softdevice error code 0x0000000D1
Hi all
I am using S130 SDK12, nRF51822
This is the error I am getting - line_num 0x07C0, p_file_name 0x06D1, error code 0x00D1, fault id 0x0001, pc 0x83CC (a print-screen from the debugger is also below)
The error occurred repeatedly in the same scenario
I added a notification characteristic to an existing custom service, and when the central subscribe to the notification and it is being sent the error occurs.
The error occurs only when I compile with optimization (I optimized to level 3)
The notification was sent (using sd_ble_gatts_hvx) from a function invoked by at timer interrupt (timer_timeouts_check()), so I changed it to be sent from the event scheduler, and this apparently resolved the issue, partly, I still wish to
1. Understand what happened, to assure the problem or bug is not still hiding somewhere
2. Return to my original implementation simply because it saves me important flash memory.
Would appreciate any help
Thanks
    Another question if I may, I played around with the code a bit, without using irq_diable(), I was able to avoid Hardfault but still getting error 0x0003 returned from sd_ble_gatts_hvx  , what can this mean?
    Thanks and best regards
    Did you try to increase the stack size? This error is an internal error, and its the default return code if the input parameters are not matching the expected format.
    You can set the stack size as high as you'd like, but it is restricted towards how much RAM you have available.
    Ron said:
    If the problem is a stack overflow, what is the best way to verify it?
    When in debug mode, check the cpu register "SP", and see if the address there is outside the area that is set-aside for the stack. You can find the stack area in your .map file.
    Håkon
  • Hi Håkon
    I am using the nrf51822xxaa with s130, what is the maximum stack size I can chose and how exactly it is done? Increasing the stack size will be done via the arm_startup_nrf51.s file?
                    IF :DEF: __STARTUP_CONFIG
    Stack_Size      EQU __STARTUP_CONFIG_STACK_SIZE
                    ELIF :DEF: __STACK_SIZE
    Stack_Size      EQU __STACK_SIZE
                    ELSE
    Stack_Size      EQU 2048
                    ENDIF
    This is what I am seeing on the .map file
    STACK$$Length                            0x00000800   Number         0  anon$$obj.o ABSOLUTE
    After failing on the sd_ble_gatts_hvx I checked the SP, it is 0x20003918
    According to the .map file
    STACK     0x20003178   Section     2048  arm_startup_nrf51.o(STACK)
    STACK$$Base 0x20003178 Number 0 arm_startup_nrf51.o(STACK)
    __initial_sp 0x20003978 Data 0 arm_startup_nrf51.o(STACK)
    between 0x20003918 and 0x20003978 there is some space although I don't know how much the softdevice used during the execution of sd_ble_gatts_hvx  what do you think?
    Could you share the full function that calls sd_ble_gatts_hvx()?
    Does the issue still occur immediately, or does it happen "after some time"?
     This shows that there's only 0x60 bytes of stack being used, so there's no stack overflow.
    You can increase the size by setting the ASM define "__STACK_SIZE=3072" in your keil project settings -> assembly tab. You have to ensure that you do not exceed the amount of RAM that you have available. If you have the 16k version, you can currently set it to max. 3720 bytes for instance.
    Håkon
  • Hi
    uint32_t ble_eff_notify_hvx_send(ble_led_t * p_ble, uint8_t * data)
        uint32_t err_code = NRF_SUCCESS;
        if (p_ble->conn_handle != BLE_CONN_HANDLE_INVALID)
            ble_gatts_hvx_params_t hvx_params;
            uint16_t hvx_len = sizeof(uint8_t);
            // Initialize value struct.
            hvx_params.handle = p_ble->eff_notify_handles.value_handle;
            hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
            hvx_params.p_len  = &hvx_len;
            hvx_params.offset = 0;
            hvx_params.p_data = data;
            err_code = sd_ble_gatts_hvx(p_ble->conn_handle, &hvx_params);
            err_code = NRF_ERROR_INVALID_STATE;
        return err_code;
    This happens every time the the sd_ble_gatts_hvx  function is called, I have a breakpoint after the
    Ok, I tried this, did not work...
    Any other ideas?
    Thanks again!
