how to write the data in nvmc block wise
Hi
I am working on nRF52832 , I want to store the data in NVMC . so I am trying to write the data blockwise , I saw the layout each page consists of Block 0-7 .To each block we can write the 512 bytes . how to write the data block wise or page 1
please suggest me
please have a look at code , it is correct ? why my data is updating while reading
 * Copyright (c) 2016 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @brief fstorage example main file.
 * This example showcases fstorage usage.
#include <stdint.h>
#include <stdbool.h>
#include <string.h>
#include "nrf.h"
#include "nrf_soc.h"
#include "nordic_common.h"
#include "boards.h"
#include "app_timer.h"
#include "app_util.h"
#include "nrf_fstorage.h"
#include "nrf_delay.h"
#ifdef SOFTDEVICE_PRESENT
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_fstorage_sd.h"
#else
#include "nrf_drv_clock.h"
#include "nrf_fstorage_nvmc.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define BUTTON_DETECTION_DELAY  APP_TIMER_TICKS(50)
#define APP_BLE_CONN_CFG_TAG    1
/* Defined in cli.c */
extern void cli_init(void);
extern void cli_start(void);
extern void cli_process(void);
static void fstorage_evt_handler(nrf_fstorage_evt_t * p_evt);
NRF_FSTORAGE_DEF(nrf_fstorage_t fstorage) =
    /* Set a handler for fstorage events. */
    .evt_handler = fstorage_evt_handler,
    /* These below are the boundaries of the flash space assigned to this instance of fstorage.
     * You must set these manually, even at runtime, before nrf_fstorage_init() is called.
     * The function nrf5_flash_end_addr_get() can be used to retrieve the last address on the
     * last page of flash available to write data. */
    .start_addr = 0x3e000,
    .end_addr   = 0x3ffff,
 char m_depth[80];
 char axis[80];
uint8_t x=0;
int i;
/**@brief   Helper function to obtain the last address on the last page of the on-chip flash that
 *          can be used to write user data.
static uint32_t nrf5_flash_end_addr_get()
    uint32_t const bootloader_addr = BOOTLOADER_ADDRESS;
    uint32_t const page_sz         = NRF_FICR->CODEPAGESIZE;
    uint32_t const code_sz         = NRF_FICR->CODESIZE;
    return (bootloader_addr != 0xFFFFFFFF ?
            bootloader_addr : (code_sz * page_sz));
/**@brief   Function for initializing the SoftDevice and enabling the BLE stack. */
    ret_code_t rc;
    uint32_t   ram_start;
    /* Enable the SoftDevice. */
    rc = nrf_sdh_enable_request();
    APP_ERROR_CHECK(rc);
    rc = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start);
    rc = nrf_sdh_ble_enable(&ram_start);
#else
static void clock_init(void)
    /* Initialize the clock. */
    ret_code_t rc = nrf_drv_clock_init();
    // Wait for the clock to be ready.
    while (!nrf_clock_lf_is_running()) {;}
/**@brief   Initialize the timer. */
static void timer_init(void)
/**@brief   Sleep until an event is received. */
static void power_manage(void)
    (void) sd_app_evt_wait();
#else
    __WFE();
    if (p_evt->result != NRF_SUCCESS)
        NRF_LOG_INFO("--> Event received: ERROR while executing an fstorage operation.");
        return;
    switch (p_evt->id)
        case NRF_FSTORAGE_EVT_WRITE_RESULT:
            NRF_LOG_INFO("--> Event received: wrote %d bytes at address 0x%x.",
                         p_evt->len, p_evt->addr);
        } break;
        case NRF_FSTORAGE_EVT_ERASE_RESULT:
            NRF_LOG_INFO("--> Event received: erased %d page from address 0x%x.",
        } break;
static void print_flash_info(nrf_fstorage_t * p_fstorage)
    NRF_LOG_INFO("========| flash info |========");
    NRF_LOG_INFO("erase unit: \t%d bytes",      p_fstorage->p_flash_info->erase_unit);
    NRF_LOG_INFO("program unit: \t%d bytes",    p_fstorage->p_flash_info->program_unit);
    NRF_LOG_INFO("==============================");
void wait_for_flash_ready(nrf_fstorage_t const * p_fstorage)
    /* While fstorage is busy, sleep and wait for an event. */
    while (nrf_fstorage_is_busy(p_fstorage))
        power_manage();
static void log_init(void)
    ret_code_t rc = NRF_LOG_INIT(NULL);
void test_data()
 x++;
 sprintf(axis,"%d",x);
return axis;
    ret_code_t rc;
#ifndef SOFTDEVICE_PRESENT
    clock_init();
    timer_init();
    log_init();
    cli_init();
    NRF_LOG_INFO("fstorage example started.");
    nrf_fstorage_api_t * p_fs_api;
    NRF_LOG_INFO("SoftDevice is present.");
    NRF_LOG_INFO("Initializing nrf_fstorage_sd implementation...");
    /* Initialize an fstorage instance using the nrf_fstorage_sd backend.
     * nrf_fstorage_sd uses the SoftDevice to write to flash. This implementation can safely be
     * used whenever there is a SoftDevice, regardless of its status (enabled/disabled). */
    p_fs_api = &nrf_fstorage_sd;
#else
    NRF_LOG_INFO("SoftDevice not present.");
    NRF_LOG_INFO("Initializing nrf_fstorage_nvmc implementation...");
    /* Initialize an fstorage instance using the nrf_fstorage_nvmc backend.
     * nrf_fstorage_nvmc uses the NVMC peripheral. This implementation can be used when the
     * SoftDevice is disabled or not present.
     * Using this implementation when the SoftDevice is enabled results in a hardfault. */
    p_fs_api = &nrf_fstorage_nvmc;
    rc = nrf_fstorage_init(&fstorage, p_fs_api, NULL);
    print_flash_info(&fstorage);
    /* It is possible to set the start and end addresses of an fstorage instance at runtime.
     * They can be set multiple times, should it be needed. The helper function below can
     * be used to determine the last address on the last page of flash memory available to
     * store data. */
    (void) nrf5_flash_end_addr_get();
    /* Let's write to flash. */
    /* Enable the SoftDevice and the BLE stack. */
    NRF_LOG_INFO("Enabling the SoftDevice.");
    ble_stack_init();
    m_data = 0xDEADBEEF;
while(1)
 test_data();
    rc = nrf_fstorage_write(&fstorage, 0x3f000,&axis, sizeof(axis), NULL);
    if(rc==NRF_SUCCESS)
printf("write data to flash :%s\n",axis);
    wait_for_flash_ready(&fstorage);
    NRF_LOG_INFO("Done.");
nrf_delay_ms(2000);
    rc = nrf_fstorage_read(&fstorage, 0x3f000,m_depth,sizeof(m_depth));
   if(rc==NRF_SUCCESS)
printf("read from flash:%s\n",m_depth);
    cli_start();
    /* Enter main loop. */
    for (;;)
        if (!NRF_LOG_PROCESS())
            power_manage();
        cli_process();
