = adapter
            self.conn_q = Queue()
            self.adapter.observer_register(self)
            self.adapter.driver.observer_register(self)
            self.adapter.default_mtu = 300
            self.nus_base = BLEUUIDBase([
                0x6e, 0x40, 0x00, 0x00, 0xb5, 0xa3, 0xf3, 0x93, 0xe0, 0xa9, 0xe5, 0x0e, 0x24, 0xdc, 0xca, 0x9e
            self.nus_rx = BLEUUID(0x0002, self.nus_base)
            self.nus_tx = BLEUUID(0x0003, self.nus_base)
        def open(self):
            self.adapter.driver.open()
            if config.__conn_ic_id__ == "NRF51":
                self.adapter.driver.ble_enable(
                    BLEEnableParams(
                        vs_uuid_count=1,
                        service_changed=0,
                        periph_conn_count=0,
                        central_conn_count=1,
                        central_sec_count=0,
            elif config.__conn_ic_id__ == "NRF52":
                gatt_cfg = BLEConfigConnGatt()
                gatt_cfg.att_mtu = self.adapter.default_mtu
                gatt_cfg.tag = CFG_TAG
                self.adapter.driver.ble_cfg_set(BLEConfig.conn_gatt, gatt_cfg)
                self.adapter.driver.ble_enable()
                self.adapter.driver.ble_vs_uuid_add(self.nus_base)
        def close(self):
            self.adapter.driver.close()
        def connect_and_discover(self):
            scan_duration = 5
            params = BLEGapScanParams(interval_ms=200, window_ms=150, timeout_s=scan_duration)
            message = "We are connected!\r\n"
            self.adapter.driver.ble_gap_scan_start(scan_params=params)
            try:
                new_conn = self.conn_q.get(timeout=scan_duration)
                self.adapter.service_discovery(new_conn)
                self.adapter.enable_notification(new_conn, self.nus_tx)
                #data = [ord(n) for n in list(message)]
                data = [49]*244
                print(data)
                print(type(data))
                self.adapter.write_cmd(new_conn, self.nus_rx, data)
                return new_conn
            except Empty:
                print("No device advertising with name {TARGET_DEV_NAME} found.")
                return None
        def on_gattc_evt_exchange_mtu_rsp(self, ble_driver, conn_handle, status, att_mtu):
            print("ATT MTU updated to {}".format(att_mtu))
        def on_gap_evt_data_length_update(
            self, ble_driver, conn_handle, data_length_params
            print("Max rx octets: {}".format(data_length_params.max_rx_octets))
            print("Max tx octets: {}".format(data_length_params.max_tx_octets))
            print("Max rx time: {}".format(data_length_params.max_rx_time_us))
            print("Max tx time: {}".format(data_length_params.max_tx_time_us))
        def on_gatts_evt_exchange_mtu_request(self, ble_driver, conn_handle, client_mtu):
            print("Client requesting to update ATT MTU to {} bytes".format(client_mtu))
        def on_gap_evt_connected(
            self, ble_driver, conn_handle, peer_addr, role, conn_params
            print("New connection: {}".format(conn_handle))
            self.conn_q.put(conn_handle)
        def on_gap_evt_disconnected(self, ble_driver, conn_handle, reason):
            print("Disconnected: {} {}".format(conn_handle, reason))
        def on_gap_evt_adv_report(
            self, ble_driver, conn_handle, peer_addr, rssi, adv_type, adv_data
            if BLEAdvData.Types.complete_local_name in adv_data.records:
                dev_name_list = adv_data.records[BLEAdvData.Types.complete_local_name]
            elif BLEAdvData.Types.short_local_name in adv_data.records:
                dev_name_list = adv_data.records[BLEAdvData.Types.short_local_name]
            else:
                return
            dev_name = "".join(chr(e) for e in dev_name_list)
            address_string = "".join("{0:02X}".format(b) for b in peer_addr.addr)
            print(
                "Received advertisment report, address: 0x{}, device_name: {}".format(
                    address_string, dev_name
            if dev_name == TARGET_DEV_NAME:
                self.adapter.connect(peer_addr, tag=CFG_TAG)
        def on_notification(self, ble_adapter, conn_handle, uuid, data):
            if len(data) > 32:
                data = "({}...)".format(data[0:10])
            print("Connection: {}, {} = {}".format(conn_handle, uuid, data))
    def main(selected_serial_port):
        print("Serial port used: {}".format(selected_serial_port))
        driver = BLEDriver(
            serial_port=selected_serial_port, auto_flash=False, baud_rate=1000000, log_severity_level="info"
        adapter = BLEAdapter(driver)
        collector = NusCollector(adapter)
        collector.open()
        conn = collector.connect_and_discover()
        while conn is not None:
            time.sleep(100)
        collector.close()
    def item_choose(item_list):
        for i, it in enumerate(item_list):
            print("\t{} : {}".format(i, it))
        print(" ")
        while True:
            try:
                choice = int(input("Enter your choice: "))
                if (choice >= 0) and (choice < len(item_list)):
                    break
            except Exception:
                pass
            print("\tTry again...")
        return choice
    if __name__ == "__main__":
        logging.basicConfig(
            level="DEBUG",
            format="%(asctime)s [%(thread)d/%(threadName)s] %(message)s",
        serial_port = None
        if len(sys.argv) < 2:
            print("Please specify connectivity IC identifier (NRF51, NRF52)")
            exit(1)
        init(sys.argv[1])
        if len(sys.argv) == 3:
            serial_port = sys.argv[2]
        else:
            descs = BLEDriver.enum_serial_ports()
            choices = ["{}: {}".format(d.port, d.serial_number) for d in descs]
            choice = item_choose(choices)
            serial_port = descs[choice].port
        main(serial_port)
        quit()
    Vidar
    Thank you for your quick reply
    But the result was the same. It can be detected, but it is not collected in self.db_conns.
    The Base UUID of our vender service is the following value.
    00000000-XXXX-XXXX-XXXX-XXXXXXXXXXXX
    In other words, the part corresponding to 16bit UUID matches 0x0000 = BLEUUID.Standard.unknown.
    Therefore, the guard on line 327 will prevent collection.
    In our use case, we would like to remove the guard statement.
    However, we are worried about side effects, because we do not understand the intent of this guard statement.
    Yuta
    Yes, it looks like the correct fix is to remove the guard as you said. Please see discussion in this pull request for details: https://github.com/NordicSemiconductor/pc-ble-driver-py/pull/167
    Vidar
  • HI,
    Thank you for introducing the pull request.
    I understand the intent of this code and the side effects of removing the guard statement.
    Yuta
