Disable GPIO_AS_PINRESET on NCS SDK
Hello everyone,
I'm working on an nrf52832 custom board and trying to initialize the SPI module(I configured pin 21 as SCK)
I known pin 21 is a PIN_RESET, so I set CONFIG_GPIO_AS_PINRESET=n, but it did not affect and my application not working.
What's I'm missing?
    When you run a firmware that is configured with CONFIG_GPIO_AS_PINRESET=y, it will write to UICR. In order to erase UICR, you have to explicitly do so, or run a erase all (nrfjprog -e -f nrf52).
    Could you ensure that you have erased UICR first, then flash the new firmware?
    Håkon
    It still not working.
    Here are my SPI configurations and the custom board device tree:
    # LIS3DH Config
    CONFIG_SPI=y
    CONFIG_SPI_1=y
    CONFIG_SENSOR=y
    CONFIG_LIS2DH=y
    # GPIO config
    CONFIG_GPIO=y
    &spi1 {
    	compatible = "nordic,nrf-spi";
    	/* Cannot be used together with i2c0. */
    	status = "okay";
    	sck-pin = <21>;
    	mosi-pin = <20>;
    	miso-pin = <19>;
    	cs-gpios = <&gpio0 18 GPIO_ACTIVE_LOW>;
    	lis2dh12: lis2dh12@0 {
    		compatible = "st,lis2dh", "st,lis2dh12";
    		reg = <0>;
    		spi-max-frequency = <10000000>;
    		irq-gpios =  <&gpio0 17 GPIO_ACTIVE_HIGH>;
    		label = "LIS2DH12-ACCEL";
    const struct device *sensor = device_get_binding(DT_LABEL(DT_INST(0, st_lis2dh)));
    if (sensor == NULL) {
        LOG_INF("Could not get %s device\n", DT_LABEL(DT_INST(0, st_lis2dh)));
        return;
    P/s: When I set CONFIG_SPI=n, my application ran, but I couldn't bind the sensor module and received Error log: Could not get LIS2DH12-ACCEL device.
    I set CONFIG_SPI=y again, the application didn't run anything.
    This makes sense, as you're using SPI as the transport layer towards your sensor.
    What do you mean by not running anything? Is there a fault or similar occurring? Or no bus activity?
    Have you scoped the SPI lines? not just P0.21, but the others as well.
    Håkon
    I have some information log when my application starts running, and my BLE device will advertise.
    But, when I set CONFIG_SPI=y, I can't get any logs, and my device didn't advertise also.
    It seems like the program stuck somewhere
    If there's no output, have you tried entering debug mode to see where its stuck?
    Håkon
