I am working on internal flash nRF52832 merged with twi sensor, my sensor function will return a string . How to assign the string to the my_data.p_data . i am getting error ,
how to resolve this ? I don't know how to write the return value from the sensor function to fds
please help me
#include "fds.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_twi.h" //twi added
/* TWI PINS */
#define TWI_SCL_PIN 27
#define TWI_SDA_PIN 26
/* MPU-6050 I2C-ADDRESS */
#define MPU_6050_I2C_ADDR 0x68
/* MPU-6050 Register Map */
#define WHO_AM_I 0x75
#define ACCEL_XOUT_H 0x3B
#define TEMP_OUT_H 0x41
#define GYRO_XOUT_H 0x43
#define PWR_MGMT_1 0x6B
/* TWI instance. */
static const nrf_drv_twi_t m_twi_mpu_6050 = NRF_DRV_TWI_INSTANCE(0); //added
char *accelerometer_value;
float alt[8];
char accel[80];
uint32_t flash=5;
/**************************Private Function Definitions**************************/
uint32_t file_id = 0x01000;
uint32_t rec_id = 0x1111;
typedef struct
char accel_data[30];
}configuration_t_sensor;
static configuration_t_sensor my_data =
.accel_data= accelerometer_value
/* A record containing dummy configuration data. */
fds_record_t record =
.file_id = 0x00,
.key = 0x00,
.data.p_data = &my_data,
/* The length of a record is always expressed in 4-byte units (words). */
.data.length_words = 25, //Also change this if array size is changed.
/* Flag to check fds initialization. */
static bool volatile m_fds_initialized = false;;
static bool volatile m_fds_write = false;
static bool volatile m_gc_complete = false;
* @brief Event handler for FDS events
* @param[in] p_evt Structure with FDS data
* @retval NONE
static void fds_evt_handler(fds_evt_t const * p_evt)
/*NRF_LOG_INFO("Event: %s received (%s)",
fds_evt_str[p_evt->id],
fds_err_str[p_evt->result]);
switch (p_evt->id)
case FDS_EVT_INIT:
if (p_evt->result == NRF_SUCCESS)
m_fds_initialized = true;
case FDS_EVT_WRITE:
m_fds_write = true;
} break;
case FDS_EVT_DEL_RECORD:
NRF_LOG_INFO("Record ID:\t0x%04x", p_evt->del.record_id);
NRF_LOG_INFO("File ID:\t0x%04x", p_evt->del.file_id);
NRF_LOG_INFO("Record key:\t0x%04x", p_evt->del.record_key);
///m_delete_all.pending = false;
} break;
case FDS_EVT_GC:
NRF_LOG_INFO("GC Done");
m_gc_complete = true;
}break;
* @brief Function to go to low power when waiting for FDS
* @param[in] NONE
* @retval NONE
static void power_manage(void)
#ifdef SOFTDEVICE_PRESENT
(void) sd_app_evt_wait();
#else
__WFE();
* @brief The FDS takes some time for init. Waiting till it gets initialised properly.
* @param[in] NONE
* @retval NONE
static void wait_for_fds_ready(void)
while (!m_fds_initialized)
power_manage();
static void wait_for_write(void)
while (!m_fds_write)
power_manage();
void fds_write()
ret_code_t rc;
fds_record_desc_t desc = {0};
record.file_id = file_id;
for(int i=0;i<10;i++)
memset(&desc, 0x00, sizeof(fds_record_desc_t)); //clear pannuthu
record.key = rec_id;
rc = fds_record_write(&desc, &record);
wait_for_write();
if(rc == NRF_SUCCESS) {
NRF_LOG_INFO("Data written with id %d",rec_id);
else {
NRF_LOG_INFO("Write Failed, id %d",rc);
rec_id++;
rec_id = 0x1111;
void fds_read()
NRF_LOG_INFO("Starting Read");
ret_code_t rc;
fds_find_token_t tok = {0};
memset(&tok, 0x00, sizeof(fds_find_token_t));
rc = fds_record_find(file_id, rec_id, &desc, &tok);
if (rc == NRF_SUCCESS)
fds_flash_record_t config = {0};
/* Open the record and read its contents. */
rc = fds_record_open(&desc, &config);
APP_ERROR_CHECK(rc);
NRF_LOG_INFO("File Found with id %s",record.data.p_data);
printf("File Found with id %s",record.data.p_data);
/* Close the record when done reading. */
rc = fds_record_close(&desc);
rec_id++;
* @brief Initialise FDS
* @param[in] NONE
* @retval NONE
void init_fds()
ret_code_t rc;
/* Register first to receive an event when initialization is complete. */
(void) fds_register(fds_evt_handler);
NRF_LOG_INFO("Initializing fds...");
rc = fds_init();
NRF_LOG_INFO("fds init %d",rc);
/* Wait for fds to initialize. */
wait_for_fds_ready();
* @brief Function to call the power management
* @param[in] NONE
* @retval NONE
void idle_state_handle()
nrf_pwr_mgmt_run();
* @brief Initialise the peripherals
* @param[in] NONE
* @retval NONE
void init_peripherals()
NRF_LOG_INIT(NULL);
NRF_LOG_DEFAULT_BACKENDS_INIT(); //Use RTT as default backend
NRF_LOG_INFO("Start\r\n");
init_fds();
// twi added
* @brief Function for initializing the TWI peripheral.
void twi_init (void)
ret_code_t err_code;
const nrf_drv_twi_config_t twi_mpu_6050_config = {
.scl = 27 ,
.sda = 26 ,
.frequency = NRF_TWI_FREQ_400K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH
err_code = nrf_drv_twi_init(&m_twi_mpu_6050, &twi_mpu_6050_config, NULL, NULL);
nrf_drv_twi_enable(&m_twi_mpu_6050);
* @brief Function for writing to registers on the MPU-6050.
ret_code_t mpu_6050_I2C_register_write(uint8_t reg_addr, uint8_t * p_tx_data, uint8_t bytes)
ret_code_t ret_code;
uint8_t tx_data[bytes+1];
tx_data[0] = reg_addr;
for(uint8_t i = 0 ; i<bytes ; i++)
tx_data[i+1] = p_tx_data[i];
ret_code = nrf_drv_twi_tx(&m_twi_mpu_6050, MPU_6050_I2C_ADDR, tx_data, sizeof(tx_data), false);
return ret_code;
* @brief Function for reading from registers on the MPU-6050.
ret_code_t mpu_6050_I2C_register_read( uint8_t reg_addr, uint8_t * p_rx_data, uint32_t bytes)
ret_code = nrf_drv_twi_tx(&m_twi_mpu_6050,MPU_6050_I2C_ADDR, ®_addr, 1, false);
if(ret_code != NRF_SUCCESS)
return ret_code;
ret_code = nrf_drv_twi_rx(&m_twi_mpu_6050, MPU_6050_I2C_ADDR, p_rx_data, bytes);
return ret_code;
void mpu_6050_init (void)
uint8_t tx_data = 0;
// Write zero to the PWR_MGMT_1 register to wake up the MPU-6050
err_code = mpu_6050_I2C_register_write(PWR_MGMT_1, &tx_data, 1);
void mpu_6050_get_device_id (uint8_t * p_dev_id)
uint8_t rx_data;
// Read the I2C Address of the MPU-6050 from the WHO_AM_I register
err_code = mpu_6050_I2C_register_read(WHO_AM_I,&rx_data,1);
*p_dev_id = rx_data;
char *accel_data()
float *p_a_val;
float *p_b_val;
float *p_c_val;
int16_t *p_x_val;
int16_t *p_y_val;
int16_t *p_z_val;
// Raw accelerometer measurements buffer
uint8_t acc_data[6];
// Read the six accelerometer data registers starting from ACCEL_XOUT_H
mpu_6050_I2C_register_read(ACCEL_XOUT_H,acc_data,sizeof(acc_data));
/* Combine the two 8-bit data registers to a 16-bit value
for each axis by left shifting ACCEL_xOUT_H eight times
and OR it with ACCEL_xOUT_L. */
* p_x_val = (acc_data[0]<<8)|acc_data[1];
*p_y_val = (acc_data[2]<<8)|acc_data[3];
*p_z_val = (acc_data[4]<<8)|acc_data[5];
*p_a_val = (*p_x_val) /16384.0; // in m/s^2
*p_b_val = (*p_y_val) /16384.0; // in m/s^2
*p_c_val = (*p_z_val) /16384.0; // in m/s^2
alt[0]=*p_a_val;
alt[1]=*p_b_val;
alt[2]=*p_c_val;
sprintf(accel,",%.2f,%.2f,%.2f\n",alt[0],alt[1],alt[2]);
return accel;
* @brief Main Function
* @param[in] NONE
* @retval NONE
int main()
twi_init();
mpu_6050_init();
init_peripherals();
fds_write(accel);
fds_read();
while(1)
NRF_LOG_PROCESS();
accelerometer_value=accel_data();
idle_state_handle();
