Problem with pwm (piezo buzzer) using with ble_app_blinky example
I am trying to switch on-off a piezo buzzer though ble using the ble_app_blinky example.
i modified the code such that
led_0 show advertising
led_2 show connection
pin 8 show buzzer pin
Problem: the application runs correctly and connects with app but when i send the led_on command from app , the device automatically disconnect.
i have checked some threads and found out there is problem with pwm turning off.
#define ADVERTISING_LED                 BSP_BOARD_LED_0                         /**< Is on when device is advertising. */
#define CONNECTED_LED                   BSP_BOARD_LED_2                         /**< Is on when device has connected. */
#define LEDBUTTON_LED                   8                                      /**< LED to be toggled with the help of the LED Button Service. */
#define LEDBUTTON_BUTTON                BSP_BUTTON_0                            /**< Button that will trigger the notification event with the LED Button Service */
uint32_t value;  //for buzzer volume
APP_PWM_INSTANCE(PWM1,1);                   // Create the instance "PWM1" using TIMER1.
static volatile bool ready_flag;            // A flag indicating PWM status.
void pwm_ready_callback(uint32_t pwm_id)    // PWM callback function
    ready_flag = true;
void buzz_config(void){
    /* 2-channel PWM, 200Hz, output on DK LED pins. */
    app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(250L,LEDBUTTON_LED);
    /* Initialize and enable PWM. */
    app_pwm_init(&PWM1,&pwm1_cfg,pwm_ready_callback);
		pwm1_cfg.pin_polarity[0] = APP_PWM_POLARITY_ACTIVE_HIGH;
		app_pwm_enable(&PWM1);
	  app_pwm_channel_duty_set(&PWM1, 0, 0);
void buzz_on(){
			for (uint8_t i = 0; i < 40; ++i)
					value = (i < 20) ? (i * 5) : (100 - (i - 20) * 5);
					ready_flag = false;
					while (app_pwm_channel_duty_set(&PWM1, 0, value) == NRF_ERROR_BUSY);
					nrf_delay_ms(25);
static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state)
    if (led_state)
		 buzz_on();
    // Initialize.
    log_init();
    leds_init();
    timers_init();
    buttons_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
	buzz_config();
    // Start execution.
    //NRF_LOG_INFO("Blinky example started.");
    advertising_start();
    // Enter main loop.
    for (;;)
        idle_state_handle();
Please help me for the same. thanks
    When the disconnect happens, do the device also do a reset?
    Do the log give any indication to what may go wrong?
    I cannot see any calls to APP_ERROR_CHECK that could cause this in the posted code, but it may be in some parts that you excluded. You are spending a very long time inside the led_write_handler (25ms * 40 = 1000ms), which typically runs at a high priority. Could you try to only set a flag in the handler and process the PWM operation in the main-loop?
    Jørgen
  •  yes, the device do a reset after sending led-on command from the Blinky app.
    can you provide some details about how can I use flags here (i am using pwm library as a reference).
    thanks and regards
    Rajat
  • Something like this:
    static uint8_t led_on = false;
        if (led_state)
    		 led_on = true;
        // Enter main loop.
        for (;;)
            if(led_on == true)
                buzz_on();
                led_on = false;
  • Thank you for your reply but it still getting reset after sending Led-on command from the app.
    The whole code is as follows
     * @brief Blinky Sample Application main file.
     * This file contains the source code for a sample server application using the LED Button service.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_err.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "boards.h"
    #include "app_timer.h"
    #include "app_button.h"
    #include "ble_lbs.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "app_pwm.h"
    #include "nrf_delay.h"
    #define DEVICE_NAME                     "Nordic_Blinky_Rajat"                         /**< Name of device. Will be included in the advertising data. */
    #define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_ADV_INTERVAL                64                                      /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */
    #define APP_ADV_DURATION                BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED   /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.5 seconds). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (1 second). */
    #define SLAVE_LATENCY                   0                                       /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(20000)                  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000)                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)                     /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
    #define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    BLE_LBS_DEF(m_lbs);                                                             /**< LED Button Service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
    static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;                   /**< Advertising handle used to identify an advertising set. */
    static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];                    /**< Buffer for storing an encoded advertising set. */
    static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX];         /**< Buffer for storing an encoded scan data. */
    //*******************************************************Buzzer********************************************************************************
        ready_flag = true;
    // PWM initialization function
    void buzz_init(void){
    		ret_code_t err_code;
        /* 1-channel PWM, 4KHz, output on buzzer pins. */
        err_code =app_pwm_init(&PWM1,&pwm1_cfg,pwm_ready_callback);
    void buzz_on(){
    							ready_flag = false;
    							nrf_delay_ms(25);
    /**@brief Struct that contains pointers to the encoded advertising data. */
    static ble_gap_adv_data_t m_adv_data =
        .adv_data =
            .p_data = m_enc_advdata,
            .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
        .scan_rsp_data =
            .p_data = m_enc_scan_response_data,
    /**@brief Function for assert macro callback.
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for the LEDs initialization.
     * @details Initializes all LEDs used by the application.
    static void leds_init(void)
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module.
    static void timers_init(void)
        // Initialize timer module, making it use the scheduler
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
        ble_advdata_t advdata;
        ble_advdata_t srdata;
        ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
        // Build and set advertising data.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        advdata.include_appearance = true;
        advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        memset(&srdata, 0, sizeof(srdata));
        srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
        srdata.uuids_complete.p_uuids  = adv_uuids;
        err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
        err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
        ble_gap_adv_params_t adv_params;
        // Set advertising parameters.
        memset(&adv_params, 0, sizeof(adv_params));
        adv_params.primary_phy     = BLE_GAP_PHY_1MBPS;
        adv_params.duration        = APP_ADV_DURATION;
        adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
        adv_params.p_peer_addr     = NULL;
        adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
        adv_params.interval        = APP_ADV_INTERVAL;
        err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling write events to the LED characteristic.
     * @param[in] p_lbs     Instance of LED Button Service to which the write applies.
     * @param[in] led_state Written/desired state of the LED.
        if (led_state)
    			  led_on = true;
    				app_pwm_disable(&PWM1);
        ble_lbs_init_t     init     = {0};
        // Initialize LBS.
        init.led_write_handler = led_write_handler;
        err_code = ble_lbs_init(&m_lbs, &init);
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module that
     *          are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply
     *       setting the disconnect_on_fail config parameter, but instead we use the event
     *       handler mechanism to demonstrate its use.
    /**@brief Function for handling a Connection Parameters error.
        err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
        bsp_board_led_on(ADVERTISING_LED);
            case BLE_GAP_EVT_CONNECTED:
               // NRF_LOG_INFO("Connected");
                bsp_board_led_on(CONNECTED_LED);
                bsp_board_led_off(ADVERTISING_LED);
                err_code = app_button_enable();
               // NRF_LOG_INFO("Disconnected");
                bsp_board_led_off(CONNECTED_LED);
                err_code = app_button_disable();
                // Pairing not supported
                err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                       BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                       NULL,
                                                       NULL);
                //NRF_LOG_DEBUG("PHY update request.");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
                //NRF_LOG_DEBUG("GATT Client Timeout.");
            case BLE_GATTS_EVT_TIMEOUT:
                //NRF_LOG_DEBUG("GATT Server Timeout.");
                // No implementation needed.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the button handler module.
     * @param[in] pin_no        The pin that the event applies to.
     * @param[in] button_action The button action (press/release).
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
        switch (pin_no)
            case LEDBUTTON_BUTTON:
                //NRF_LOG_INFO("Send button state change.");
                err_code = ble_lbs_on_button_change(m_conn_handle, &m_lbs, button_action);
                if (err_code != NRF_SUCCESS &&
                    err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                    err_code != NRF_ERROR_INVALID_STATE &&
                    err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
                APP_ERROR_HANDLER(pin_no);
    /**@brief Function for initializing the button handler module.
    static void buttons_init(void)
        //The array must be static because a pointer to it will be saved in the button handler module.
        static app_button_cfg_t buttons[] =
            {LEDBUTTON_BUTTON, false, BUTTON_PULL, button_event_handler}
        err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
                                   BUTTON_DETECTION_DELAY);
    static void log_init(void)
            nrf_pwr_mgmt_run();
    /**@brief Function for application main entry.
        // Initialize.
        //log_init();
        leds_init();
        timers_init();
        buttons_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        buzz_init();
        // Start execution.
        // Enter main loop.
        for (;;)
    		if(led_on == true)
                    buzz_on();
                    led_on = false;
    Thanks and regards
    Rajat
  • I tested you code, but I was not able to reproduce the reset. Can you upload the full project? There may be something in your project settings or configuration that causes this behavior.
