Dear Members,
I saw this example,
I can not find this example on SDK 17,
How can I use UARTE0 and UARTE1 on separate port ? one is for debugging via USB and the other one for communicating with GPS UART ?
Any suggestions ?
Thanks
Dear Members,
I saw this example,
Any suggestions ?
Thanks
it works well on
* Copyright (c) 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
#include <stdint.h>
#include <stdbool.h>
#include <stddef.h>
#include "nrf.h"
#include "nrf_drv_clock.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_power.h"
#include "nrf_serial.h"
#include "app_timer.h"
#include "app_error.h"
#include "app_util.h"
#include "boards.h"
/** @file
* @defgroup nrf_serial_uartes_example main.c
* @ingroup nrf_serial_uartes_example
* @brief Example of @ref nrf_serial usage. Loopback example using two UARTE peripherals.
* Please short Arduino SCL and SDA GPIOs to start transmission.
#define OP_QUEUES_SIZE 3
#define APP_TIMER_PRESCALER NRF_SERIAL_APP_TIMER_PRESCALER
static void sleep_handler(void)
__WFE();
__SEV();
__WFE();
NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uarte0_drv_config,
RX_PIN_NUMBER, ARDUINO_SCL_PIN,
RTS_PIN_NUMBER, CTS_PIN_NUMBER,
NRF_UART_HWFC_DISABLED, NRF_UART_PARITY_EXCLUDED,
NRF_UART_BAUDRATE_115200,
UART_DEFAULT_CONFIG_IRQ_PRIORITY);
NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uarte1_drv_config,
ARDUINO_SDA_PIN, TX_PIN_NUMBER,
RX_PIN_NUMBER, TX_PIN_NUMBER,
SER_APP_RX_PIN, SER_APP_TX_PIN,
NRF_UART_BAUDRATE_9600,
#define SERIAL_FIFO_TX_SIZE 32
#define SERIAL_FIFO_RX_SIZE 32
NRF_SERIAL_QUEUES_DEF(serial0_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
NRF_SERIAL_QUEUES_DEF(serial1_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
#define SERIAL_BUFF_TX_SIZE 1
#define SERIAL_BUFF_RX_SIZE 1
NRF_SERIAL_BUFFERS_DEF(serial0_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
NRF_SERIAL_BUFFERS_DEF(serial1_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
NRF_SERIAL_CONFIG_DEF(serial0_config, NRF_SERIAL_MODE_DMA,
&serial0_queues, &serial0_buffs, NULL, sleep_handler);
NRF_SERIAL_CONFIG_DEF(serial1_config, NRF_SERIAL_MODE_DMA,
&serial1_queues, &serial1_buffs, NULL, sleep_handler);
NRF_SERIAL_UART_DEF(serial0_uarte, 0);
NRF_SERIAL_UART_DEF(serial1_uarte, 1);
ret_code_t ret;
ret = nrf_drv_clock_init();
APP_ERROR_CHECK(ret);
ret = nrf_drv_power_init(NULL);
ret = app_timer_init();
// Initialize LEDs and buttons.
bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS);
ret = nrf_serial_init(&serial0_uarte, &m_uarte0_drv_config, &serial0_config);
ret = nrf_serial_init(&serial1_uarte, &m_uarte1_drv_config, &serial1_config);
static char tx_message[] = "Hello nrf_serial!\n\r";
static char gps_message[] = "GPS DATA..\n\r";
ret = nrf_serial_write(&serial1_uarte,
tx_message,
strlen(tx_message),
NULL,
NRF_SERIAL_MAX_TIMEOUT);
ret = nrf_serial_write(&serial0_uarte,
tx_message,
strlen(tx_message),
NULL,
(void)nrf_serial_flush(&serial1_uarte, 0);
while (true)
char c;
char data[512];
ret= nrf_serial_write(&serial0_uarte, gps_message,strlen(gps_message), NULL, NRF_SERIAL_MAX_TIMEOUT);
(void)nrf_serial_read(&serial1_uarte, &data, sizeof(data), NULL,1000);
(void)nrf_serial_write(&serial0_uarte, &data, sizeof(data), NULL, 1000);
ret = nrf_serial_read(&serial0_uarte, &c, sizeof(c), NULL, 1000);
if (ret != NRF_SUCCESS)
continue;
(void)nrf_serial_write(&serial0_uarte, &c, sizeof(c), NULL, 0);
(void)nrf_serial_flush(&serial0_uarte, 0);
ret = nrf_serial_read(&serial1_uarte, &c, sizeof(c), NULL, 1000);
continue;
(void)nrf_serial_write(&serial1_uarte, &c, sizeof(c), NULL, 0);
nRF5_SDK_15.2.0_9412b96\examples\peripheral\serial_uartes
What happens when you run the application? Does it assert somewhere? Try to use the debugger and see if the application stops somewhere.
where do you want to put the breakpoint ? what do you want to see ? thanks
NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 0, 0, 0, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 3);
NRF_LIBUARTE_ASYNC_DEFINE(libuarte1, 1, 0, 0, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 3);
nrf_libuarte_async_config_t nrf_libuarte_async_config = {
.tx_pin = TX_PIN_NUMBER,
.rx_pin = RX_PIN_NUMBER,
.baudrate = NRF_UARTE_BAUDRATE_115200,
.parity = NRF_UARTE_PARITY_EXCLUDED,
.hwfc = NRF_UARTE_HWFC_DISABLED,
.timeout_us = 100,
.int_prio = APP_IRQ_PRIORITY_LOW
nrf_libuarte_async_config_t nrf_libuarte_async_config1 = {
.tx_pin = SER_APP_TX_PIN,
.rx_pin = SER_APP_RX_PIN,
.baudrate = NRF_UARTE_BAUDRATE_9600,
.timeout_us = 100,
nrf_libuarte_async_init(&libuarte, &nrf_libuarte_async_config, uart_event_handler, (void *)&libuarte);
nrf_libuarte_async_init(&libuarte1, &nrf_libuarte_async_config1, uart_event_handler1, (void *)&libuarte1);
Correct me ?
Code :
err_code = nrf_libuarte_async_init(&libuarte, &nrf_libuarte_async_config, uart_event_handler, (void *)&libuarte);
NRF_LOG_INFO("Err_code %u",err_code);
err_code = nrf_libuarte_async_init(&libuarte1, &nrf_libuarte_async_config1, uart_event_handler1, (void *)&libuarte1);
nrf_libuarte_async_enable(&libuarte);
Output :
UART example started.
Loopback:
it can not display NRF_LOG_INFO() ..... ??
