Cannot connect to Nordic Cloud using custom PCB
Dear community,
Dear Nordic engineers,
For some reason I cannot connect my custom board to the nordic cloud. Previously I have followed the described procedures with the nRF91-DK and I successfully connected to the Nordic cloud with the asset tracker example software. I am now using my custom PCB which seems to register to the LTE network here in the Netherlands (see picture below):
However it does not seem to connect to the Nordic cloud see the log from the terminal below:
[00:00:12.906,311] [0m<inf> asset_tracker: Connected to LTE network.[0m
[00:00:12.913,085] [0m<inf> asset_tracker: Network registration status: Connected - home network[0m
[00:00:13.076,202] [0m<inf> asset_tracker: DATE_TIME_OBTAINED_NTP[0m
[00:00:13.082,611] [0m<inf> asset_tracker: Connecting to cloud, attempt 1 of 8[0m
[00:00:13.090,087] [0m<inf> asset_tracker: Cloud connection request sent.[0m
[00:00:13.097,106] [0m<inf> asset_tracker: Connection response timeout is set to 30 seconds.[0m
[00:00:13.105,895] [0m<inf> asset_tracker: CLOUD_EVT_CONNECTING[0m
[00:00:13.168,090] [0m<dbg> nrf_cloud_transport.nct_connect: IPv4 address: 3.221.63.246[0m
[00:00:13.176,330] [0m<dbg> nrf_cloud_transport.nct_mqtt_connect: MQTT clean session flag: 1[0m
[00:00:17.752,685] [0m<inf> nrf_cloud_transport: Using socket send timeout of 60 seconds[0m
[00:00:17.761,047] [0m<dbg> nrf_cloud.nrf_cloud_run: Cloud connection request sent.[0m
[00:00:17.939,239] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_DISCONNECT: result = -128[0m
[00:00:17.949,035] [0m<dbg> nrf_cloud_fsm.drop_event_handler: Dropping FSM transition 9, current state 1[0m
[00:00:18.459,014] [0m<dbg> nrf_cloud.nrf_cloud_run: Socket error: POLLNVAL[0m
[00:00:18.466,278] [0m<dbg> nrf_cloud.nrf_cloud_run: The cloud socket was unexpectedly closed.[0m
[00:00:18.475,219] [0m<inf> asset_tracker: CLOUD_EVT_DISCONNECTED: 2[0m
[00:00:18.481,872] [0m<inf> asset_tracker: Cloud connection closed.[0m
[00:00:18.488,372] [0m<inf> asset_tracker: This can occur during initial nRF Cloud provisioning.[0m
[00:00:18.497,436] [0m<inf> asset_tracker: Attempting reconnect in 10 seconds...[0m
[00:00:18.505,096] [0m<dbg> nrf_cloud_transport.nct_disconnect: nct_disconnect[0m
[00:00:28.505,157] [0m<inf> asset_tracker: Connecting to cloud, attempt 2 of 8[0m
[00:00:28.512,664] [0m<inf> asset_tracker: Cloud connection request sent.[0m
[00:00:28.519,683] [0m<inf> asset_tracker: Connection response timeout is set to 30 seconds.[0m
[00:00:28.528,411] [0m<inf> asset_tracker: CLOUD_EVT_CONNECTING[0m
[00:00:28.535,247] [0m<dbg> nrf_cloud_transport.nct_connect: IPv4 address: 3.221.63.246[0m
[00:00:32.698,303] [0m<inf> nrf_cloud_transport: Using socket send timeout of 60 seconds[0m
[00:00:32.706,726] [0m<dbg> nrf_cloud.nrf_cloud_run: Cloud connection request sent.[0m
[00:00:32.877,655] [0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_DISCONNECT: result = -128[0m
[00:00:32.887,512] [0m<dbg> nrf_cloud_fsm.drop_event_handler: Dropping FSM transition 9, current state 1[0m
[00:00:33.397,460] [0m<dbg> nrf_cloud.nrf_cloud_run: Socket error: POLLNVAL[0m
[00:00:33.404,663] [0m<dbg> nrf_cloud.nrf_cloud_run: The cloud socket was unexpectedly closed.[0m
[00:00:33.413,513] [0m<inf> asset_tracker: CLOUD_EVT_DISCONNECTED: 2[0m
[00:00:33.420,135] [0m<inf> asset_tracker: Cloud connection closed.[0m
[00:00:33.426,605] [0m<inf> asset_tracker: This can occur if the device has the wrong nRF Cloud certificates.[0m
[00:00:33.436,798] [0m<inf> asset_tracker: Attempting reconnect in 480 seconds...[0m
[00:00:33.444,549] [0m<dbg> nrf_cloud_transport.nct_disconnect: nct_disconnect[0m
It looks like it connects to the LTE network and then tries to connect to the Nordic cloud but fails, and keeps on trying but continuously fails connecting to the Nordic Cloud.
I hope you can help me with this problem.
