nrfjprog over usb
I use usb with secure bootloader to flash 52833/840/832 boards.  Is there a way to use the nrfjprog --memwr/rd over the usb after a DFU on USB upgrade to new app?
Steps w/o DFU  are as follows
nrfjprog --recover
make flash_softdevice
make clean
make -j12 flash (app)
nrfjprog --memwr 0x7fd00 --val 0x10012048
nrfjprog --memrd 0x7fd00 --n 8
This works fine
But after the bootloader is loaded with SWD
Then the softdevice is flashed
then plug the usb in and find the port
then the nrfutil zip file --p COMXX --b 115200
At this point the app is working
Can I use nrfjprog over USB to write the addresses or is there another way that you can share with me to get this accomplished?
Thanks
  • Hi Stevie,
    I afraid what you are asking for is not possible.
    nrfjprog only works with the SWD programming interface.
    What you got when you call nrfutil to download the .zip file via USB is the nrfutil talk to the bootloader to send the image via UART/USB to the bootloader and the bootloader replace the old image with the new image.
    You can, however, modify the bootloader so that it also accept a custom command to read out a place in flash and reply that via UART. But you would need to implement that and the application on PC to talk to the bootloader.
