GPS and accelerometer data to own AWS server
I am a little confused between GPS and AGPS sample code provided by nordic. can you help me to understand it?
I just want to send GPS and accelerometer data of thingy91 to my own AWS IOT server. which one would be the easiest way to use to satisfy requirements.
  • Rkidechaa said:
    both are working fine when run individually.
     For GPS and LTE to run concurrently, you need to enable PSM. As far as I can tell, from the CEREG return value PSM is not enabled. What SIM/operator are you using. What location do you try to connect from?
  • What SIM/operator are you using. What location do you try to connect from?
    SIM operator is Ibasis only. Location =  USA -Texas, Arlington.
    I have successfully received the accelerometer data on my AWS server. Now when I am trying to send data from another thingy on the same server getting an error.
    2021-01-12T05:22:18.759Z DEBUG modem << *** Booting Zephyr OS build v2.4.0-ncs1-1710-g5a7b4eb71047  ***
    2021-01-12T05:22:18.760Z DEBUG modem << I: BSDlib is not yet initialized, AT commands not sent
    2021-01-12T05:22:18.761Z DEBUG modem << I: Configuration of MAGPIO and COEX0 is left to drivers
    2021-01-12T05:22:18.762Z DEBUG modem << The AWS IoT sample started, version: v1.0.0
    2021-01-12T05:22:20.656Z DEBUG modem << LTE cell changed: Cell ID: 133272592, Tracking area: 27174
    2021-01-12T05:22:20.659Z DEBUG modem << PSM parameter update: TAU: -1, Active time: -1
    2021-01-12T05:22:20.700Z DEBUG modem << RRC mode: Connected
    2021-01-12T05:22:22.563Z DEBUG modem << Network registration status: Connected - roaming
    2021-01-12T05:22:23.218Z DEBUG modem << DATE_TIME_OBTAINED_NTP
    2021-01-12T05:22:23.222Z DEBUG modem << Next connection retry in 30 seconds
    2021-01-12T05:22:23.224Z DEBUG modem << AWS_IOT_EVT_CONNECTING
    2021-01-12T05:22:23.520Z DEBUG modem << E: mqtt_connect, error: -95
    2021-01-12T05:22:23.523Z DEBUG modem << AWS_IOT_EVT_CONNECTING
    2021-01-12T05:22:29.284Z DEBUG modem << RRC mode: Idle
    2021-01-12T05:22:53.220Z DEBUG modem << Next connection retry in 30 seconds
    2021-01-12T05:22:53.222Z DEBUG modem << AWS_IOT_EVT_CONNECTING
    2021-01-12T05:22:53.320Z DEBUG modem << RRC mode: Connected
    2021-01-12T05:22:53.535Z DEBUG modem << E: mqtt_connect, error: -95
    2021-01-12T05:22:53.537Z DEBUG modem << AWS_IOT_EVT_CONNECTING
    2021-01-12T05:22:59.287Z DEBUG modem << RRC mode: Idle
    can we set multiple thingies to send data to the AWS IOT account?
     Yes, that should be possible. You need to set up individual certificates though. Have you done that?
  • Hello ! Were you able to send GPS data to AWS? Thanks :)
