Dear Members,
I saw this example,
I can not find this example on SDK 17,
How can I use UARTE0 and UARTE1 on separate port ? one is for debugging via USB and the other one for communicating with GPS UART ?
Any suggestions ?
Thanks
Dear Members,
I saw this example,
Any suggestions ?
Thanks
How can I implement this app with libuarte ?
\nRF5_SDK_15.2.0_9412b96\examples\peripheral\serial_uartes
thanks
................If you want to use two UARTE instances then you have to enable both instances in the config file and resources that the module is dependent on ( Timer and PPI) . Next you have to define an instance of the module and initialize it in the project. Again, the libUARTE example should be a good reference, it's pretty straightforward.
How ? What's PPI ? thanks
Could you add an APP_ERROR_CHECK(err_code) after each call to nrf_libuarte_async_init() and see if the application asserts during run time.
err_code=nrf_libuarte_async_init(&libuarte, &nrf_libuarte_async_config, uart_event_handler, (void *)&libuarte); APP_ERROR_CHECK(err_code); err_code=nrf_libuarte_async_init(&libuarte1, &nrf_libuarte_async_config1, uart_event_handler1, (void *)&libuarte1); APP_ERROR_CHECK(err_code);
blank screen on serial ....?
complete main.c
* Copyright (c) 2018 - 2020, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup libuarte_example_main main.c
* @ingroup libuarte_example
* @brief Libuarte Example Application main file.
* This file contains the source code for a sample application using libuarte.
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include "nrf_libuarte_async.h"
#include "nrf_drv_clock.h"
#include <bsp.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_queue.h"
NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 0, 0, 0, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 3);
NRF_LIBUARTE_ASYNC_DEFINE(libuarte1, 1, 0, 0, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 3);
static uint8_t text[] = "UART example started.\r\n Loopback:\r\n";
static uint8_t text_size = sizeof(text);
uint8_t text_rx[20];
static volatile bool m_loopback_phase;
typedef struct {
uint8_t * p_data;
uint32_t length;
} buffer_t;
NRF_QUEUE_DEF(buffer_t, m_buf_queue, 10, NRF_QUEUE_MODE_NO_OVERFLOW);
void uart_event_handler(void * context, nrf_libuarte_async_evt_t * p_evt)
nrf_libuarte_async_t * p_libuarte = (nrf_libuarte_async_t *)context;
ret_code_t ret;
switch (p_evt->type)
case NRF_LIBUARTE_ASYNC_EVT_ERROR:
bsp_board_led_invert(0);
case NRF_LIBUARTE_ASYNC_EVT_RX_DATA:
ret = nrf_libuarte_async_tx(p_libuarte,p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
if (ret == NRF_ERROR_BUSY)
buffer_t buf = {
.p_data = p_evt->data.rxtx.p_data,
.length = p_evt->data.rxtx.length,
ret = nrf_queue_push(&m_buf_queue, &buf);
APP_ERROR_CHECK(ret);
bsp_board_led_invert(1);
m_loopback_phase = true;
case NRF_LIBUARTE_ASYNC_EVT_TX_DONE:
if (m_loopback_phase)
nrf_libuarte_async_rx_free(p_libuarte, p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
if (!nrf_queue_is_empty(&m_buf_queue))
buffer_t buf;
ret = nrf_queue_pop(&m_buf_queue, &buf);
UNUSED_RETURN_VALUE(nrf_libuarte_async_tx(p_libuarte, buf.p_data, buf.length));
bsp_board_led_invert(2);
void uart_event_handler1(void * context, nrf_libuarte_async_evt_t * p_evt)
NRF_LOG_INFO("UART1 EVENT FROM GPS!\r\n");
ret_code_t ret = nrf_drv_clock_init();
ret_code_t err_code = NRF_LOG_INIT(app_timer_cnt_get);
nrf_libuarte_async_config_t nrf_libuarte_async_config = {
.tx_pin = TX_PIN_NUMBER,
.rx_pin = RX_PIN_NUMBER,
.baudrate = NRF_UARTE_BAUDRATE_115200,
.parity = NRF_UARTE_PARITY_EXCLUDED,
.hwfc = NRF_UARTE_HWFC_DISABLED,
.timeout_us = 100,
.int_prio = APP_IRQ_PRIORITY_LOW
nrf_libuarte_async_config_t nrf_libuarte_async_config1 = {
.tx_pin = SER_APP_TX_PIN,
.rx_pin = SER_APP_RX_PIN,
.baudrate = NRF_UARTE_BAUDRATE_9600,
.timeout_us = 100,
//err_code = nrf_libuarte_async_init(&libuarte, &nrf_libuarte_async_config, uart_event_handler, (void *)&libuarte);
//err_code = nrf_libuarte_async_init(&libuarte1, &nrf_libuarte_async_config1, uart_event_handler1, (void *)&libuarte1);
nrf_libuarte_async_enable(&libuarte);
//nrf_libuarte_async_enable(&libuarte1);
err_code = nrf_libuarte_async_tx(&libuarte, text, text_size);
//nrf_libuarte_async_rx_free(&libuarte1, text_rx, 20);
while (true)
NRF_LOG_FLUSH();
