RSSI meter wildly ineffective
The nRF 52840 RSSI "meter" is not usable.
I tested in an RF (2.4Ghz) quiet neighborhood. Using a reference receiver, I measured RSSI variance around +/-3 dB (95% confidence interval) from each of 5 transmitters; this is in line with expectation. Noise was below -99 at all times during the 1 hour test. I positioned a nRF 52840 20 cm away from the reference measurement station. The Nordic RSSI values did not exhibit a Gaussian noise curve at all, but instead reported three strong modes at -79, -65, and -58; each with incredibly small tails. Binning the results according to proximity to these modes revealed a variance of 0.2 dB (95%), which is more precise than noise will allow. From this evidence I gather three important facts: a more distant node can have a higher RSSI, the RSSI cannot be averaged to reduce "noise" as the values are nonlinear and modal, and therefore there is no way to estimate relative signal strength from the relative signal strength indicator. I used 5 transmitters during this test and observed similar behavior from each, both reasonable values from my reference receiver and unreasonable values from the Nordic chip. RSSI does not work as intended. Please document this behavior, consider disabling the API for this part, and further document which nRF parts actually work.
Please tell me what part I have to replace in my next board design to achieve usable RSSI?
  • To confirm, when I switch the beacon to any one advertisement channel, the RSSI meter returns to expected behavior. Having all three channel RSSI meters would be invaluable. Please see whether the team can put this on the road map for 2021?
  • Being lazy (== busy) I haven't read the entire thread in detail, but I already display separate RSSI values for all 40 channels - including the advertising channels - on an e-Ink display. Does this help at all? Place in ble_evt_handler()
            case BLE_GAP_EVT_RSSI_CHANGED:                 // 28 RSSI report
                rssi_value =  p_gap_evt->params.rssi_changed.rssi;
                int16_t channel_rssi =  p_gap_evt->params.rssi_changed.ch_index;
                NRF_LOG_INFO("RSSI changed, new: %d, channel: %2d, power %ddBm",rssi_value, channel_rssi, p_gap_evt->params.adv_report.tx_power);
                int16_t LimitedValue = rssi_value; if (LimitedValue < -99) LimitedValue = -99;  if (LimitedValue > 99) LimitedValue = 99;
                rssiValues[channel_rssi] = LimitedValue;
            case BLE_GAP_EVT_CONNECTED:
                // Start RSSI collection for reports
                //   Minimum change in dBm before triggering BLE_GAP_EVT_RSSI_CHANGED event
                //   Number of RSSI samples with a change of threshold_dbm or more before BLE_GAP_EVT_RSSI_CHANGED event
                err_code = sd_ble_gap_rssi_start(p_gap_evt->conn_handle, 4, 2);
                // Set RSSI to minimums
                InitRssiValues();
                Blah Blah
                InitRssiValues();
                Blah Blah
    Assumes:
    // Channel rssi values, 37 data and 3 advertising
    int16_t rssiValues[40] = {-99};
    #define BLE_CHANNEL_COUNT sizeof(rssiValues)/sizeof(rssiValues[0])
    #define BLE_DATA_CHANNELS (BLE_CHANNEL_COUNT-3)
    STATIC_ASSERT(BLE_CHANNEL_COUNT == 40, "BLE_CHANNEL_COUNT == 40 error");
    static void InitRssiValues(void)
        for (uint16_t i=0; i<BLE_CHANNEL_COUNT; i++)
            rssiValues[i] = -99;
    This on the Central, by the way
  • Thank you , it does. Unfortunately, we are hoping to implement something like this on the 9160 platform which utilizes the nRF Connect SDK. Can anyone from Nordic comment as to the ability for a user to parse out the RSSI per channel on the nRF Connect SDK? Do we have access to the "p_gap_evt" struct?
  • Hi Cody,
    I'm taking over the case from Andreas.
    I will check with our team if there is any solution for this.
    From my understanding you are asking about 2 options:
    - report of RSSI per channel
    - Or possibility to do selective channel when scanning ?
    In the mean time please let us know how do you measure RSSI? by using the rssi value in the call back bt_le_scan_cb_t ?
