I am trying to add a characteristic and am getting error 7 (invalid param). I started out calling sd_ble_gatts_characteristic_add() directly but I realized that characteristic_add() in ble_srv_common.c already does a lot of the work for me - and either way, it made no difference.
I saw a number of places that the problem is not having enough memory allocated for UUIDs, so I increased this to 10 in sdk_config.h:
// <o> NRF_SDH_BLE_VS_UUID_COUNT - The number of vendor-specific UUIDs. #ifndef NRF_SDH_BLE_VS_UUID_COUNT #define NRF_SDH_BLE_VS_UUID_COUNT 4 #endif
but that didn't solve the problem. I think I can actually specify a 16-bit UUID here but it behaves the same either way:
void rv_service_init(rv_service_t *p_rv_service) {
uint32_t err_code;
ble_uuid_t service_uuid;
ble_uuid128_t base_uuid = BLE_UUID_RV_BASE_UUID;
ble_uuid_t temp_char_uuid;
// Declare 16 bit service and 128 bit base UUIDs and add them to BLE stack table
service_uuid.uuid = BLE_UUID_RV_SERVICE;
err_code = sd_ble_uuid_vs_add(&base_uuid, &service_uuid.type);
// Add the service
err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,
&service_uuid,
&p_rv_service->service_handle);
// SEGGER_RTT_WriteString(0, "Executing our_service_init().\n"); // Print message to RTT to the application flow
// SEGGER_RTT_printf(0, "Service UUID: 0x%#04x\n", service_uuid.uuid); // Print service UUID should match definition BLE_UUID_OUR_SERVICE
// SEGGER_RTT_printf(0, "Service UUID type: 0x%#02x\n", service_uuid.type); // Print UUID type. Should match BLE_UUID_TYPE_VENDOR_BEGIN. Search for BLE_UUID_TYPES in ble_types.h for more info
// SEGGER_RTT_printf(0, "Service handle: 0x%#04x\n", p_our_service->service_handle); // Print out the service handle. Should match service handle shown in MCP under Attribute values
static ble_gatts_attr_t attr_char_value;
void rv_char_init(rv_service_t *service) {
uint32_t err_code;
ble_add_char_params_t add_char_params;
add_char_params.uuid = BLE_UUID_RV_TEMP; /* this is a 16 bit number */
add_char_params.uuid_type = BLE_UUID_TYPE_BLE; /* BLE_UUID_TYPE_BLE (16 bit) or BLE_UUID_TYPE_VENDOR_BEGIN (128 bit) */ add_char_params.init_len = sizeof(uint8_t);
add_char_params.max_len = sizeof(uint8_t);
add_char_params.char_props.read = 1;
add_char_params.char_props.write = 0;
add_char_params.read_access = SEC_OPEN;
add_char_params.write_access = SEC_OPEN;
err_code = characteristic_add(service->service_handle, &add_char_params, &service->char_handles);
I don't know for sure that running out of UUIDs in stack memory is the problem, but a lot of posts seem to suggest that it is. If that's the case, do I have to do something OTHER than that #define ?
